Question about Dryers
I have power but the motor does not work - Dryers
  • 2,992 Answers
If you have a volt-ohm meter check voltage at motor. If no voltage, there is a problem with the dryer switch for "run" which may be a relay. OR there is a problem with the door switch which is broken or "thinks" the door is still open and will not alow the motor to run.
Posted on Mar 31, 2015
Testimonial: "Thank you for the suggestion but the question is not about a dryer. I am talking about my Kenmore "Intuition" vacuum cleaner Model#116.28014700"
  • gbob59 Mar 31, 2015
    Probably a bad switch, or a bad switch that may determine if a filter is in place or needs to be changed.
1999 Nissan Pathfinder sunroof tilt will not close. sunroof tilt open works but will not close. Motor to open works but motor will not energize to close. Jumpered power to close circuit and motor doe
-Sounds like the motor is effect on Reverse position.
-If jump power to either terminal. If it work on both, that mean the switch is bad. But If it works only one terminal that mean the motor.
Good Luck
Mai
Apr 04, 2014 | Vehicle Parts & Accessories
I plug it and try to turn it on but no power
not sure what you have going there? was the motor working before you removed it?Theres a great chance the motor is burned out!
to test it first grab the motor onlyconnect it to power bypassing any circuit between the motor and power, if the motor still will not spend then that is your issue----- you can try and recoil the motor but its not worth it however it will work if thats the issue, if the motor works after direct power then the issue is the circuit board--- look for bad parts good luck more questions just ask
Mar 29, 2013 | Blenders
Electric car windows will not close properly -every onr of them
POWER WINDOWS NOT WORKING & POWER WINDOW/REGULATOR ISSUES
It can be issue with motor itself. If it's not going up, then how its working down. But still it feels like weak window motor or is issue with power window switch. Get the voltage tested at switch and motor. Also try another working window motor at not working window side.
For more troubleshooting i suggest go through the help links mentioned below:-----
Its complete details with troubleshooting steps:------
Car windows will go down but come right back up
http://schematicsdiagram.blogspot.com/2011/06/car-windows-will-go-down-but-come-right.html
Power windows will not go up and relay clicks when switch is pressed?
http://technoanswers.blogspot.com/2012/01/power-windows-will-not-go-up-and-relay.html
Electric Window Motor REMOVAL and INSTALLATION on ford vehicles?
http://schematicsdiagram.blogspot.com/2011/06/electric-window-motor-removal-and.html
Driver side power window wont go up on ford expedition?
http://howtobyme.blogspot.com/2011/10/driver-side-power-window-wont-go-up-on.html
How to replace window motor and regulator on jaguar S-Type?
http://howtobyme.blogspot.com/2011/09/how-to-replace-window-motor-and.html
How to remove window motor and regulator on Volkswagen Car?
http://howtobyme.blogspot.com/2011/09/how-to-remove-window-motor-and.html
power locks, power window and power mirror on the passenger side not working on Ford Windstar
http://howtobyme.blogspot.com/2011/09/power-locks-power-window-and-power.html
All power windows not working on 2003 Cadillac CTS?
http://howtobyme.blogspot.com/2011/09/all-power-windows-not-working-on-2003.html
How to remove the door panel to install a new window regulator on Cadillac Deville?
http://howtobyme.blogspot.com/2011/08/how-to-remove-door-panel-to-install-new.html
How to Remove Electric Window Motor on Acura Integra?
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-electric-window-motor-on.html
How to replace power window motor in car?
http://schematicsdiagram.blogspot.com/2011/06/how-to-replace-power-window-motor-in.html
HOW TO REPLACE A POWER WINDOW SWITCH
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-power-window-switch.html
How to Replace a Window Motor
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-window-motor.html
HOW TO REPLACE A WINDOW REGULATOR WITH MOTOR
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-window-regulator-with.html
HOW TO REPLACE WINDOW RUN CHANNEL SEALS
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-window-run-channel-seals.html
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-window-regulator.html
How to replace power window regulator for 2006 Dodge Dakot
How to remove passenger side power window motor on Dodge Grand Caravan?
http://schematicsdiagram.blogspot.com/2011/09/how-to-remove-passenger-side-power.html
How to replace automatic window motor unit for the front passenger side on 2001 jeep grand cherokee Laredo ?
http://schematicsdiagram.blogspot.com/2011/09/how-to-replace-automatic-window-motor.html
how to replace passenger side power window motor on 2001 Dodge van
All power windows not working on mercury sable?
http://technoanswers.blogspot.com/2011/09/all-power-windows-not-working-on.html
How to replace electric window regulator for mitsubishi 380 ?
http://technoanswers.blogspot.com/2011/09/how-to-replace-electric-window_05.html
how to remove window motor on driver side door panel on 1994 Oldsmobile Cutlass Ciera
http://technoanswers.blogspot.com/2011/08/how-to-remove-window-motor-on-driver.html
driver side window problem on Mercury Sable
http://technoanswers.blogspot.com/2011/06/driver-side-window-problem-on-mercury.html
How to remove door panel, door window motor and regulator on 1991 cavalier?
http://technoanswers.blogspot.com/2011/05/how-to-remove-door-panel-door-window.html
how to replace the power window switch on 2005 BMW 325i?
http://technoanswers.blogspot.com/2011/03/how-to-replace-power-window-switch-on.html
How to replace window switch on bmw?
http://technoanswers.blogspot.com/2011/03/how-to-replace-window-switch-on-bmw.html
ford explorer window motor, regulator and door panel removal?
http://technoanswers.blogspot.com/2011/02/ford-explorer-window-motor-regulator.html
How to Replace a Window Switch on a 2002 Ford Explorer ?
http://technoanswers.blogspot.com/2011/02/how-to-replace-window-switch-on-2002.html
Ford F-150 Power Windows Not Working?
http://schematicsdiagram.blogspot.com/2011/12/ford-f-150-power-windows-not-working.html
Power windows works intermittently?
http://schematicsdiagram.blogspot.com/2011/12/power-windows-works-intermittently.html
Pontiac grand am power window not working?
http://repairhelpcenter.blogspot.com/2012/01/pontiac-grand-am-power-window-not.html
Auto open close feature not working for Toyota Avalon?
http://technoanswers.blogspot.com/2012/01/auto-open-close-feature-not-working-for.html
Lexus ES300 Power window out of time?
http://repairhelpcenter.blogspot.com/2012/01/lexus-es300-power-window-out-of-time.html
Rear power windows not working on Ford Mustang?
http://technoanswers.blogspot.com/2012/01/rear-power-windows-not-working-on-ford.html
All power windows not working on Ford Explorer?
http://technoanswers.blogspot.com/2012/01/all-power-windows-not-working-on-ford.html
2003 Chevy impala power windows not working?
http://technoanswers.blogspot.in/2012/02/2003-chevy-impala-power-windows-not.html
Diagnosis & Testing Power Windows?
http://repairhelpcenter.blogspot.in/2012/02/diagnosis-testing-power-windows.html
All Power Windows Not Working
http://whatisbyme.blogspot.in/2012/07/all-power-windows-not-working.html
1977 Chevrolet Corvette Power Windows Not Working?
http://technoanswers.blogspot.in/2012/04/1977-chevrolet-corvette-power-windows.html
These details will help.
Thanks.
Dec 31, 2012 | Cars & Trucks
How do i change the drivers side window motor an an 05 kia sedona
You have to remove the inner door panel to
access the window regulator
You remove the regulator & then the motor from it
You Tube Video will provide a visual of several
similar window motor replacement jobs
Go there-- enter your car,question ,details,etc--- then move
around the site to watch various things
Dec 09, 2012 | 2005 Kia Sedona
Thank yo for the schematic Ernesto. It says Nissan 1996, so is the 2008 still using the same schematic?
It can be issue with motor itself.If its not going up,then how its working down.But still it feels like weak window motor or is issue with power window switch.Get the voltage tested at switch and motor.Also try another working window motor at not working window side.
==========For more troubleshooting i suggest go through the help links mentioned below:-----
--------------How to Remove Electric Window Motor on Acura Integra?
Laredo ?
These details will help.Thanks.
Nov 27, 2012 | 2007 Nissan Frontier SE Crew Cab
Power windows don't work
For all types of power window problem and power windows not working,i suggest you to go through the help links given below.Click the link to go through its procedure to troubleshoot the problem :------
driver side power window problem?
Driver side power window wont go up?
Power window problem
rear door or window will not open ?
http://technoanswers.blogspot.com/2011/06/rear-door-or-window-will-not-open-on.html
How to remove door panel, door window motor and regulator ?
Power windows not working after car wash?
http://howtobyme.blogspot.com/2011/11/power-windows-not-working-after-car.html
---------power locks, power window and power mirror not working?
All power windows not working?
How to remove window motor and regulator on Car?
-------------Complete Diagnosis & Testing Power Windows?
-----------This will help.Thanks.
Jan 20, 2012 | 2006 Chrysler Sebring
My fan motor quit working.... then it works... and it quits... i pulled the dash and there is no power at the switch for the fan
Thats not how it works. The blower motor has power and the switch GROUNDS the cicuit through the blower resistor (lower speeds) or directly (high speed) Check for power at the blower motor BLACK/LIGHT GREEN is POWER. BROWN/YELLOW is ground. If you have power and ground but the motor doesnt work, then its bad. If you rap on it and it works for a while, its bad. If there is no power at the switch, the motor is bad.
Aug 25, 2011 | 2001 Ford F250 Super Duty Super Cab
My 2002 audi a4 passenger seat stop working . theres no power going to the motor. could it be a fuse???
yep check fuse.if fuse good check to see if power going to switch if yes.sound like seat motor bad or there is a broke wire at switch going to power seat motor or the switch could be faulty.hot wire the power seat motor using jumper wires.if motor works problem in switch or it wires.if motor dont work it is faulty.
Nov 26, 2009 | 1996 Audi A4
Dryers Logo
52 people viewed this question
Top Dryers Experts
