Question about Car Audio & Video
How do I rest the unit if the small reset button isn't doing anything?
I have an error code of "protect" flashing on the screen. I think I have resolved the short, but the rest button doesn't seem to be functioning
    Top Expert:
  • 10,875 Answers
Needs a new reset button,you had a power surge and fried it
Posted on Mar 31, 2015
How dop i reset e54 error of gestetner 2715?
To rest the error code > press the yellow Clear button then enter 1,0,7 then press and hold the red Stop button and hold till the screen changes. Then turn the main power switch OFF then back ON..... If the code comes back, you may have a thermister that is shorting out. Good Luck
Aug 12, 2012 | Gestetner Office Equipment & Supplies
Trinitron XBR Projection - No Picture
When it shuts off. Try doing what's called a self-diagnostic test.
As soon as the television shuts try these steps.
Pressing on the front panel's ?INPUT? and ?MENU? buttons at the same time, and holding for 5 seconds,
activates the Self Diagnostic Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
has occured since the last Initalization.
Please do Note: The front panel buttons must be used, NOT those on the Remote Control.
? The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
? The flashing then pauses for approximately 1/2 second.
? The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
? The Error Code is repeated a total of 5 times.
Example: If the Error Code is ?24?, the LED will flash two times, pause, and then flash four
times.
The Error Code designations indicating a malfunction, or no malfunction, are listed below:
Self Diagnosic Code Description
1 - 2 = no error detected
2 - 1 = X-ray protect (high voltage or beam current)
2 - 2 = Short protect (short protect monitors low voltage supplies)
2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection)
2 - 4 = Vertical protect (usually loss of vertical from the source).
Certainly, I can help you. I would recommend going to the following link and getting the service manual so you can see first hand disassembly instructions and testing procedures. Its only 10.99 and they email it to you shortly after purchase. The manual is a valuable resource as it will have part numbers in case you do need a new KD board. heres the link.
http://servicemanuals.vstore.ca/
Good luck..............
Jul 06, 2008 | Sony KP-65XBR10W 65" Rear Projection...
What is a c0500 error
Sir, Fuser unit is bad. To reset place a paper clip in the small hole on the rightside of the operators panel. The screen will show abort code/please wait NORMAL then the screen will start its normal routine be on the look out for a small dot on the left hand of the screen when you see this press "3" then the screen will show some differtent buttons press Trouble reset machine will do the same thing as it did when you did the paper clip this time dont do anything machine should come up ready to copy if the code persits then a new fuser is required.
Feb 17, 2010 | Konica Minolta DiALTA Di200 Copier
The tv sound works all the time when turned on but occasionally the video either does not come on or goes of while watching it.
It is usually a vertical deflection circuit problem. Here's the basic troubleshooting:
  1. Make sure that no front panel buttons are inadvertently stuck in an "engaged" position.
  2. Press MENU button. If a small horizontal line appears at the center of the screen, you have lost vertical sweep on your TV. The protection circuit shuts down the picture to protect the tubes from burning a line across them. The intermittent problem may indicate a loose solder. Try resoldering the vertical output IC. The IC along with the B+ feed resistor back in the sweep power supply is most probably bad or has a loose solder.
  3. Press the DEVICE and MENU buttons on the front panel simultaneously and hold it for 5 seconds to activate the Error Code Operational Check. The status LED indicator will then flash denoting a two digit code.
  4. Count the number of flashes then pauses for about a half second then flashes again. The first number of flashes indicates the first digit of the error code and the second number of flashes indicates the second digit of the code. For example, if the error code is "24", the LED will flash 2 times, pauses, then flashes 4 times. The error code is repeated a total of 5 times. Error 24 indicates a vertical deflection circuit failure.
Please let me know the code you'll and I'll tell you where the problem lies and how to fix it.
Dec 02, 2009 | Mitsubishi WS-55859 55" Rear Projection...
L cant rest my copier D125if
First check the right side cover where the image unit is located. Check the two latches that latch that door are not broken especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel with go thru some screens when you see the screen with copiers on it on the left side of the screen in the middle you will see a small "." when dot appears touch 3 button. Then the machine will continue to the code screen. Press the utility button should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset you are messing with the Fuser the Hot part continue reset without a technician looking at and or replacing it can catch on fire that would ruin a perfectly good day
Aug 27, 2009 | Minolta DiALTA Di250 All-In-One Laser...
KDC-MP443U - flashes protect
I had the same Prob on my KDC 237. I hit the small reset Button on the front and it fixed it. Hope this helps.
Mar 03, 2009 | Kenwood KDC-135 CD Player
Samsung RM255LASH - flashing error code 98 a8 after power glitch
Just happened to me with a power flash- fixed it by pressing and holding the Freezer and Frig buttons together until the screen flashed and reset. Wheww! Though it was a gonner! Fine now:) Hope it works for you!
Nov 06, 2008 | Samsung RM255LASH Side by Side...
Canon clc 5100 E075 error code
E075 error is a HARD error. Im means, it will not reset by turning the machine OFF and ON. The reason for the error is the Black transfer belt is moved too much in one dirrection, causing a fault. the belt will have to be moved to center by hand, then the E075 cde can be cleared in service mode. (function > f-misc-p> screen 2> E075-rls. then shut off.
its best to get a canon tech involved, because there is most likely other problems.
May 13, 2008 | Office Equipment & Supplies
Mitsubishi VS-50705, 50 inch Rear projection TV won't turn on!
most of the time the convergance ic go bad:
but try this:
The 3 flashes of the led when you plug the unit in is the
microprocessor initializing.
This unit has an error code diagnostics.
On the front panel of the unit press and hold the INPUT and MENU
buttons at the same time and hold them down for about 5 or 6 seconds.
The unit should activate it's error code mode.
The led will flash count the number of flashes. It will then pause for
1/2 or 1 second. The led will flash again count the number of flashes.
The unit will repeate this for about 5 or 6 times.
You now have the two digit error code. The first time the led flashed
is the first number of the error code, the next time the led flashed is
the last number of the error code.
12 ----------- indicates no error
21 ------------- X-Ray Protect circuit
22 ------------ Short Protect circuit
23 ------------- Horizontal Deflection failure
24 ------------- Vertical Deflection failure
Most units give a error code "22" short protect circuit. If so check:
Q5A00
C557
If Q5A00 check bad there are other parts that have to be checked or
replaced.
If you are able to do above call a tech to service the unit
Dec 11, 2007 | Mitsubishi WS-48613 48" Rear Projection...
Car Audio & Video Logo
50 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
