Question about Asko TL751 Electric Dryer
Can I get a list of error messages for an ASKO TL751 clothes dryer?
Error code HI
  • Asko Master
  • 2,963 Answers
I googled: Asko TL751 Electric Dryer Error code HI
You may find a manual in this search that gives you the code
If I had to guess it means the high heat is not working, or the high
temperature protection has opened to protect the dryer from
self distruction.
Your owner's manual should give the error codes.
No manual? manualslib.com may have it. YOu may want it next time anyway.
Posted on Mar 31, 2015
ASKO TL751 error messages ?
Asko dryers as model T760 or T780 indicate failure by error message (like "Overflow", "Sensor", "Thermistor", ...) while the model TL751 indicate failure by error code ("H1", "H2", ...)
Below you can see a list of error codes:
H1 error - Humidity sensor error
H2 error - Drying temperature sensor open/short error
H5 error - Heater overheated (ELECTRIC TYPE)
Heater disconnection check and H4/H6 error (ELECTRIC TYPE)
H3 Error - Flame Detector Open Defect (Gas Type)
H7 Error - Gas Valve Defect or Gas Blocked-off (Gas Type)
H8 Error - Igniter Defect or Flame Detector Short (Gas Type)
Dado
Mar 31, 2015 | Asko TL751 Electric Dryer
What does the Code C3 mean on my Asko Dryer
Here is the list for the DRYER not sure what model... guys please post MODELS!!!!!!!!!!!!!!!!!!!!!
Asko
Dryer
Failure Code Condition Check/Repair
F1 Condensate drain overfilling.
1. Check condensate reservoir pump and drain tube.
F2 Maximum drying time exceeded (3hrs) 1. Check for tripped circuit breaker or blown fuse
2. Check ductwork for lint build-up
3. Check hi-limit and cycling thermostat
4. Check heating element
F3 Thermistor fault 1. Open thermistor, replace
2. Bad wiring to thermistor
F4 Too much lint in the lint filter, front housing, or in the condenser.1. Clean lint from lint filter and/or condenser
F5 Fault in the moisture sensor · Lint covering sensor in front of housing1. Bad sensor
2. Bad wiring to sensor
Sep 26, 2014 | Asko Dryers
We just replaced the heat element still no heat any ideas
Contact asko... did you check the power going to the heating element. Or the control panel. If the unit doesn't know to work it won't I would check everything form the heating unit back
Sep 03, 2014 | Asko TL751 Electric Dryer
Is there a theromostat reset button on an Asko TL751 Electric Dryer
Have you clean the air vent out the one leading to the outside? One time we had one do the same thing because the vet was blocked it heated up to quick and sent the the message that the clothes was dry. I hope this helps
Sep 16, 2012 | Asko TL751 Electric Dryer
Dryer makes a grinding sound when stopping
I would try to listen to where the noise and smoke is coming from and get back. look here for some likely parts
Maybe the front bearing or rear bearing.
Apr 16, 2012 | Asko TL751 Electric Dryer
TL751 is two years old. Heating element burned
You did clean out the dryer before turning it back on?
May 10, 2010 | Asko TL751 Electric Dryer
Where can I get a parts list for an Asko TL751 dryer?
Try this website, I think they may be able to help you.
I hope this helps
http://www.partsselect.com/
Oct 03, 2009 | Asko Dryers
Asko dryer: room temp air, is not heating
first try the reset button .. a black rubber button at the back panel about middle...
Hope it helps if NOT let me know more about your problem... and I will help
Jul 02, 2009 | Asko TL751 Electric Dryer
Asko TL751 Electric Dryer Logo
130 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
