Question about Measuring Tools & Sensors
I want to know the horsepower of my 143-186022 vertical shaft engine.
Is there anything in serial number that tell shaft length?or anything to tell if its long or short shaft
Just Google the make, horsepower and the serial number. There are website that list the models.
You can also Google
make horsepower long shaft short shaft
May 04, 2016 | Boating
What is horsepower and can I determine horsepower from vin number
to get an answer we need to know the make model year, engine size turbo etc because what you have given means nothing
Vin are vehicle serial numbers and that same make of vehicle can have several engine capacities depending on the manufacturers level of car finish( sedan --low hp super sports big engine hp)
Dec 29, 2015 | Cars & Trucks
K300 gas engine. What is output shaft dia and is it keyed?
3/4 Keyed Shaft ' eBay
www.ebay.com/bhp/3-4-keyed-shaft
eBay3/4" Dia. Steel Shaft / Rod 18" Long. ( Keyed 3/16 "both ends ). $34.21 .... 3/4" to 1" inch w/Step Key Gas Engine pulley Crank Shaft Sleeve adapter Predator.
Vertical shaft Kohler Engines - Engine4Less.com
engine4less.com/ALL-Vertical-shaft-Kohler-Engines/
This engine has same mounting and shaft as all KOHLER Single cylinder ... 1"diameter x 3-5/32" length keyed VERTICAL (UP and DOWN ' ) crankshaft. Please ...
Nov 06, 2015 | Kohler Electrical Supplies
205cc = ? hp
I am sorry, but these do not equate. cc (cubic centimeter) is a measure of volume, hp (horsepower) is a measure of power, like watts. There are many factors beyond the cubic centimeter displacement of an engine and the determination of horsepower.
Kevin D
Dec 22, 2014 | Briggs & Stratton Briggs Stratton Intek V...
Is there a conversion chart to cc to horsepower?
No. Cubic centimeter (cc) is a unit of volume. Horsepower is a unit of power. Two different 250 cc engines, for example, may put out different amounts of power, while 250 cc of sand won't put out very much.
Oct 22, 2014 | Briggs & Stratton Briggs Stratton Intek V...
How can i extend blade shaft 2 inches on 4 horsepower motor
you will have to buy a tecuseh engine they make there shafts in differnt sizes
May 26, 2012 | Briggs & Stratton Briggs Stratton...
How to get 1000 hp
> how to get 1000 horsepower
Since the "stock" engine only produces 200 to 400 horsepower, you're looking at a lot of "upgrades" for it to produce 1000 horsepower, such as:
* high-compression pistons
* better ignition system & spark-plugs
* turbo-charging or super-charging
* "racing" cam-shafts
* high-performance exhaust manifolds & headers
Speed costs money -- how fast do you want to go?
May 21, 2011 | Computers & Internet
I am looking for a replacement motor for an craftsman garden tractor model 917.257082 20 horsepower. its has an onan motor now 12 volt
Find the physical specs by googling the engine. once you know the requirements for shaft size and length and mounting holes you can check the other engine manufacturer's site for compatible engines. then go look on ebay for folks selling those engines.
Oct 04, 2010 | Garden
How to change electric starter on vanguard 14 hp v twin vertical shaft.
Please, help me to regulate valves on Vanguard B&S 14HP OHV model:294446 tip:1141-a1. I don't know how. Thenks. My adress kolya-kolyanof@rambler.ru
Mar 31, 2010 | Briggs & Stratton Briggs Stratton Intek V...
How do you time a 20 horsepower intex engine
i believe the ignition timing is not adjustable , if you think you might have a timing issue you need to chech if flywheel keyway is twisted or sheared
Mar 04, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Measuring Tools & Sensors Logo
91 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
