Question about Chevrolet 1965 Chevy Chevelle Malibu SS Z16 1/18 Yellow
Need wiring diagram for wiper motor, My switch knob gets hot
    Top Expert:
  • Chevrolet Master
  • 10,875 Answers
Need wiring diagram for wiper motor, My switch kno - 25618751-gpgzti2ec3hbjv0hrsl1kugs-3-0.png
Posted on Mar 31, 2015
My 2004 lincoln towncar windshield wipers come on by themselves, and will not turn off
Is this your first Lincoln? Our 1989 had "rain sensor" and the wipers would come on with the lights if it deemed the mist/rain was making the windshield damp. Almost all cars today have this build in the computer. Some work with a different circuit other than the wiper mode, to allow the lights to come on, the dimming of the dash lights means the lights are on, and then when they come back to a higher resolution they are off. I am not sure what you are saying about the light switch. So can't help you with that.
Dec 11, 2017 | Lincoln Cars & Trucks
I HAVE A 2000 OLDSMOBILE SILHOUETTE. MY REAR WIND SHIELD WIPER STOPPED WORKING. HOW CAN I FIX IT
First you must pull off the trim panel and expose the mortar and wiring to the motor, then test for power and ground, if present test the motor.
Aug 29, 2017 | Oldsmobile Cars & Trucks
Where is the Windshiled wiper relay in a 2000 chevy silverado 2wd base truck
Check the fuse box under the hood. Typically on driver side behind battery. Top lifts off to expose relays and fuses.
Oct 25, 2017 | Chevrolet Silverado 1500 Cars & Trucks
Troubleshoot wipers
Best if you have a wiring diagram of at least the part of
the curcuit your going to work on (wiper circuit)
That applies to any electrical issue,simply can't start your
checking or testing without a road map.
If it were to guess for you,I would say the motor has failed
Even with a wiring diagram it isn't always easy to jump it
once out of the car,to test it. You won't have the internal
wiring diagram for the motor.
The switch you can turn on & use your volt meter at the
wiper motor with it disconnected,but again need to have the
diagram to probe the correct wires
Dec 08, 2012 | 1991 Ford Escort
Front wipers will not operate. checked fuse and relay look ok. back wiper works
Here are a few other things to check beside the fuse and relay:
Check Wiper Motor - the wiper motor is the driving force of the windshield wiper. Feel the motor and listen to a humming sound. If there is no humming, the motor is the problem. Check if the motor is working properly and see to it that its electrical connections are made properly. If you find that the motor is dead and beyond repair, get it replaced immediately.
Check For Break in Connecting Wires - the connecting wires of the motor sometimes go loose and that may cause the windshield wipers to stop working. Also check the battery plug connection which the motor has. Connecting the loose wires properly or fixing/replacing the plug might solve your problem.
Check Wiper Switch - another wiper assembly part that can malfunction is the wiper switch itself. Check for switch malfunction and if you find that is indeed the problem, get it replaced from a mechanic.
Check for Bent Wiper Arms - bent wiper arms can cause the operation of the wipers to be hampered. If the wiper arms are bent beyond repair, get them replaced immediately.
Nov 25, 2010 | 2003 Isuzu Ascender
2000 dodge caravan wipers dont work. I ran hot wire to wiper motor, it works. I have power at wiper switch, but not sure which wires to check
Heres a wiring diagram, this sounds like it may be a wiper module or a bad body control module, you have checked all your fuses and i assume they are good, heres a diagram to help you .afccff5.gif
Oct 19, 2010 | 1998 Dodge Caravan
Changed wiper motor when it blew the fuse. it worked about a day and now it blows the fuse even with the wiper switch off in need of the wiring diagram for an 87 dodge dakota wiper assembly
YOUR WIPER SWITCH HAS A SHORT OR THE WIRING GOING TO THE WIPER MOTOR HAS A SHORT.CHECK WIRING FOR BREAKS AND OPENS THAT WOULD CAUSE SHORTING.
Oct 05, 2010 | 1987 Dodge Dakota
Rear wiper motor not working
most likely the wiper motor is bad the second wire sould be a ground if you set meter to ohms you sould be able to get a low resistance to any good ground on the vehicle if the hot wire is hot any time key is on the bcm is controling the ground to operate moter and you should have a steady continuity on the ground side with switch on the fast postion an it will read on and off in the intermitant postion if both wires test good motor is bad when you replace motor let it cycle and shut it off before installing the arm on it
May 21, 2009 | 2005 Dodge Caravan
Wiring diagram wiper motor Ford Thunderbird 1995
If the same as on a 93 the wiper motor has two connectors.
Connector A (motor):
wiper switch to motor (high) - dark brown / orange
wiper switch to motor (low) - white
ground - black
Connector B (park switch):
wiper switch to motor (park and return) - red
wiper switch to motor (park return) - black
ground - black
Hope this helps.
May 16, 2009 | 1995 Ford Thunderbird
When i turn off the wiper , they still stand up
Sounds like you have no permanent live to wiper motor.
You need this to make the wipers park when you switch them off.
They are swithed off using a switch inside the motor itself.
To check.. Disconnect plug supplying power to motor one wire should be battery voltage with ignition on and wiper switch off.
If yes....Motor probably shot.
If no... You need a wiring diagram to determine where the permanent feed comes from.
Dec 29, 2008 | 1997 Pontiac Grand Prix
Chevrolet 1965 Chevy Chevelle Malibu SS Z16 1/18 Yellow Logo
160 people viewed this question
Top Chevrolet Toys Experts
gbob59
jeff5may32
Are you a Chevrolet Toy Expert? Answer questions, earn points and help others
