Question about Refrigerators
Freeze will not stop running - blows breaker
It was running constantly, blew breaker, won't start back up once reset. Need to know more about what could be the issue so I don't spend $$ on electrical parts I can' return. Any Help is appreciate. Think it might be defrost timer or thermostat, but don't know how to tell which one is causing the problem. If something else would like to hear your thoughts.
  • 1 more comment
  •  johnny rebel
    johnny rebel Mar 31, 2015
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • Anonymous Mar 31, 2015
    What more information do you need. Frigidaire model MFU14F3GW9. It was in the garage, stopped working - thought it just quit, then realized the GFI was tripped. Never did this before, and it was in the garage for over 10 years. Brought it inside, since I read GFI not good. Once inside, it came on, ran constantly and then after several hours of running it trips the circut. I do see that the plug it is using is connected to another plug that is GFI an it trips,
    Also, when I turn the defrost time it will kick back on, but it trips again.
  • 2,992 Answers
If you have a volt-ohm meter, check the compressor for a short to ground or the compressor shell. My guess is the compressor is burned. Don't bother to repair. Shop for a lightly used replacement.
Posted on Mar 31, 2015
Life Fitness 4000 repeatedly blows outlet circuit breaker
If there was a fuse in the treadmill it certainly wouldn't cause your main circuit breaker to blow. It sounds like the motor burnt out and shorted- which is causing your house circuit breaker to blow. There is a chance that the ball caused some other damage that is creating the short but my bet is on a burnt out motor. You would need to disassemble the unit and test for short circuits to verify.
Mar 04, 2014 | Life Fitness Lifefitness 4000 Treadmill...
Microwave won't start when pressing the start botton
call Chas&son,s appliance repair at 579-379-0993 and they will come out the same day no less okay
Feb 13, 2013 | GE JE2160 Microwave Oven
Feb 13, 2013 | Microwave Ovens
Thanks for taking my question. Model Info: Whirlpool Accubake system electric range Super Capacity 465...... my wife moved the range to clean behind and it sparked at the plug and blew the breaker. ...
try fitting a new plug. if you do cut back the cord back at least 3 inches try it again. before you do check socket with another appliance.let me know if that fixed it or not
Jul 26, 2011 | Microwave Ovens
6hp, 25 gallon compressor, never cycled back on, blew the breaker. reset the breaker and soon as i flip the compressor it trys to start then blows the breaker right away.
sounds like its the motor drawing too much current,has it got plenty or oil cause they run low and seize up,not the most reliable can be fine but equally can be dramas especially if its from China
Oct 26, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Breaker blew and when flipped back on, microwave didn't work
yes there is a 15 amp fuse that needs to be changed in behind the front control panel
Aug 21, 2009 | Whirlpool MH7140XF Microwave Oven
I have a 2002 Toyota Corolla Le and everytime my car is at stop sign my aircondition starts blowing out hot air but, once the car is moving the air starts back blowing cold. Do you know what might cause...
Make sure your fans are running. It sounds like your fans are not working all the time. With the AC on the fans should run constantly. Check fan relays and fuses.
Jun 13, 2009 | 2002 Toyota Corolla
E-Machine T6216 PSU fan runs, computer will not boot
Giving the fact that your fan is constantly running and you had an electrical spike you should take it in to be looked at. If it overheats then the motherboard will go and it will cost more to fix it than to buy a new one.
Don't forget to rate this solution before you log off.
Jan 26, 2009 | Computers & Internet
Fill with water - Stopped in the wash cycle - Blew Breaker
please put unit in a out by its self...recontact if still problem
Dec 15, 2008 | Kenmore 15864/15862 Top Load Washer
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
