Question about ASUS R1E-B1 Tablet PC
No power when plugged in? What did I do? - ASUS R1E-B1 Tablet PC
  • ASUS Master
  • 2,992 Answers
If you have a volt-ohm meter check that you have voltage at the plug to the computer. If no voltage, the power supply is bad or the socket does not have power (circuit breaker) change to a known working 120vac socket. Dobble check your laptop's power supply. If still bad, see if you can barrow one, or take laptop to repair shop and ask them to try their power supply. Then you will know to purchase a replacement.
Posted on Mar 31, 2015
Tip
Power Cable Popping Out on Versus Chinese Tablet
Versus Tablets (sold mostly in the UK and Ireland until 2014) have some great features (like HDMI out and Bluetooth), but power is a problem. They do not charge through the USB port, but through a 3.5mm barrel jack plug (specs are 5v 2000mA).
The power cable on my Versus Android Tablet keeps popping out (and therefore the tablet won't charge). Lately it got so bad that the plug simply wouldn't go in at all. I did a bit of research and came up with a fix.
There's a small plastic ring at the top of the plug. Take a precision pliers and pull the ring off the plug. BE CAREFUL! - If you damage the plug it simply won't go in at all, and your tablet will be useless.
Without this ring the plug stays in and the tablet charges. It still pops out occasionally, but a lot less than it did before.
NB: I do see some replacement power adapters with these plugs available on eBay and Amazon, so you may be able to try out a replacement power supply too.
Versus Tablet
on Feb 01, 2015 | Tablets & eReaders
MY DREAM TAB I LOST THE INSTRCTION ON HOW TO CHARGE BATTERY
Plug the tip of the USB charging cable into the power charger port and plug the other end into the USB Power Adapter. Plug the USB Power Adapter into an electrical outlet. You will know that it is completely charged when the orange light on the charge indicator turns green.
Jul 23, 2015 | Tablets & eReaders
Why is my kitkat not powering on?
if you have a volt ohm meter see if theres voltage at the power adapter plug
if its not charging it cant turn on
Feb 07, 2015 | Tablets & eReaders
Ipad won't turn on. Worked fine last night, got down to about 5% battery left. Plugged in overnight and it won't turn on. Tried different power cables, no success. Tried plugging into PC no luck. ...
You could try a hard reset.
Hold down the power button and the home button at the same time until the device completely shuts down and the Apple logo appears.
Hope that helps!
Sep 24, 2013 | Apple iPad (16 GB) WiFi Tablet PC
My kindle won t turn on
Her is a possible solution:
1. Plug into the original charger, hold the power down for a full 30 seconds, release. Let charge in this state for 12 hours.
2. Lease the device plugged into the charger, while you have the device plugged into power, press the power button for a full 40 seconds, release. Wait for 5 seconds and then press and release the power button. Did the device wake up? No, continue to step 3.
3. Plug the device into another charger, if you do not have an charger from another phone go to Staples or Radio Shack pick up a new Kindle or Universal charger, make sure you can return the charger.
4. Plug the Kindle into the new or alternate charger. Hold down the power button for 30 seconds release. Let charge for 12 full hours.
5. Unplug the Kindle from the charger.
6. Press the power button for 40 seconds - time it. Release the power button, wait for 5 seconds, then press and release the power button. The Kindle should wake up. If not, proceed to step 7.
7. If you can not wake up the Kindle from a 'hard reset' the Contact Amazon directly for a replacement.
May 25, 2013 | Amazon Kindle Fire HD
Netbook turns off instantly when power cord plugged in - even when not plugged into power outlet!
Have you tried a different adaptor or power outlet other than that the dc jack on the notepad may need replaced
May 08, 2013 | Gigabyte Atom Series Netbook: Q2005 -...
Hi when plug in my ac adapter into lenovo x61 the tablet will not turn on i try it on other computer and it will on what happen?
LOL, sounds like your tablet has seen it's better days. See why HP got out of the Tablet business? They are nothing but trouble.
Apr 08, 2012 | Lenovo Tablets & eReaders
Power adpater/battery problem
You need to check with an HP service site about the mixed battery/power adapter problem. You may have a bad battery.
Feb 03, 2010 | Compaq tc4200 Tablet PC
ASUS R1E-B1 Tablet PC Logo
42 people viewed this question
Top ASUS Tablets & eReaders Experts
Alun Cox
Are you an ASUS Tablet and eReader Expert? Answer questions, earn points and help others
