Question about Locks & Locksmithing
How do I remove this doorknob? It has no visible screws, and no tabs or set screws to remove the knob itself.
I have some pictures of the knob, I snapped the cover off of it, and can still not see how to remove it.
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 93 Answers
Look for a pin or slot on the side for an insert to pop the cover hiding the screws.
Posted on Mar 31, 2015
Removing an exterior doorknob with no screws. I can get the lever part off but can't remove the backplate by just prying. Appears to be a tiny "spring" holding it on.
Look for a little divet to pry if not its most likely joined internally try un screwing the actual backplate itself
Sep 02, 2017 | Cars & Trucks
The set screw has fallen out of our doorknob and is lost. What can I use as a replacement?
Just go to the hardware store and get another set screw. They sell them individually in the hardware aisle.
Dec 21, 2014 | Locks & Locksmithing
I have an exterior screwless doorknob that I need to remove. The faceplate on the inside knob that covers the screws is also covering the little pin that removes the knob. Is there another way to remove...
There is the 3rd version of the Kwikset exterior door set. The interior face plate is removed and on each side of the base plate has small slots with a lever on either side that need to be moved to the other end of the slot. The whole interior knob assembly with come off.
Dec 23, 2011 | Kwikset Locks & Locksmithing
How to put the striker from a door knob kit back together
i can help you with that...just follow this steps...
1.Remove the old doorknob by taking out the screws that hold it in. You will have to remove the striker separately by removing the screws that hold the strike plate in place on the outside edge of the door. Slide the striker out.
2.
Take the new doorknob, striker, and strike plate out of the packaging and look for the directions. (Most doorknobs are installed in the same way, but there are always exceptions.)
3.
Slide the striker bar into the hole. Insert the screws into the striker plate and tighten.
4.
ake the two halves of the doorknob, and place the one with the male end through the hole in the striker bar. Place the female side of the doorknob on the other side of the door and make sure that it lines up with the male end. Slide the two together. Screw the knob together using the two long screws that came with the doorknob. Make sure that the screws are tight. Make sure that you have the lock facing the right direction. You want the locking mechanism on the inside of the house or room.
5.
Test your work before you shut the door. Make sure that both sides of the door knob turn and the striker bar goes back and forth.
:p
Dec 01, 2011 | Hardware & Accessories
How to tighten loose Gainsborough passage door knobs?
Hi, W/D here.
I don't know your brand of lock, but I have extensive experience with locksets. My information, then will be somewhat generic, but should get you what you need.
Since you called it a passage lockset, I'm assuming that it an be locked from one side as in a bedroom lock, operated by button that is either pushed or turned to lock the door.
On that side of the lock, there will be two screws, one on either side of the knob. Sometimes the screws are hidden by the trim ring. If that is your case, you'll need to look around the trim ring for a slot that you can insert a screwdriver into to remove the trim ring. If this is your type, the doorknob will have to also come off. This is usually accomplished by another tab on the neck of the doorknob that you have to press in with a screwdriver and pull the knob off once the tab clears the neck. (It sounds harder than it really is). Anyway, take the knob off, pop the trim ring and tighten the screws.
Hope that this has helped, --W/D--
Jan 26, 2011 | Garden
Broken door knob. no access to hinges, screws. Rental property!
Take apart a similar doorknob in your house. Use the stem with knob on it and insert into the square hole in the lock--turn!
Feb 27, 2010 | Hardware & Accessories
Bathroom doorknob stuck in locked position.
I will tell you how to fix 'em. Open the Door Knob with a screw driver, gently pull aart the two knobs once open, then look for a long sliding rod, pull one knob away, twist the Knob untlil it is in unlock position, put them back together to test if it slips properly. If it does not, there is something preventing the rod from rotating freely. Try to ensure it rotates freely. Then screw back together :)
Nov 18, 2009 | Hardware & Accessories
How do I remove the doorknob from a weiser passage set? Want to paint door and remove passage set. Can't seem to find any slot to remove doorknob.
Door knobs have an escutcheon plate (The round part that touches the door ) that covers the screws attaching the knob together.
To get the knob off first look along the shaft of the knob ( The straight part between where you grab the knob and the escutcheon) there should either be a allen head screw or just a metal button. If its a button push in on it while you pull the knob away from the door or if its a screw just unscrew it either way the knob will come off.
Now look at the edge of the escutcheon where it touches the door. On some models there's a little detent or hole where you can put a small flat head screwdriver in to pop the escutcheon loose from the plate. If there is no detent or hole then it may be screwed on. Just grab the escutcheon and turn to the left.
Once you get the escutcheon off you'll be able to see the screws that attach the door hardware together. Just make sure to pay attention to how you took it apart so it goes back the same way.
Hope that helps !
Nov 03, 2009 | Hardware & Accessories
Doorknob sticks in 'lock' position-but no real 'lock' feature
If this is the lock part itself,try gradually loosening install screw enough to be able to manuver lock to work and if so slowly tighten as you test each time gradually. Please clarify problem more if need to.
Mar 12, 2009 | Top Knobs M826 Door Pull
Locks & Locksmithing Logo
720 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
