Question about Coffee Makers & Espresso Machines
Power light come on that is all - Coffee Makers & Espresso Machines
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 76 Answers
They put so many micro chips and other reducers and such either take it to some repair shop, bypass all the electronics or scrap it. If you do any mods to it never leave it alone. My place almost burned down.
Posted on Mar 31, 2015
    Top Expert:
  • Coffee Maker... Master
  • 52,097 Answers
Sorry but we need make and model to even think of looking
When I turn power on my acer aspire netbook the screen is black. The only light that lights up is the battery light. Do you know what is the problem and how can I fix it?
Have you tried turning it on using your adapter? If there is still no power light, try removing the power jack in the laptop and the power cable in the adapter and re-insert it both then plug it then test it again. If there is still no power light, try bending slowly the power jack cable in the laptop while inserted and slowly bend and move until you reach the power adapter. Observe the power light while bending the cable. If the light turns on while bending, the wire/s on the cable might be cut where you bend and see the power light turning on. If there's still no power light, your power adapter or the laptops power supply might be defective.
Sep 25, 2011 | Acer Aspire One Netbook 8.9" Notebook
Thethe tv will not come on and power and theopc is flashing.
Ok This is how to troubleshoot the TV, there are lights on the front and you are mainly concerned with two of these lights (the power light and the OPC light). I) If non of the lights come on then this is a AC Power failure (There is a loose connection or you need to check the Power/Inverter unit or the Main unit) II) If the power light is blinking at a rate of one blink per min and the OPC light is off (then there is a CCFL backlight problem) III) If the power light is blinking at a rate of two times per min and the OPC light blinks at a rate of one time per min (13V/UR10V failure you need to check the Power/inverter board or the main board). IV) If the power light is blinking at a rate or two times per min and the OPC light blinks at a rate of two times per min (3.3V Main Failure check power/inverter board or Main board). V) If the power light is blinking at a rate or two times per min and the OPC light blinks at a rate of three times per min (UR6V failure check power/inverter board or Main board). VI) If the power light is blinking at a rate or two times per min and the OPC light blinks at a rate of Five times per min (Panel 5V failure check LCD control unit or control panel).
Sep 07, 2010 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
My linksys wrt160n wireless router light is blinking
Welcome to FixYa
Indication of Router Lights:
  • Power light blinks. If LAN or WAN cable is plugged in, their respective lights will flash on activity.
  • Power light turns off for several seconds.
  • All lights, except power light, turn on and then off.
  • Power light blinks slowly, then faster, and WLAN light will turn on.
  • Once Power light and WLAN light are on solid, the router is fully rebooted.
A working router should show solid green power light. upgrade the firmware of the router.
If this Helped you-Rate me..Thanks for Using FixYa
Jun 30, 2010 | Linksys WRT160N Wireless Router
3 red lights on
Step 1: Turn on the console, and check the light on your power supplyThe power supply light is located on the black box that is in the middle of your power cord.
Figure 2: The Xbox 360 Power Supply light uparrow.gifBack to the top Step 2: If power supply light is green, try this solution 3frlgreen.jpg
Figure 3: Three flashing lights on the Ring of Light with a green power supply light Solution: Submit a console repair requestYour console is in need of a repair. There are no additional troubleshooting steps. To begin the online repair process, click one of the following links: Step 3: If the power supply light is red, is orange when the console is powered on, or is not lit, try these solutions 3frlpower.jpg
Figure 4: Three flashing lights on the Ring of Light with a red, orange, or unlit power supply light Solution 1: Unplug your console, plug it into a different outlet in a different room, and then turn it onThis will help determine whether the problem is with your power supply, your power outlet, or your console. Solution 2: Request a replacement power supplyIf the power supply light is still red, orange, or not lit, the problem is with your power supply. Contact Xbox Support to obtain a replacement power supply. Contact Xbox Support
(source: www.microsoft.com)Kind Regards
Mar 23, 2010 | Microsoft Xbox 360 Console
Tree lights in red
Figure 3: Three flashing lights on the Ring of Light with a green power supply light Solution: Submit a console repair requestYour console is in need of a repair. There are no additional troubleshooting steps. To begin the online repair process, click one of the following links: Step 3: If the power supply light is red, is orange when the console is powered on, or is not lit, try these solutionsuparrow.gifBack to the top 3frlpower.jpg
Figure 4: Three flashing lights on the Ring of Light with a red, orange, or unlit power supply light Solution 1: Unplug your console, plug it into a different outlet in a different room, and then turn it onThis will help determine whether the problem is with your power supply, your power outlet, or your console. Solution 2: Request a replacement power supplyIf the power supply light is still red, orange, or not lit, the problem is with your power supply. Contact Xbox Support to obtain a replacement power supply. Contact Xbox Support(source: www.microsoft.com)Regards
Both lights are blinking and will not print
they call that flash codes or error codes. please count
count how many times the lights flash, here is what they mean
Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
Sep 20, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Power light on& status light on
The power red led indicates that your device is "power on" , but the status led still red and turn to green if the device ( video input )received video signal ( from DVD player, Laptop etc. ) .
Apr 29, 2009 | Computers & Internet
Solid orange light on motherboard when power light is plugged in
the light on the motherboard indicates power to the board, so it's completely normal. that might be the same for the power button light.
Nov 15, 2008 | Computers & Internet
Coffee Makers & Espresso Machines Logo
42 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
