Question about Sewing Machines
H How do i adjust the tension on my Model# 3116
It may be old ,But it works like a charm
    Top Expert:
  • Sewing Machines Master
  • 43,095 Answers
If I saw a make and model we might find out .
Posted on Mar 31, 2015
Tension is messed up on my 96ksv7
Keep adjusting the tensions top and bottom until you get it right
Oct 27, 2013 | Singer 3116 Simple
Bernina 830 tension belt old how do i adjust the belt tension so it does not slip
Remove the end cover.
The tension mechanism will be visible. Loosen the screw, apply some tension, retighten the screw. Quite easy to do,
Oct 21, 2013 | Singer 3116 Simple
15 different types of thread - polyester, rayon, cottons all sew about 3-4 stitches and then break. i have used this 3116 for 3 yrs - 700 18" blankets - i recently ran out of "yardsale " thread and started...
I would suggest having the sewing machine checked to see if there is a adjustment needed in the timing. and also to see if the tension dial has any problems.
it could be the needle and thread are not compatable with the fabric
is the needle in the needle holder correctly?
are there any burrs in the needle plate or in the bobbin area?
Aug 09, 2013 | Singer 3116 Simple
My Singer 3116 Simple is tangling up by the bobbin and leaving knots of thread on the underside of material?
Thread it right...with the lever up. Then adjust your top tension.
If you still have problems check the bobbin carrier/shuttle for burrs. If you find burrs carefully sand with fine grit sand paper.
Sep 19, 2012 | Singer 3116 Simple
Singer 3116 tension problem
since the tension is the same no matter where the dial is set, the machine may need a new tension dial.
Go to the singer website
Click on customer support--there will be a drop down menu
Choose instruction manual
In the box type the model number--(example 3116)
Click search
Mar 25, 2012 | Singer 3116 Simple
I have a singer simple 3116 sewing machine and it stitches loose upper threads. I?ve tried adjusting the tension, re threading, flipping the bobbin around, and even different fabric. But nothing seems to...
Insert a new needle, (flat side facing rear of machine), now totally rethread. Try this, with presser foot up, pull top thread, it should pull smoothly, now lower presser foot, the thread should barely move. This should seat the thread in the tension discs. If that doesn't work, call Singer at 1-800-4singer.
Dec 27, 2010 | Singer 3116 Simple
Seat the bobbin & adjust tension on Singer 9018
basic tension instructions apply...bottom tension should be moderate, thread should pass when holding thread and dangle the case. Top tension should pull bottom thread JUST to the top side of fabric. thread bobbin case counter clockwise.
May 31, 2010 | Singer 3116 Simple
Thread bunches up under fabric
Your thread tension needs adjustment.
Most likely it is the lower thread tension (not the upper thread tensioner).
When sewing very thin or very heavy material - it is required to adjust the lower tension as well.
To regulate the lower thread tension - turn the small screw on the tension spring of the bobbin case with a small screwdriver.
To increase tension - turn it clockwise SLIGHTLY.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 30, 2009 | Singer 3116 Simple
Sewing Machines Logo
26 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
