Question about Garden
How do I fix a Speedy Green 1000 rotary spreader with no tension on the selector dial/lever. I think I broke a spring or whatever that provided tension.
I was going to open the dial to 2/3 to spread pelletized lime, when it gave way to no tension. I didn't see a spring or retainer.
5 Suggested Answers
SOURCE: need spreader settings for Scotts Speedy Green 3000
I found this:
For 18-24-12 %50 PPSCU
Product Application Rate:
*LBS PER 1000 SQFT 4
Coverage:
* 12000
Craftsman 3
Craftsman Drop 7
Cyclone 4.25
Earthway 14.25
Lely 4.5
LESCO HD-1 7
LESCO R-94 7.5
LESCO Rotary (80# & 100#) 15
Ortho 3
Precision 6
Red devil 6
Republic 3
Scott's Accu Green 7.25
Scott's Easy Green 26.25
Scott's R7- X F.5
Scott's R8-A J.5
Scott's Speedy Green 1000 6
Scott's Speedy Green 2000 7
Scott's Speedy Green 3000 6
Spyker 4.5
True Temper 1500 \ 5000 5.5
Vicon 28
Posted on Oct 24, 2010
  • 25 Answers
SOURCE: scott speedy green 1000 spreader The spring at
The spring on the Speedy Green 1000 is more of a plastic bow piece. The accordion shaped piece should run through the "bridge" that is riveted to the hopper and then the bow piece fits into it. It is possible that the plastic bow may have worn out and may need to be replaced. You should give Scotts a call @ 1-800-543-8873 and see if we have a replacement available for you.
Posted on Feb 25, 2011
  • 25 Answers
SOURCE: I have a speedy green
listed below are the SpeedyGreen 2000 suggested spreader settings for lime:
(Please note that these are not exact measurements but they are close enough for lime applications)
30# per 1000 sq. ft. - Setting of 10
40# per 1000 sq. ft. - Setting of 7.5, go over the area twice
50# per 1000 sq. ft. - Setting of 7, go over the area three times
Posted on Mar 07, 2011
jklhbertg32013
SOURCE: Speedy Green Parts
Replacement parts for your model can be found at amazon, click here and take a look: Amazon com scotts lawn parts. I hope this was helpful. Cheers
Posted on Dec 16, 2014
I have a speedy green 1000 and the drop chute will not close is there a repair kit for this machine?
Phil, Check the attached links,instruction and guides contact Scotts if you have to. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Help Center Contact Lawn and Grass Experts Scotts
Scotts Speedygreen 1000 law spreader spring repair
Replacing Rusted Axle on Scotts Speedy Green Spreader
scotts speedy green 1000 parts diagram Google Search
Apr 15, 2015 | Scotts Company Scotts& Accugreeen 2000...
Need a setting for Scott's Speedy Green EdgeGuard mini
First, I went to the products website, in this case Lesco and looked up the spreader settings:
https://www.johndeerelandscapes.com/home/spreader-settings.aspx
Then, I went to Scotts website and looked up spreader settings:
http://www.scotts.com/smg/node2/SCOTTSCOM/lawn-care/lookup-spreader-settings/7800015-24900013-s
I cross referenced a product on the Scotts website that uses the same settings as one of those listed on the Lesco website and I found my settings that way.
In my case I was using Lesco Pre-M 0.86% 0-0-7 and wanted to apply 5.3 lbs/1000ft. My spreader was a Scotts Turf Builder EdgeGuard Mini with settings from 0-15. I found out by cross referencing that the Scotts Speedy Green 1000 and my spreader used the same settings. So I ended up using the recommended setting of 5.5, as listed on the Lesco website for the Scotts Speedy Green 1000, to apply 5.3 lbs/1000ft of pre emergent using my Scotts EdgeGuard Mini.
Hope this helps!
Mar 30, 2013 | Scotts Company Garden
The little door on the hopper of my Scotts Speedy Green 1000 spreader does not close when I release the contol handle. Is there a spring that has come off and can a replacement part be purchased? Dennis
Hi Dennis. I don't think there are any after market parts for Scotts spreaders. I do recall a wire and a spring on one type of Scotts spreader. There was an eyelet hole just off center that the wire and spring attached to. You could probably rig something up pretty easy. Would be a matter of locating a spring and wire.
Before you get to deep into this... flip it over and look for dried / caked fertilizer on next to thehinge area. I have seen this stop spreader application doors from closing often.
You can ask Scotts here:
http://www.scotts.com/smg/helpcenter/helpCenter.jsp
Kelly
Apr 26, 2011 | Scotts Company Garden
Spring on speedy green scotts 1000 is missing...where can i buy a spring? part #? price? i am in zip code 66207 area
We would be happy to send you a new return spring! Call us at 800-543-8873, and we will order it for you! Stacey@scotts
Apr 18, 2011 | Scotts Company Garden
Scott speedy green 1000 spreader The spring at the bottom fell off. How do I put it back?
Feb 24, 2011 | Scotts Company Garden
I have an older rotary scotts pro turf spreader and dont know what setting to put it on for fertilizer because the settings are letters not numbers how do i know what setting to put it on?
try this:
After doing a search I found this:
From Lesco website
Coverage:
* 12000
Craftsman 3
Craftsman Drop 7
Cyclone 4.25
Earthway 14.25
Lely 4.5
LESCO HD-1 7
LESCO R-94 7.5
Ortho 3
Precision 6
Red devil 6
Republic 3
Scott's R7- X F.5
Scott's R8-A J.5
Spyker 4.5
Vicon 28
_________________________
I was married by a judge. I should have asked for a jury.
-- Groucho Marx
Oct 20, 2010 | Scotts Company Garden
Have scotts speedy green 1000 spreder, there is a spring that nkeeps hopper open. SPRING IS GONE AND DO NOT KNOW HOW TO REPLACE?
I am sorry to hear about the problem with your spreader. There is a chance that we have replacement parts available to ship. Please give Scotts a call @ 1-800-543-8873 at your earliest convenience to see what we can do to assist you.
May 26, 2010 | Scotts Company Garden
Speedy Green Parts
Mar 18, 2010 | Scotts Lawn 73740 SPDY GREEN 3000 B/C S 3...
Need spreader settings for Scotts Speedy Green 3000
I found this:
Coverage:
* 12000
Craftsman 3
Craftsman Drop 7
Cyclone 4.25
Earthway 14.25
Lely 4.5
LESCO HD-1 7
LESCO R-94 7.5
Ortho 3
Precision 6
Red devil 6
Republic 3
Scott's R7- X F.5
Scott's R8-A J.5
Spyker 4.5
Vicon 28
Jul 21, 2009 | Scotts Company Garden
Garden Logo
346 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
