Question about Cameras
Ex SD card can not load - Cameras
    Top Expert:
  • Cameras Master
  • 10,875 Answers
Try different card
Posted on Mar 30, 2015
How to put photos onto SD cards
In Windows, click on Start/Computer. A window opens showing all the drives connected to the computer. Under "removable drives" locate the SD card. Hover your mouse pointer over the SD card icon and it should tell you how much free space is on the card. If necessary, delete some photos or other data to make more space available so you can add the photos you want. If there's already plenty of space, try formatting the SD card in either ex-FAT or NTFS format. Then try copying the photos again. If the SD card does NOT in appear in removeable drives then the SD card may be faulty. Try a different SD card.
Nov 04, 2014 | Philips 6.5-Inch Digital Photo Frame...
Why won't Kingston SDHC 4 gb card work in Casio EX Z57 camera
The EX-Z57 is designed to work with SD cards, not SDHC cards. While an SDHC card will fit into the slot, it is electronically incompatible and will not work. You need to use SD cards 2GB and smaller.
Oct 06, 2010 | Casio Exilim EX-Z57 Digital Camera
How much of memory it supports. Not detecting 4gb microsd when used with adapter.
The EX-P600 is designed to work with SD cards (and microSD cards via an SD adapter). Your 4GB card is actually a microSDHC card and is not compatible with SD devices. You need to go with SD cards (micro or otherwise) 2GB and smaller.
Sep 17, 2010 | Casio Exilim Pro EX-P600 Digital Camera
Installed camera back in August, need to download photos, but it says the language is different?? Camera is a ex-z100, I have had no problems before.
I don't know about your software problem, but there is an alternate way to down load most cameras that use SD memory cards. Several stores carry card readers that output to USB connectors. Just remove your SD card , install it in the card reader and plug the card reader into the USB connector on your computer. Your computer should recognize it as just another input,
and you can copy the JPEG picutre to your computer.
Dec 27, 2009 | Casio Exilim EX-Z100 Digital Camera
Casio exilim ex-80 always shows SD card as locked
the SD card should have a small switch on the upper left side it slides from lock to unlock if this doesnt work Look in the card slot - there may be a small bit of plastic sticking out over where the card's locking switch would fit when the card's inserted.
Oct 25, 2009 | Casio Exilim Zoom EX-Z80 Digital Camera
SD card not working on EX-Z1 Exilim cammera?
Are you sure you have an SD card, 2GB or smaller? The S600 will not work with the higher-capacity SDHC cards.
Jul 03, 2009 | Casio Exilim EX-S600 Digital Camera
Memory cards for ex-z60
HI! FROM ALL MY RESEARCH FROM VARIOUS CASIO SITES, I HAVE FOUND THAT THE EX-Z60 CAN NOT USE THE NEW SDHC CARD. SORRY, BUT THE EX-Z60 CAN ONLY USE MMC OR SD CARDS. THE EX-Z60 BK &SR MODELS CAN USE THE SDHC CARDS. THERE ARE MANY 2GB SD ULTIMATE CARDS THAT HAVE FAST READ TIMES THAT MIGHT HELP. IF YOU NEED MORE HELP, REPLY TO ARCLIGHT1217. IF THIS HAS BEEN HELPFUL,PLEASE RATE! THANKS!
Nov 30, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Casio Exilim ex-s600
Why don't you just transfer them onto your memory card? If your computer has an SD slot that would work. In your play mode you would just press menu and then copy to card. Otherwise you are going to have to wait until you get back to your dock with your camera.
Jul 20, 2008 | Casio Exilim EX-S600 Digital Camera
System error 0e01
Maximale Kapazität von SD-Speicherkarten bei Verwendung mit CASIO Digitalkameras Error 0e01: It has to do with the maximum save capacity of the used SD-Cards (max. 1GB for following models). You can format the card (somehow, maybe with docking station), then it would only have 1GB capacity...
...found on Casio Homepage...
Bitte beachten Sie, dass die folgenden CASIO Digitalkameras die Verwendung von SD-Speicherkarten mit Kapazitäten von mehr als 1 GB nicht unterstützen. Bitte berücksichtigen Sie dies beim Kauf von SD-Speicherkarten für diese Kameramodelle.
CASIO kann nicht für die ordnungsgemäße Funktion von SD-Speicherkarten in den Kameras garantieren, auch wenn die Kapazität der Speicherkarte 1 GB nicht überschreitet.
Für welche Modelle ist dies gültig?
  • QV-R3
  • QV-R4
  • QV-R40
  • QV-R41
  • QV-R51
  • QV-R52
  • QV-R61
  • QV-R62
  • EX-S1
  • EX-S2
  • EX-S3
  • EX-S20
  • EX-S20U
  • EX-S100
  • EX-M1
  • EX-M2
  • EX-M20
  • EX-M20U
  • EX-Z3
  • EX-Z4
  • EX-Z4U
  • EX-Z30
  • EX-Z40
  • EX-Z50
  • EX-Z55
  • EX-P600
  • EX-P700
Welche Probleme können auftreten?
  • Die Fehlermeldung "CARD ERROR" wird auf dem Bildschirm angezeigt. Die Aufnahme von Bildern ist nicht möglich.
  • Wird die Speicherkarte in der Kamera formatiert, reduziert sich die Speicherkapazität auf ca. 1 GB.
Jun 08, 2008 | Casio Exilim EX-Z40 Digital Camera
Cameras Logo
27 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
