Question about Kenmore Elite HE5t Washer
How do I reset after cleaning pump?
Took out clothes, ran rinse & spin, ran cleaning cycle, put wet clothes back in. Near end of cycle F21 came up again
  • 21 Answers
SOURCE: wet clothes at end of spin cycle
sounds like your transmission is not working properly. check your warranty information. (should be in your owners manual) many of the whirlpool made top loaders came with a 5 year warranty on the transmission/gear case
Posted on Dec 29, 2008
hiltonjug
  • 612 Answers
SOURCE: Wet Clothes and some sandy crud left at spin cycle end
Make sure you plugged the wires back in that you unplugged to take the case off. The plug located under the panel. This is you lid switch and if it's unplugged it will not spin clothes out. If it is plugged in, you might want to go back and take the pump off. Once you have, check inside the drain tube that connects from the pump to the tub. Make sure there is nothing inside it. Sometimes lint will build up inside it, clogging it.
Please rate solution
Posted on Oct 02, 2009
jsrock516
  • 5911 Answers
SOURCE: I get an F21 Error I stop the washer reset and do
No...you need to check your DRAIN PUMP.
"F21" is a Long Drain error code. This may be an indication that you have an obstruction somewhere in the drainage system. Most commonly, this means there is something lodged in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
http://www.fixya.com/support/r3608588-f21_error_code
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris and small articles of clothing such as socks or under garments can commonly clog in this area as well causing the drain cycle to fail.
NOTE: The "SUD" error code can often occur in conjunction with the "F21" error code. This is due to air being detected in the drainage system, which can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error should go away.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced. If the pump requires replacement, the following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
Posted on Jan 21, 2010
washdryman
  • 154 Answers
SOURCE: The problem is that my clothes are coming out wet
pump is not pumping out the water fast enough you may have trash and lint clogging the proper flow in your water pump
Posted on Feb 07, 2010
blueextc3221
  • 15935 Answers
SOURCE: I got a SUD code,
The "SUDS" error can be caused by too much detergent, improper detergent, drain pump/drain line problem, or pressure switch malfunction.
1. If you are not using HE detergent, you need to be. These washers are designed to use HE detergent which is formulated for wash tubs that use 5 to 7 gallons of water. If you use regular detergent, you are, in affect, placing a higher concentration of detergent in the washer that is normally formulated for wash tubs that have a 35 gallon capacity. The manufacturer should have a disclaimer in the owner's manual explaining this. In most cases this will also void your warranty. NOTE: Prolonged use of the wrong detergent can damage the drain pump components and or wash tub seals.
If you are using the correct detergent, double check the label to make sure it is not double (2X) or triple (3X) concentrated. You could still be placing too much soap in your wash.
To get rid of excessive detergent, place the washer on a RINSE & SPIN cycle, then run it through a normal wash cycle with NO detergent added. You may have to repeat these steps depending on the amount of detergent used.
2. If you do not have a detergent issue, double check the drain pump and drain lines to ensure they are not obstructed in any way. Click on the following link for step-by-step instructions:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
Obstructions in the drain pump and/or drain lines can attribute to air getting trapped in the drain pump and cause the error code. Double check all electrical connections to the drain pump and Central Control Unit (CCU). You will need to remove the top panel of the washer to access the CCU. This is accomplished by removing the three screws in the back of the washer that hold the top panel in place. With the screws removed, slide the panel back, then off. The CCU is located directly behind the wash tub in the center of the washer. The Drain Pump connector will be the 6th connector (facing from the front L to R) in the center of the CCU.
3. Check the Pressure Switch to ensure it is good. The Pressure Switch is located to the right of the CCU as you are looking from the front. It is a small cylindrical shaped device with a connector plug and an air hose attached. The switch can be checked at several water levels by removing the plug and taking resistance readings at the connector pins. Readings are as follows:
(Pins are numbered R to L facing the from the REAR)
Pins 1 to 2 (SUDS Detect) – 0 ohms
Pins 3 to 4 (Overflow) – 0 ohms
Pins 4 to 5 (L1) – 0 ohms
Pins 4 to 6 (Empty) – 0 ohms
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
My clothes are still to wet after spin cycle..GE WKSE5260E. What is causing this?
you may have a pump not working correctly or the spin cycle is not coming up to proper speed or a control board failing .
1st off lets look at the unit after you have ran a load are the clothes still wet or damp ?
so lets check the water with out a load of clothes in it and lets see what happens when it goes to a drain cycle and i think your machine should have a rinse and drain cycle ? does it pump the water out quickly . im betting it does not at the bottom there is a access panel for service behind this door you will find a pump with a clean out filter after making sure you have as much water out of the unit and before you take the filter out of the pump . be sure to have some towels and a bucket as there will be water that will come out of the outer tub and it will end up on your floor . after you have gotten this far check the filter and see what may be in it pens coins socks lots of things end up there when pockets do not get cleaned out .and a pump could also be failing .
if you still have the problem you may want to consider calling your local servicer to take care of the matter
Dec 31, 2014 | Washing Machines
Wme8227b broken?
Possibly blockage in pressure system
Jun 13, 2013 | Washing Machines
Start matsui washing machine
Check the washer drain hose for clogs.
Jun 19, 2017 | Washing Machines
I have a hotpoint wm54 and it is not rinsing or spinning properly, at the end of the cycle the clothes are dripping wet & soapy, however if i manually put on to rinse and spin it seems to work!
You need to check and clean the pump filter.
Remove rear panel od washer, locate and remove large black hose on bottom of drum, remove and clean filter inside the hose.
Nov 15, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Clothes still wet aftre drying cycle over
It sounds as if the wash cycle isn't terminated by pumping the rinse water out and spinning to rid the clothing of most of the water.
Most dryers sense moisture but I think they all will have a maximum run-time to prevent possible fires if the programmer fails to shut them down at the end of the drying cycle.
I would watch the machine and when it started the drying cycle, I would shut it off and check for surplus water that hadn't been pumped out as it should have been.
Feb 03, 2009 | Bosch Logixx WFT 2806 Front Load...
Clothes still wet at end of spin cycle
i would check your belt.the added stress of a full tub longer with water may have done it in.part#wh1x2026 God bless,tom
Jan 10, 2009 | GE WBSR3140DW Top Load Washer
Wet clothes at end of spin cycle
Dec 29, 2008 | Kenmore 22422 Top Load Washer
Kenmore Elite HE5t Washer Logo
80 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
