I have no sound. Everything else seems fine.
All the usual sound settings seem good
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 76 Answers
Mute? is there any other device's? go to menu.
Posted on Mar 31, 2015
The radios charge up good and everything seems to work fine, except I can't change the channel. The channel buttons on both radios are not working on both radios which seems very weird.
They must be locked. To unlock, usually you press and hold a button with a "key" symbol. Model and brand would help a lot to "unlock" the mystery.
If you like this answer, please rate it.
Nov 05, 2015 | Radio Communications
I recently purchased a new 09 GSXR 600. Everything is fine except the clutch lever seems too tight.Tight enough where it causes my hand to cramp after short rides around town. Is this normal? Any...
This sounds like heavy duty springs in the clutch. Just have to get used to it. I suspect this is a cable actuated clutch correct? If it isn't then that does sound a little strange. Usually hydraulic clutch lever action is pretty easy... Good luck HDTV GURU JAY
Mar 26, 2011 | 2008 Suzuki GSX-R 600
I got a set of Logitech S-150 USB digital speakers for Christmas, and the very first time I plugged them in (and every time since) they have been very unbalanced. The right speaker seems to be fine and can...
Logitech are usually good speakers, I have had them for a long time and would suggest that there is a problem with the speaker in question. My advice would be to return them for a replacement
Dec 29, 2010 | Logitech S150 2 Speakers
I have an Ambassador radiogram, everything seems to be working but there is no sound, I do not know if it is the radiogram or the speakers. Please Help.
"everything seems to be working but there is no sound"
If everything was working you would have sound.
Troublshooting these sets is hard over the net. Basic troubleshooting involvs, verifying parts are in good order. Testing the speaker. Test the transformer and power supply. In older sets, you may need to replace the filter capcaitors.. If a cap is shorted, you might have already taken out your power transformer.
This is a common mistake people do. They power up an old set to 'test', in the process they burn up hard to find parts.
If all this is over your head, first please see:
http://antiqueradio.org/powerup.htm
I assume you are in the UK? If so, I'd suggest you join this fine group. They can steer you in the right direction.
http://www.vintage-radio.net/forum/index.php
I can probably get your set running, but it's impossible to do over the net.
If you are in the USA, you may join here:
http://antiqueradios.com/forums/
Another fine group of helpful folks there. So, I'd suggest that you do not power up your set again, until some basic checks have been done, and at least the filter capacitors have been replaced.
Often replacing the filters will result in a working set again.
Mar 10, 2010 | La Crosse Technology E. Howard Ambassador...
Computer speakers do not work
Maybe you need to reinstall the driver for your sound card as what ever you installed may have currupted the original sound driver.
I hope this helps.
Have a good day and good luck.
Nov 20, 2009 | IBM ThinkPad T43 Notebook
92 toyota camry automatic le tac went crazy and sudden loss pwr
check you ignition components to see if they are worn or faulty, this is usually the cheapest part that can cause this problem since your tach runs off the ignition.check fuel filter before fuel pump as this could be clogged and also not as expensive as a pump or oxy sensor. a faulty oxy sensor will set a code.
Feb 06, 2009 | 1992 Toyota Camry V6
Screen has gone white
Either your LCD is damaged or the cable connecting it to the rest of the camera is loose. I would suggest taking it to be repaired.
Sep 09, 2008 | Canon PowerShot A540 Digital Camera
Nx7010 mic problem
Did you check the sound settings for the mike?
May 08, 2008 | HP Compaq nx7010 Notebook
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
