Question about Honda 2005 Accord EX
Is the pulley and hub pressed on a 2005 Honda accord ex
    Top Expert:
  • Honda Master
  • 48,512 Answers
That might depend on which one you refer to but we have no idea which that would be .
Posted on Mar 31, 2015
  • Anonymous Mar 31, 2015
    I am trying to remove the pulley and clutch hub on the AC compressor on a 2005 Honda accord.
  • ray gallant Mar 31, 2015
    sad to say but it is pressed together and non repairable
What size power steering return line do I get for a 2005 Honda Accord ex
The return hose is pre-molded to the correct shape and is only available from Honda. They are not expensive. While at the dealer, get Honda power steering fluid and the o-ring for the pump
91345-rda-a01.
Mar 04, 2015 | 2005 Honda Accord
I have a 91 honda accord ex, one of the front lug
If you undid the hub nut and retainer ring with clip it should tap off once brake caliper is removed.
May 15, 2010 | 1991 Honda Accord
92 honda accord ex - No power on D4..
D4 is slipping and not engaging. This means you need a transmission. you're losing a gear
Jul 24, 2009 | 1992 Honda Accord
I need to know how to install a rear wheel bearing hub on a Honda 2000 Accord ex.
its going to be hard to do at home you need a press to press out bearings and press them in
Mar 28, 2009 | 2000 Honda Accord
Repair manual
the honda dealer.  and at ebay on CD
Mar 11, 2009 | 2005 Honda Accord
I cannot get my radio to reset on accord ex 2005. i have the code
I just went thru this with my dealer. As you probably know, to get the correct code, you must have the radio serial number. My Accord EX has the navigation system, so that was the first problem I had to solve. The dealer had a service bulletin to tell me that. The Radio code on a 2005 Accord EX is only 4 digits. His computer showed 5 digits for the code. So he called Honda and the gave him the correct code for my serial number. It had no relationship to the 5 digits obtained from his computer. Nice, huh?
Feb 16, 2009 | 2005 Honda Accord
Honda accord ex 92
Crankshaft pulley (harmonic balancer) removal- disconnect neg battery cable, remove belts, it would be a good idea to soak the bolt w/ penetrating oil overnight, there is a special 'crankshaft pulley holding tool' available to secure the pulley while removing and installing the bolt. Some parts stores loan tools for free if u purchase parts from them, I don't know if this is available, but it would be worth checking out. Attach holding tool and remove bolt securing pulley. Carefully remove pulley from crankshaft, Do NOT pry off. Remove key from crankshaft sprocket,
Install: install key on crankshaft sprocket, slide pulley on, apply clean oil to bolt threads but NOT to washer contact surfaces, secure crankshaft w/ holding tool, tighten to 159 ft lbs (91-93 Accord), install belts, re-attach neg cable.
Nov 11, 2008 | 1992 Honda Accord
Honda 2005 Accord EX Logo
Top Honda GPS Experts
Will Halftowaite
Are you a Honda GPS Expert? Answer questions, earn points and help others
