Question about FreeMotion 775 Treadmill
Just got it and it will not power on. There is a red light on the circuit board inside of motor housing
    Top Expert:
  • 10,875 Answers
Http://www.sportsmith.net/images/product_support%5CFreeMotion%20Fitness%5Ctreadmills%5Cfmtl8505p2_freemotion_treadmill_owners_manual.pdf
Just got it and it will not power on. There is a r - 25618641-gpgzti2ec3hbjv0hrsl1kugs-3-0.png
25618641-gpgzti2ec3hbjv0hrsl1kugs-3-2.png Just got it and it will not power on. There is a r - 25618641-gpgzti2ec3hbjv0hrsl1kugs-3-5.pngt/uploads/images/25618641-gpgzti2ec3hbjv0hrsl1kugs-3-5.png" alt="2561864Just got it and it will not power on. There is a r - 25618641-gpgzti2ec3hbjv0hrsl1kugs-3-9.png="h_mi" />
Posted on Mar 30, 2015
FAN NOT BLOWING ON INSIDE UNIT, CARRIER FX4CN042T00AAAA LAST TIME IT WAS SOMETHING ON A CONTROL BOAQRD THAT HAD A RED LIGHT ON IT, QUESTION WHERE IS THAT LOCATED?
If your outdoor unit has a control board/circuit board, it will located at the outdoor units electrical panel where the line voltage electrical whip goes into the unit. Should be 2 screws that hold the panel/cover on. Turn off power, remove panel, and board should be visible.
Mar 30, 2017 | Carrier Heating & Cooling
I have zanussi ZWH 6140 P WATER WONT DRAIN ERROR CODE 5 FLASHING RED LED LIGHTS?
First, always check carbon brushes on main motor especially if the appliance is in use for several years.
Five times the red alarm means a problem with the engine washing.
So, could be:
E51 - Motor power triac short-circuited.
Current leakage from motor or from wiring; Main PCB faulty
E52 - No signal from motor tachometric generator.
Wiring faulty; Motor faulty; Main circuit board faulty.
E53 - Motor triac sensing circuit faulty (wrong input voltage to
microprocessor). Main circuit board faulty.
E54 - Motor relay contacts sticking (high voltage level when
the relay switches to OFF).
Current leakage from motor or from wiring; Main PCB faulty;
Rapid reading last alarms:
Press the START/PAUSE button and the nearest option button simultaneously (4 and 6) for at least 2 seconds: the LEDs initially switch off, and then display the flashing sequence indicating the last alarm.
zwh 6140 p-dd5v0vxzvbk4xzho0hm3qdol-4-0.jpgDado
Mar 01, 2017 | Zanussi Washing Machines
TREADMILL wont run when turned on, could it be the motor, or a fuse?
If you wish to get more details; check the sites linked here. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
cj6
Jul 05, 2015 | Reebok Exercise & Fitness
Frigidaire furnace
is red light on a circuit board? if so that is a error code. look for error code diagnostics on the inside of door(s). tell me what furnace does. first draft motor (small motor) comes on. then you should hear clicking noise and see sparks. or see a glow from front of burners this is the hot surface ignighter. then gas comes on and burners light. tell me what you find. i suggest you turn power off then back on and give it time to start process listed above incase its in lock out mode. tell me what happens.
Jan 24, 2014 | Heating & Cooling
House fuse blew last night
Plastic lead inside front of soap dispenser unlocks door.
Remove front panel, undo top panel & lift up, check wax motor (red / brown unit above / top of door), usually burnt out taking control board with it. If you are going to repair fit 5 amp fuse in line with wax motor or fit later model door lock mechanism.
Dec 08, 2013 | Maytag Neptune MAH5500B Front Load Washer
I have the toshiba 23hlv85 and it will not power up, red light on when plugged in, maybe the power source???
Hello Corey hi, Its not the power source but the power supply circuit board on your TV. this is where the red light is connected. this simply means that there is an overload/short circuit somewhere inside your TV. this overload prevents the power supply board to turn on for protection. To find the overload in your TV, needs the services of a technician. Usually they swap boards and isolate where the problem is. I suggest you inquire about your problem to your dealer. see if they have after-market service.
Oct 20, 2010 | Toshiba 23HLV85 Television
On my kenmore central vac no power unplug unit plug it back green light comes on but try turning vac on green light goes off again .
Please clarify that we are talking about the central vac LED/switch panel panel and plugging it into a 110 V wall receptacle.
If I understand when you unplug from the power source ,then plug back in the green LED comes on, looking normal ? But when you manually activate the switch on the motor housing of the vac itself the vac does not start and the LED goes out, so no green or red LED at that point?
If this is the case , Kenmore CV's built approx 5 years ago (MADE by EUREKA) and prior had a circuit board with attached cord (as opposed to detachable) which was prone to relay failure. There were several symptoms, most common was that the relay on that switch panel /circuit board would fuse on and the vac would continue to run when the hose was detached from the wall.However some I worked on from that era had exactly the same symptom you describe. If your unit is between 5 and 10 years old and this sounds accurate, you can unscrew this curved side panel relay with one philips screw. Inside on the PCB will be an L shaped black or white 24volt relay, generally rated at 10 amps. The replacement board or relay will be rated at least 24V/ 15 amps or more. If you can isolate your motor and test it separtely with a power cord or meter , the realy/board will be the only control componnet left.
If you have a small tipped soldering IRON, not a gun, you can generally find a replacement relay to rebuild the board for about $6 at an electronics parts store. Otherwise you will need to replace the control board itself, anywhere form $45 to $70 plus service call if you have a tech come out to the house, and the tech will just unscrew , detach wires and replace the board, no repair , approx 15 minutes work. This will likely cost over $100.
Please post back with your results
Oct 24, 2009 | Easy Flo EF1400 Central System Vacuum
Toshiba TV model CZ27V51 - picture+audio off, red light flashing
hi there, Flashing light red means a shorted electronic component is need to be replaced. do some test at video section, most of it are diode, transistors, transformers. ty
Jan 27, 2008 | Televison & Video
Washing machine won't turn on
For the F&P machine.
Check the circuit board fuse. I had my machine do exactly the same thing. Just wouldn't power up at all, no lights, nothing.
The fuse is on the circuit board a small round red unit, with T1.6A250V written on the top.
Remove the 2 screws securing the control panel. Inside there is a grey plastic box. This houses your circuit board. You will need to have a multi meter and a soldering iron to replace this component.
May 22, 2006 | Fisher and Paykel (IWL12)
FreeMotion 775 Treadmill Logo
704 people viewed this question
Top FreeMotion Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a FreeMotion Kitchen Appliances - Other Expert? Answer questions, earn points and help others
