Keyocera km 2560 poor quality copy but good quality report print
    Master:
  • 553 Answers
Dear clean the platen glass and its cover. adjust the sharpness.darkness.image quality to text and photo.
your printer is in good condition.
thanks.
Posted on Mar 31, 2015
SOURCE: print poor copy quality
Fuser pressure (2 green levers on fusing section) may be set to envelope position.
Posted on Mar 05, 2008
jackboy
  • 2985 Answers
SOURCE: Printing is poor quality with
What printer- what Computer all information is required
Posted on Jun 17, 2008
  • 71 Answers
SOURCE: MP610 with poor photo printing, colors off, low quality
Adjust the driver settings and you will have success.
Posted on Jul 08, 2009
efs_perpends
  • 1996 Answers
SOURCE: Print Quality Poor - HP Photosmart 2575 All-in-One
You can download the manual from Software & Downloads here.
Then work through this article and see here to diagnose the printing problem. Make sure the print quality is set for photos in the print preferences or properties.
You might try cleaning the cartridge contacts as described here.
Make sure you are using a good quality paper, that it is feeding correctly,
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 30, 2009
Josue Pongco
  • 154 Answers
SOURCE: printing quality poor
Try this one, Turn on the printer, Take out the inks, remove the
printhead, put back the printhead make sure it will snap and you hear a
click, put the inks back, wait for the printer to initialize, Press the
Menu button, look for Calibrate printer, then print calibration page,
then scan it after. Load a regular paper. Then try to print a demo page
If
same problem persist call this no for further assistance 1800 421 6699 Thanks
Posted on Aug 15, 2009
When i print the quality is poor and is show some lining
you are using a laser jet or are making photo copies. if laser jet you need a new cart rage if photo copies the copy scanner has dust trapped in it
Apr 12, 2015 | Office Equipment & Supplies
Bad copy quality, prints are good
Could be a faulty optical sensor or crud on the glass?
Jul 24, 2014 | Brother MFC-9840CDW Laser Printer
Very dark background on copies Bizhub 420
Do prints turn out ok how about the meter read report is that ok? setting are offer in the user mode
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 11, 2012 | Minolta Office Equipment & Supplies
HOW TO GET PAGE COUNTER IN KM-1510
Just hold down the stop/clear button for 3 seconds..
It will flash F24 then 3 increments then 3 more.. eg; F24>063>123
It means you have done 063123 copies/prints..
Sep 18, 2009 | Kyocera KM-1510 Copier
I NEED ASSITANCE
what's the problem of your machine?
Jun 20, 2009 | Kyocera KM-1505 Copier
Prints photos with yellow horizontal stripes.Hv downloaded HP printing diagnostic utility and no errors were reported. If just using scanner to copy photos, prints fine but copying photos in library p
go into the printer and do a test print. start>printer & faxes>right click on the printer in question>properties>printer preference button> test print ... try the printer's own test print. This is usually caused by a poor print head, low ink, poor cartridge or the need for calibration. Look in the maintenance tab in the printer properties for head cleaner, jet cleaner etc. This also happens with refill ink cartridges.
Apr 28, 2009 | Office Equipment & Supplies
Black Horizontal lines
hi!
Horizontal white lines usually indicate the ink cartridge is running out of ink or has some clogged ink nozzles. Try the following steps:
  1. Some of the ink cartridge ink nozzles may be clogged with dry ink. Use the ink cartridge cleaning service to try to clear them. Follow the steps below:
    1. check if there is plain white paper in the Input tray.
    2. Press Setup .
    3. Press < or >to select Tools and then press OK .
    4. Press < or > to select Clean Print Cartridge and then press OK . The unit prints a test page.
    5. Examine the test page. If the print quality of the page is good, stop here. If the print quality appears to be getting better, run the Clean Print Cartridge utility again
  2. If the self test appears better, Increase the copy quality setting (Normal or Best) and try copying again. If the quality is still poor, continue to the next step.
  3. If the quality is still poor, one or more of the cartridges may be low on ink or empty. Follow the steps below to check the ink levels.
    1. Open HP Solution Center .
    2. Click Settings .
    3. Click Print Settings .
    4. Click Printer Toolbox .
    5. Click the Estimated Ink Levels tab.
    6. Replace any ink cartridge that is low on ink.
  4. If the ink levels are not low, clean the cartridge face and electrical contacts at the back of the print carriage.
    1. Open the front of the unit to access the ink cartridges.
    2. After the ink cartridges are at the center, unplug the power cord from the back of the unit, and remove the ink cartridges. The power cord must be removed to ensure that the unit is not damaged during the cleaning process.
    3. Clean the cross-hatched area of the ink cartridge with a soft clean cloth that is slightly dampened with clean water to remove any build up. Avoid cleaning the ink cartridge nozzle plate. Cleaning this area can force foreign matter into the ink nozzles and plug them
    4. With a soft lint free cloth slightly dampened with clean water, clean the copper-colored contacts on the back of the ink cartridges.
    5. Allow the cartridges to dry before reinserting them.
    6. Close the unit, and plug the power cord back in.
    7. Print a self-test page to check the results. Follow the steps below to print a self-test page.
      1. Press Setup .
      2. Press <or > until Print Report displays and then press OK .
      3. Press < or > until Self-Test Report displays and then press OK . The self-test report prints.
    8. If the problem is not corrected by cleaning the ink cartridges, replace the ink cartridge(s).
- hope it will help to resolve you problem...
Jul 14, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Printer problem with 6210 all in one.
Try to print a self test page from the printer itself, do these:
  1. Press and hold the Cancel and the Color buttons at the same time.
  2. Release both buttons.
  3. The Self Test Report will be printed.
and check if it is the same output, if yes then follow the steps below:
  2. Verify that there is plain white paper in the Input tray.
  3. Press Setup .
  4. Press c00712200.gif or c00712201.gif to select Tools and then press OK .
  5. Press c00712200.gif or c00712201.gif to select Clean Print Cartridge and then press OK . The unit prints a test page.
  6. Examine the test page. If the print quality of the page is good, stop here. If the print quality appears to be getting better, run the Clean Print Cartridge utility again
  1. If the self test appears better, Increase the copy quality setting (Normal or Best) and try copying again. If the quality is still poor, continue to the next step.
  2. If the quality is still poor, one or more of the cartridges may be low on ink or empty. Follow the steps below to check the ink levels.
  3. Open HP Solution Center .
  4. Click Settings .
  5. Click Print Settings .
  6. Click Printer Toolbox .
  7. Click the Estimated Ink Levels tab
  • Replace any ink cartridge that is low on ink.
  • If the ink levels are not low, clean the cartridge face and electrical contacts at the back of the print carriage.
    3. Clean the cross-hatched area of the ink cartridge with a soft clean cloth that is slightly dampened with clean water to remove any build up. Avoid cleaning the ink cartridge nozzle plate. Cleaning this area can force foreign matter into the ink nozzles and plug them.
  • With a soft lint free cloth slightly dampened with clean water, clean the copper-colored contacts on the back of the ink cartridges.
  • Allow the cartridges to dry before reinserting them.
  • Close the unit, and plug the power cord back in.
  • Print a self-test page to check the results. Follow the steps below to print a self-test page.
    1. Press Setup .
    2. Press c00712200.gif or c00712201.gif until Print Report displays and then press OK .
    3. Press c00712200.gif or c00712201.gif until Self-Test Report displays and then press OK . The self-test report prints.
    IF THE SELF TEST REPORT IS CLEAN, THEN TRY TO PRINT FROM ANOTHER SOFTWARE LIKE PAINT, NOTEPAD AND IF THE OUTPUT IS OK THEN THE PROBLEM IS ON THE SOFTWARE THAT YOU ARE USING
    Dec 19, 2007 | HP OfficeJet 6210 All-In-One InkJet...
    Gapped incomplete printing of text and pictures
    Try this:
    1. drum refreshing- set A3,or A4 paper in the multipurpose tray.(bypass) press the * (asterisk) key
    on the control panel. Then select drum refreshing.Select "ON".
    2. Check the Drum Cleaning blade-clean it,
    Drum can be cleaned with alcolhol,if copy quality is bad after that perform several drum refresh procedures.
    3.Time for maintenance is just info for customer that machine has declared maintenance interval.
    Customer must check Warranty terms and conditions.
    resseting time for maintenance: enter 10871087,then select U251, press start.To clear,press clear key(yellow button)
    and start.After that,press stop key twice,and enter 001 and start.
    4. Also I suggest to clean grid on main corona.
    Sep 26, 2007 | Kyocera Mita KM-2530 Laser Printer
    55 people viewed this question
    k24674
    jasbo
    jasbo
