Question about WSM 1993-1994 Polaris Sl 750 Cc Jet Ski Motor Mount
How do you loosen a drive coupler on a 99 Polaris SLH jet ski???
I have a 2006 Polaris MSX 140 jet ski and it has been sitting unused for nearly 3 years the Forward/Neutral/Reverse lever is jammed, how do I loosen it?
if there is a cable on the end of the lever , replace the cable assembly
if the lever is direct connection, spray with an anti rust penetrant on a regular basis for a few days then try to move it
try using localized heat from a butane torch to break the rust / corrosion seal while trying to move it
Jan 10, 2017 | Cars & Trucks
What now ?? my yamaha suv1200 Can the transmission be shot ?
there are no gears just a direct drive from the crank to a jet pump ! if theres no propultion of water it could be several things !
1. plastic bag etc in the intake to impellor pump assy !
2. impellor gap to housing too much ie worn impellor !
3. impellor not turning because splines on either the shaft or impellor worn !
4. drive coupler damaged and spinning on shaft !
Try running on a hose pipe and look at rear of engine ( remove plastic cover so you can see the 2part coupler and drive shaft ) .
Check the impellor assy !
Sep 08, 2014 | WSM 1999-2001 Yamaha Suv 1200 Cc Jet Ski...
Polaris troubleshooting
Have you cleaned the carbs and fuel tank , checked the plugs and coil ht's and connections ?
Aug 04, 2014 | WSM 1999-2000 Polaris Slh 700 Cc Jet Ski...
How to fix slt 780 fading speedometer
Fading as in can no longer read the gauge or fading as in the needle drops as the jet ski runs across the water even though same speed is being maintained?
Jul 19, 2014 | Clymer Polaris Jet Ski & Water Vehicles...
My Polaris freedom(jet ski) starts and runs good
Tools(1) A compression gauge (2) a spark gap tester.(3) A Clymer service manual for your engine. (you can purchase from your local dealer. I know all these are expensive but if your going to be a polaris tech you will always need them. Troubleshooting (1) check compression. Look at your Clymer manual for specific psi.all cylinders need to be over 100 lbs and equal each other within 5 lbs.(2) check spark. use a spark gap tester all cylinders should jump a half inch gap. if you have good compression and good spark, fuel is the problem nine
times out of ten.Ethanol gas is proven to stay stable in fuel systems for only 30 days in 90 + degree heat. Drain gas tank,clean fuel lines replace and replace all fuel filters. Polaris has a gravity filter under seat, clean it. Finally replace spark plugs, I know spark plugs probably don't look bad but this is a C.D.ignition. Fresh spark plugs means less resistance for the ignition system. The ignition system is week compared to automotive. Test drive polaris, if the problem is still there then there is further steps to take. If your polaris is fuel injected. Pull out your clymer manual. what is great about the Clymer Manual for Novice techs is it gives detailed info on your polaris. Troubleshooting tips and teaches you how your polaris works. If its carburetor then you should clean carburetors. Inside the carbs is another filter that needs to be cleaned. Its not difficult you just make sure you put everything back in proper order. take pictures if you need to.
Sep 18, 2009 | Boating
My 1997 polaris jet ski keeps taking in water? what could this be??
Unplugged water tube, cracked water tube, bad drive shaft hull seal, hole/crack in the hull, cracked water box, broken exhaust jacket water seal, water tubes plugged in incorrectly, no cap on flush kit, broken fitting on motor,etc. Dry out the boat take off the seat and place it in the water and look to see where the water is coming into the hull.
Sep 07, 2009 | Polaris ATV
2002 polaris jet ski. Cranked 1 month ago with no
you need to put a new battery in it if that does not fix it you will have to replace the solenoid
Jul 08, 2009 | Boating
No Spark to a 1994-1995 Polaris SL Jet ski
first have you done what is necessary for that such as draining the oil (unless it's a two stroke) draining the gas and refiling it with fresh gas and a couple bottles of gas line antifreeze (it sucks up water) ... for the electrical parts ... spray them with wd40... that will force out any moisture at all and oil does not conduct electricity.
Mar 16, 2009 | Interactive Toy Concepts Polaris Sportsman...
WSM 1993-1994 Polaris Sl 750 Cc Jet Ski Motor Mount Logo
167 people viewed this question
Top WSM Boating Experts
Fabrice Wolters
Stan Ford
spy1309
Are you a WSM Boating Expert? Answer questions, earn points and help others
