Question about Shredder Office Equipment & Supplies
Shredder all of sudden only works in reverse.
  • 2,963 Answers
Jamed with paper. Turn upside down to extract the jam.
Posted on Mar 31, 2015
My Black & Decker Shredder #BD-61 all of a sudden does not work. I used it tonight, but the next time I tried it does not work. The lights come on in both positions, but
On some shredders when both the forward and reverse LEDs are on it can indicate either a jam or a full receiver bag/ container (the area that the shredded paper is fed into).
Try the following steps:
  1. ) unplug the power
  2. ) open up the shredder (see 1 on diagram)
  3. ) empty out all the shredded paper (see 2 on diagram)
  4. ) check that the shredding jaws (both the entrance and exit) are clear of any shredded material (see 3 on diagram)
  5. ) put everything back together
  6. ) plug power cord back in
  7. ) force the shredder into reverse (see 4 on diagram)
Hopefully you should hear your shredder motor running. If it is switch it to automatic and try shredding again
Jan 24, 2015 | Shredder Office Equipment & Supplies
Shreds in reverse only
I think there is a shredded buildup on the bottom. Unlpug the device ... turn it over and clear out the residue you will find there.
Sometimes I find the addition of shredder oil during the shredding process helps to eliminate this problem. Get the oil where shredders are sold.
May 31, 2010 | Tech Solution TS-4500 Shredder
The aparatus that pulls the paper into the shredder doesn't work
Check to see if cutting shafts are turning in either forward or reverse operation. If not and you can hear the motor running the take off cover and check plastic gear drive train...probably something broken in there.
May 25, 2010 | Aurora Electronics AS662C Shredder
It will not shred - the reverse works fine
UNPLUG THE MACHINE AND TRY CLEANING THE "EYES" WITH A SOFT CLOTH. IF THAT DOSN'T DO IT YOU MAY HAVE DEFECTIVE EYES OR PCB...YOU CAN CALL ROYAL FOR PARTS AT 1-800-524-0799.
May 21, 2010 | Royal 85X Shredder
I have royal shredder and suddenly stopped. reverse side is working. There is no paper stuck in it. please help. Thanks
There are LED photo sensors in the feed path that detect paper. They can get a build up of paper lint or oil on them. The shredder needs to be taken apart and these need to be cleaned.
Oct 13, 2009 | Office Equipment & Supplies
Runs in reverse, but no on auto.
check and see if there is a jam of paper inside the unit or around the sensors
Jul 20, 2009 | Royal 10X Shredder
Olympia Shredder Jammed and not working
likely a spacer has broken, if you can see the underside of the cutting heads you will see a spacer or two hanging out, If this is the case the heads will have to be bebuilt or replaced.
Mar 06, 2009 | Olympia - 1452C CROSS CUT OFFICE SHREDDER
Fellows S701CM shredder won't respond
unplug in and check the fuse in the back side of the shredder
good luck
Jan 24, 2009 | Fellowes 3011001 Shredder
Shreder will only go backwards
I have a Fellows OS-11Cs shredder that suddenly quit operating. It would run in reverse and when auto mode was selected an audible clicking noise was emitting from a relay on the pc board. My initial thought was that I had overheated the unit since the shredder had been operating perfectly up to the point where it stopped working but that didn't seem to be the case after the unit was allowed to cool down.I cleaned all visible paper shreds from the cutters(with the shredder unplugged)that were visible and then sprayed the cutters with a very light lubricant (3 in 1 oil) I then operated the shredder in the reverse mode for a few moments and since then the shredder has operated flawlessly.I hope this is of some assistance to others with a similar problem.
Apr 01, 2008 | Fellowes 3011001 Shredder
97 people viewed this question
Top Shredder Office Equipment & Supplies Experts
Ross Keen
Dave Reilly
Level 1 Expert
Gilbert Ruiz
Are you a Shredder Office Equipment and Supply Expert? Answer questions, earn points and help others
