How do I import photos from an sd card onto my laptop ad where do I find the safely remove hardware eject media icon. I csnnot see it in my hidden icons
  • 682 Answers
You have to have a card reader on your laptop, or an adapter to go into the usb port. Once it is connected, the computer should recognize the card as a drive. It normally pops up "what do you want to do" select open folder to view files. Then drag them to the C: drive in the folder you want them in. In the task bar below you should see an up arrow. Click on that and there should be an icon to remove drive (card), this will not show up until the card is inserted. All the folders will have to be closed in order to get the "safe to remove" pop up.
Posted on Mar 30, 2015
How do I mount my sd card
You will insert the SD card into the SD card slot on your device then you will power on the device and tap settings from the main menu click free format and then pick mount SD card when reformatting has completed.
May 04, 2016 | HP Computers & Internet
I right clicked on my camera device ( button?) did not see eject.
Try the triangle button on the taskbar (the show all hidden icons).
left click on the "Safely remove hardware and eject media devices". And eject your device.
Sep 23, 2014 | HP Pavilion Chromebook Black Laptop...
Laptop wont read sd card
You do not say, but before ejecting an SD card you should use the Safely remove hardware feature. If you do not do so you may damage your SD card, and you run into problems such as you describe.
Apr 06, 2012 | Dell Inspiron Computers & Internet
How do i safely eject my SD card from my macbook pro laptop ?
To remove the card, drag the SD card icon to the Trash, then remove the card from the slot after the icon disappears from your desktop. Hope this helps.
Sep 27, 2011 | Apple Customized 15" MacBook Pro Laptop...
Can i download pictures from my aspire 6920g to a sd memory card
1. open Windows Explorer
2. push the sd card into the sd card reader with its contact side down until it is flush
3. sd card is detected and displayed as a drive called SD/MMC (N:) where N is its drive letter
4. clicking on the SD/MMC drive will list any folders that are in it
5. with SD/MMC high-lighted, click on File and on the drop-down list, hover cursor over New
6. on the New list that opens, click on Folder to create a new folder on the SD/MMC drive
7. right click on the new folder and from the drop-down list click on Rename
8. rename the folder appropriate to the photos you want to download to the SD/MMC drive
9. navigate to the photos and high-light using shift+click for a block or ctrl+click for individual
10. with cursor over high-lighting, hold down right click and drag to new folder and release
11. select from the pop-up list that appears on release to either Copy Here or Move Here
12. repeat from 9 for more photo downloading and when done do an eject before removing ....
13. for Windows XP, click on the Safely Remove Hardware icon at the right side of the Taskbar
14. for Windows 7, can do same as XP or just right click SD/MMC and select eject from the list
15. **WARNING** failing to do an eject or Safely Remove Hardware can result in corruption!!!
16. once message appears that media can be safely removed, push the card in until it clicks
17. once click is heard, stop pushing and it will pop out sufficiently to be grabbed & pulled out
Apr 30, 2011 | Acer Aspire 6920 Notebook PC
How can i pull out my memory stick t of my cer laptop
The memory card is ejected by just pressing it in until you hear a faint click then letting go. The card will pop out by itself about 1/8 inch and you can just grab it and easily pull it out the rest of the way. A word of caution. If you have written anything to the memory card from your laptop, you should not eject the card until you left-click on the tool bar icon "Safely Remove Hardware and Eject Media" then click on the pop-up list item to "Eject Mass Storage Device" which will reply with a "Safe to remove hardware" message. This insures that the contents of the buffer used for writing the memory card or stick has been completely written to the memory card or stick before it is removed. Because the card or stick is much slower to write than it is to read from the laptop's hard disk, there will always be a chance for an incomplete write causing card or stick corruption unless the "Safely Remove Hardware and Eject Media" is used.
Mar 26, 2011 | Computers & Internet
How do i get my camera photos onto my computer from my pny optima sd 2 gb. thanks,
there wil be a separate icon for all the camera photos....
it may be hidden also so see also the hidden files dear,.......
Jan 13, 2011 | PNY 2GB microSD Memory Card
How to add music and video files to the sanyo nvm-4370 gps system
Option 1 (Internal Memory):
  • Connect the GPS to your computer with a supplied USB cable
  • For Windows, go to My Computer and find the connected drive (Removable Disk), when you open this disk you should see MobileNavigator folder
  • From the root of this drive, you can create 3 folders: Photos, Music, Videos and copy your media files respectively
  • Safely Remove Hardware the connected unit and unplug
  • Select your player/viewer (Photos, Music, Videos)
  • By default the internal memory (a can shape icon) is selected
  • Now enjoy your media
Option 2 (SD Card):
  • Assume your computer has a SD card reader
  • Insert the SD card to your computer
  • Insert the card to the Sanyo GPS
  • Tab the internal memory option (a can shape) to change to SD card option (sd card shape) to access files on SD card
Feb 26, 2009 | Sanyo EasyStreet NVM-4370 Car GPS Receiver
Infected SD Card? or Computer?
This can happen when the card is removed when Windows is still accessing it. Even when you think you are not doing something, Windows could be. I am 99% certain there is nothing malicious on your system and the cause was early ejection.
To prevent this from happening next time, before removing the SD card try using the "Safely Remove Hardware" tray icon to safely remove your device. TIP: Do not remove any storage device (i.e. SD Card, Flash drive, etc.) if the light is blinking.
Happy computing!
Sep 18, 2008 | SanDisk Memory Media
SD Card Error
I had a similar problem and after a bit of tooling around, I was able to get this to work for me. There are a couple of steps. Basically the problem is that the memory card wasn't properly disconnected from the player at some point so it's reading filesystem errors on it as a result. (Kinda like pulling out a USB key from a computer before you've "safely removed hardware". While your computer will tolerate this, your zen will not.) Here's how to safely remove disconnect your SD card after copying files to it.
1. First, if possible, reformat your SD card. This is not critical, but is a good practice so that you can sart from scratch with a totally fresh card.
2. Next, plug in your SD card to your player and turn it on. Navigate to the memory card menu, and place the memory card in "removable disk".
3. Plug the Zen into your computer, and go to "my computer". There should be a new disk called "removable disk" which is now shown along the rest of your hard drives. (Kinda like when you plug in a USB key drive. You're essentially doing the same thing here.)
4. Copy your files to the "removable disk".
5. VERY IMPORTANT: When you are done, right-click on the removable disk and choose "eject" fromt the menu that comes up. When a popup appears saying that your hardware is safe to remove, you can unplug the zen from the computer.
6. Now navigate to your memory card using your zen player, and choose "browse". It should come up now without any error.
Jul 08, 2008 | Creative Labs Zen Digital Media Player
Computers & Internet Logo
David Payne
David Payne
