Question about Craftsman Electric Stapler
I have an older model electric stapler that does not feed the staples consistently. The mechanism that looks like it should keep the staples pushed forward does not seem to have any tension. It's never been that good at stapling and now it's even worse.
Where can I get a couple Panasonic AS-500 Commercial Staplers repaired? Have tried calling Panasonic at 1-800-405-0652 option 4 but got nowhere.
This is a rather rare request, as very few places fix staplers.
I should recommend you find a "handy-man", maybe an older person with a hobby, and he may be able to help you.
I fix staplers, but have only been successful about 50% of the time.
God bless your efforts.
Feb 25, 2016 | Panasonic AS-500 Commercial High-Capacity...
How do I load the stapler?
No you don't. We answer most things here.
If the stapler is like any of these
http://www.amazon.com/s?ie=UTF8&page=1&rh=i%3Aaps%2Ck%3Abostitch%20staple%20gun
You push the back in slightly to unlatch it and then drop it down a bit and the staple pusher comes out completely.
Jan 28, 2016 | Heavy Duty Stanley Bostich Heavy-duty...
How do i load the Stanley Bostitch 00540
Hi Diane,
If you look at the back of the stapler, there's a bright red button. Push this in and slightly lift up at the same time, then magazine is withdrawn. Feed a strip of staples in and replace the pusher unit.
Bostitchtools co uk Bostitch Nailers Staplers Fasteners Coil Nails Staples
Jan 29, 2015 | Stanley Bostitch 00540: 00540 AntiJam ?...
How do I refill the stapler model #02210 with new staples?
I have a similar model. When you push the button on top, the "drawer" pops out. Pull the drawer out until it is fully extended and you will be able to load staples. When you fave finished loading staples, push the drawer in until it latches.
Nov 02, 2014 | Stanley Bostitch 02210 Electric Stapler...
Swingline optima 40 how do you open and close the stapler?
Swingline heavy duty staplers provide the power to staple up to 120 pages of 20-lb. paper easily and consistently. The all-metal construction of these staplers makes them an indispensible office tool. However, the way to load staples into a Swingline heavy duty stapler differs from the method for loading most other manual staplers and can cause a little confusion.
Difficulty:Easy Instructions
    • 1 Remove the follow block at the back of the stapler by pushing the mechanism in, lifting the block up over the holding hooks and sliding it out from the stapler. The follow block is the spring-loaded mechanism that holds the staples in place within the stapler.
    • 2 Load the heavy-duty staples into the staple tray.
    • 3 Replace the follow block by inserting it back into the stapler and locking it into place over the holding hooks.
Read more: How to Load a Swingline Heavy Duty Stapler ' eHow.com http://www.ehow.com/how_5822366_load-swingline-heavy-duty-stapler.html#ixzz1bVwG5bBn
Oct 21, 2011 | Swingline ® High-Capacity Heavy-Duty...
I have a stanley heavy duty stapler TC110. When I put my staples in, they don't seem to be catching. There is some black part sticking out of the end where the staples should come out. It looks like...
The staples load on the underside of the stapler.
Step 1 Push down and retract the stapler pushup mechanism.
Step 2 Position the stapler so that the moving hammer handle is down
and the staple exit is up
Step 3 Load the staples into the chamber on the bottom with the points up.
Step 4 Push the pushup mechanism into the locked position until it latches, you will feel the spring resistance as the staples are pushed into place.
Sep 04, 2011 | Powerfast Stanley TR110 Light-Duty Staple...
Just bought and tried to load my Swingline Smart Touch low force stapler. Don't know how to get it opened
I have one of these models. Just push the gray lock mechanism at the end of the stapler and the loading magazine will pop out. The chrome plated magazine opens towrds the front....it slides forward and backwards.
Jun 17, 2011 | Office Equipment & Supplies
I have an ACE aircraft aluminum stapler... I bought Ace Heavy Duty Staples 3/8" 10mm Narrow Crown Arrow T50 staples but cannot get the arm to load with them on it.
Possibly you are trying to load it from the back with the arm out. This way does not work. With this stapler you must pull the arm out all the way and then drop the staplers in the bottom. Too easy, right? I felt like a dumb a$$ after fighting this one for an hour. By the way, it will take heavy duty staples but you need to match the item codes printed on the side of the stapler with the box at ACE hardware. Hope this helps... Say "yes" to "was this solution helpful?" so I can know that im not the only one who did this wrong :)
Jan 09, 2011 | Ace Hardware Ace Staple Gun
I have an older Fasco stapler, it is orange in color. S3G 16 is number on it. The part that pushes out the staple has a piece of staple stuck in it. How can I get this out?
Some models have small screws on the face plate that can be unscrewed to release pressure or a spring clip to release. You can also push the plunger back into stapler with a thin narrow srewdriver, the staple may fall out.
Nov 30, 2010 | Fasco 9 Narrow Crown Pneumatic Staple Gun
Instructions on unjamming swingline electric stapler model 270; jam is at the front of the stapler; staplers come out either broken, flaten or crooked and does not secure document.
First, are you using the recommended staples for this stapler? Many heavy duty electric staplers don't use "standard" desk staples. Second, try unplugging the stapler, unloading the staples, and if possible, reach a couple of fingers into the stapler and try manually pushing up on the staple head to see if you can get the driver blade to come down. Does it come down smoothly, or does it seem like there is something stuck in there? If you aren't sure about disassembling the unit (my usual method-but I'd recommend having the parts diagram handy), try using a flashlight to look at the underside of the staple head, where the staples come out - can you see anything stuck in there? If so, you might be able to use a small knife blade or small dental pick to get jammed staple pieces out.
Mar 03, 2009 | Staples Swingline® 36115 Staple Guns Tools...
Craftsman Electric Stapler Logo
483 people viewed this question
Top Craftsman Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Craftsman Office Equipment and Supply Expert? Answer questions, earn points and help others
