Question about N'FINITY Dual Zone Glass Door Right Hinge Wine Cellar Capacity: 166 Bottles"
The upper zone is not cooling I get an error code EI I was told by the maker that the fan is bad and I need to replace it. How do I do that?
  • N'FINITY Master
  • 5,323 Answers
JUST REMOVE THE BACK PANEL AND SOMETIMES EVEN THE BOTTOM PLATE MUST BE REMOVED THEN U WILL HAVE ACCESS TO THE FAN REMEMBER TO SHUT OFF POWER BEFORE REMOVING IT
Posted on Apr 07, 2015
HOW TO REMOVE OR REPLACE ICE MAKER FAN
No, there is a different error code if the control board is bad or there is a wire connection issue. The IF error is a comon error and either the fan needs to be replaced or something like ice is blocking the fan from moving. Check to make sure ice or frost isn't blocking the fan, and if it's clear, you need to just replace the fan motor.
Jun 30, 2016 | LG LFXS30766S LFXS30766S 36" French Door...
Dometic model 3313192 thermostat error code E1 what does this mean?
Hi By E1 error it means
Loss of communication between the Single Zone LCD thermostat and the module board. LCD will cycle between E1 error.
Check the link for regular maintenance Of the LCD thermostat.
If it doesn't help then you have to replace the LCD thermostat.
Ajin
http://www.google.com/url?sa=t&rct=j&q=dometic%20model%203313192%20&source=web&cd=1&ved=0CCwQFjAA&url=http%3A%2F%2Fmanuals.heartlandowners.org%2FHeating-Cooling%2FA-C_Units%2FDometic%2FDometic_Single_Zone_LCD_Thermostat_Operating_Instructions.pdf&ei=hOg0T7OUNIjkrAer4Ny6Dw&usg=AFQjCNEn2y9-ItUcF2KRJZ0dm0Ftrq8Jhw
Feb 09, 2012 | Dometic Rooftop RV Air Conditioner
Error Code E3 displayed on Samsung wine cooler model RW13EBSS, even after power off and reset.
"E3" on display for upper zone - error of DC
electric fan for upper zone.
I had an E3 on the upper zone. This fix was simple. Unscrew the 2 screws for the middle tray. Pull tray out as far as you can. Check the wires in the back, those are the wires for the fans in the back. The connectors over time corrode, and break off... All I did was connected the 2 wires that had broken off of their connector directly to each other. E3 went away and the cooler is working as it should now.in
Jun 15, 2011 | Refrigerators
Error code in the top zone E3
An E-3 error code on your product indicates a problem with the DC fan in the upper zone. Your issue could be with the fan motor, control board or connecting wire harness. A DC motor can not be ohmed out like an AC motor, so if you detrmine the motor is not running, check for DC voltafe at the motor connections. If there is 12 to 24VDC, then you have a bad motor. If no voltage is present, check the output on the board. Before replacing an expensive circuit board, you may want to have a professional service tech come out and diagnose your problem. ***ALWAYS remove electrical power from the product when removing panels to gain access to components, and also when putting the panels back in place.
Nov 04, 2009 | Magic Chef Refrigerators
MC wine cooler MCWC44DZ error code e3
I had an E3 on the upper zone. This fix was simple. Unscrew the 2 screws for the middle tray. Pull tray out as far as you can. Check the wires in the back, those are the wires for the fans in the back. The connectors over time corrode, and break off... All I did was connected the 2 wires that had broken off of their connector directly to eachother. E3 went away and the cooler is working as it should now.in
Jan 04, 2009 | Refrigerators
Error code
IF error is a bad fan motor or wire connection to the fan motor that is use for cooling the ice maker
Aug 21, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
N'FINITY Dual Zone Glass Door Right Hinge Wine Cellar Capacity: 166 Bottles" Logo
70 people viewed this question
Top N'FINITY Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a N'FINITY Refrigerator Expert? Answer questions, earn points and help others
