Question about Health & Beauty
I pluged in the chair to the outlet in my house and I left the power switch on came back three hours later and it was dead does leaving the power switch on keep it from charging
  • 682 Answers
I would be inclined to think it would. This is the case on many rechargeable items.
Posted on Mar 30, 2015
  • 16 Answers
SOURCE: new battries won't charge.
Sounds like the batteries are completely dead, you'll probably need to replace them, sometimes you can only use batteries until they die, and that goes for Wheelchair Batteries too. If they won't charge or keep a charge then they are dead.
Posted on Mar 06, 2009
  • 32 Answers
SOURCE: Missing instructions on how to charge battery for MPV4
bad/old batteries
Posted on Apr 03, 2009
  • 103 Answers
SOURCE: Battery won't charge
First make sure that all the connections are tight. Then have the batteries load tested.
Posted on May 26, 2009
  • 103 Answers
SOURCE: Jazzy wheel chair
When a chair sits for a long period of time ( four weeks or more) without being charged, the batteries die. To help you with the freewheel mode I would have to know what model of Jazzy it is.
Posted on Nov 16, 2009
  • 11 Answers
SOURCE: Jazzy 1103 will not charge. Power cord and
The battery charger is only made to last 1 year if you
re lucky. They are all made in China very cheaply and some only last a matter of months. If you are on Medicare they will replace the charger if necessary after a year. Good luck, hope this helps
Posted on May 16, 2010
My fzr 250 87mod is electricaly dead.
Double check that you have not accidently hit the kill switch.
Dec 01, 2012 | 1989 Yamaha FZR 250 R
When i turn the on switch three red lights flash on the left side
glenn You have a left motor fault and the motor will have to be replaced. If Medicare paid for your chair they will pay for 80% of the repair costs. Contact Repair Express @ 877-581-3733 or Roadrunner Mobility @ 1-800-467-2668 they are both great service companies that will send a tech out to pick up your chair and leave you a loaner to use. They will bill Medicare for all repairs and get your chair back to you all ready to go You can also check with your provider to see if they will repair it for you Hope this helps
Mar 01, 2011 | Jet 3 Ultra Power Chair
My Jet 3 has new batteries and they fully charge. When I am outside of the house the chair just cuts off like you turned of a switch. Leave be a while and it runs again. when you push reset button after it...
Alvin you have a left motor problem and it could be a loose connection Check that the left motor connector is tight and that if you move it the lights blink then there is a problem with the wiring to the left motor. If Medicare paid for your chair then they will pay for 80% of the repair costs contact your provider to see if they will repair it or contact a repair service like Roadrunner Mobility @ 1-800-467-2668 Hope this helps
Mar 01, 2011 | Pride Used Mobility Jet 3 Power Wheel...
My chair will not cut on at all even with the power supply pluged in
Trace the problem to the power supply connection devices. For example, the power current be enough to inflat the chair. Consider the extension chords capacities. Second, trace the pin outlets at which the air is placed into the chair. A closed circuit usually power supply safety mechnicasm may be locked. For example, once the chair is ready to be inflated, open the pin connection hose outlet. Third, inspect the chair for damages either perforations that is causing air leakage. Also, the chair is incapable of inflation when pressure is applied on it. Either due to insufficient power from an outlet source given the extension cuicuits provided with package at purchase. Consult power citucuit professionals as alternate resolution. Good luck
Jan 10, 2011 | Pyramat Sound Rocker Gaming Chair
Plug charger in and will not charge the fan on the charger quits running in a few seconds it will beep with charger pluged in and when you unhook charger it clicks like a dead battery i wonder if charger...
David Are you leaving the power on while you are charging the Chair? If you are try charging with power off at the joystick. The manufacturers of all power batteries do not recommend charging with automotive chargers. I would try to locate a friend or neighbor that also has a chair or scooter and borrowing their charger for a few hours to see if it will charge your chair. If not contact your provider and borrow a charger from them. If the different charger works then yours is bad. You shoud be able to order a charger through your provider or by calling Pride Mobility @ 1-800-800-8586 Hope this helps you PS I didn't say you couldn't use the "other" charger. But I wouldn't want you to think I approved of it
Oct 02, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Mitsubishi vs-60609 will not power on when it is pluged in the green light flashes three times. The manual says this means the microprocessor is functional. I ran the self diagnostic (as suggested in the...
Unplug,replug it an hour later tv now,resetting back to factory setting.Should work now,not than the DM power supply board is dead.Try website like Tvrepairwold.com to buy a capacitors kit to replaced those dead capacitors on the DM power supply board.
Sep 09, 2010 | Mitsubishi VS-60609 60" Rear Projection...
Power.
Please try pluging it different ac power unit if this continues then its the faulty power unit in the tv.................
Jun 11, 2008 | RCA HD52W56 52" Rear Projection HDTV
Health & Beauty Logo
131 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
