Question about Garden
I need a carburetor gasket diagram for och gcv160 motor
  • 1,169 Answers
You need to determine which gasket and heat dams you have but following link should give an idea of how they go. Sorry can't give any better setup as there is too many variations to consider on these engines.
Honda GCV Carburetor Diagram
Posted on Mar 31, 2015
Zx9r har ingen koppling
Hej, Urban och de vanliga misst?nkta ?r: 1. T?ndningsl?s inte i l?ge "ON". 2. Motor Run Switch i l?ge "OFF". 3. urladdat batteri, m?ste vara 12,5 volt eller b?ttre och kunna passera en belastningstest vid behov. 4. Kontrollera batteripolerna f?r skador eller korrosion kontrollera batterikablarna p? "B?DA" slutar f?r l?sa, korroderade eller trasiga kontakter, "insida" och utanf?r ledningsmattan, utf?ra kontakt vicka test och kontrollera kablar med en ohmmeter vid behov. 5. Tips ?ver sensorn beh?ver en ?terst?llning. 6. Fel p? t?ndningsl?set. 7. Felaktig startknappen. 8. Felaktig st?ll eller kopplings pull switch / sensor. 9. Start styrkrets, rel? eller magnet felaktig. 10. Huvud s?kringen kan bl?sas eller felaktig. 11. Kontrollera motorns felkoder. F?r mer information om problemet och v?rdefulla "Free" nedladdningar som du beh?ver klicka p? l?nkarna nedan. Lycka till och ha trevligt en dag.
http://www.zxforums.com/forums/mechanical-technical/28041-zx9r-wont-start-strange-problem.html
zx9r electrical prob wont start please help
KAWASAKI ZX900 C1 Service Manual
Kawasaki ZX9R 98 99 Service Manual
OEM Parts for Kawasaki
Kawasaki Ninja Owners Manuals
Dec 25, 2016 | Motorcycles
I bought a carb kit, but it has extra parts. Where can I find a diagram of this carburetor?
Without the equipment and carburetor it is impossible to even direct to a possible part lists.
Most carburetor will have extra parts as there are may several revision levels for a particular carburetor and even part list diagrams won't cover them all that why you keep the old gaskets and other parts until you get it re-assembled so you can compare them as you go.
Aug 06, 2015 | Garden
Carburetor diagrams
need more info. please supply a model and make of engine. example briggs and Stratton, kohler etc
Jul 16, 2014 | Yard Machines 158cc Push Lawn Mower #11a...
Where is the carborator
Hello. The carburetor should be directly behind the air filter. I believe the unit you have is a GCV160 engine. Here is the link to the manual showing a diagram (see pg 9).
http://engines.honda.com/pdf/manuals/00X31Z8B0240.pdf
Should you have a different engine, here is the link showing how to identify it's type, then proceed to download that one instead.
http://engines.honda.com/parts-and-support/owners-manuals/gcv160
Hope this helped. If so, please rate this a four-thumbs up. Thank You.
Apr 02, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
I need a diagram to rebuild the carb for my 67 250 inline 6
When you buy a carb. rebuild kit it will come with the diagram chart and spec to rebuild it.
Jun 10, 2010 | Cars & Trucks
Volvo pento 1998 want start with out pouring gas down throat of carburetor (marine)
There are a few things to check for this problem and you will need a helper to run 1 test on the engine. Whether you have a carburetor or injectors the engine needs to draw in the fuel. Put your hands over the carburetor without the flash arrestor on it. Have a helper crank the engine and try to start it doing what you normally would do on a cold start.
If you feel a vacuum draw and the engine starts or the carburetor gets wet and tries to start you need to adjust the choke or test the intake manifold gasket.
On a carburetor the choke plate needs to be closed when cold or even warm on some motors. The intake gasket needs to seal and can seal when it gets hot.
After you get the motor running squirt some water around the seams of the intake gasket and see if the Rpms drop or the engine cuts out. Same thing for the base carburetor gasket.
If adjusting the choke does not help and there are no manifold leaks you need to remove the carb with as little disturbance as possible. Then place it on a level surface and expose the bowl to see if it is dry or low on gas. If the bowl is dry,you need a rebuild and if the level is low you need to adjust the float. Get your model number for the carburetor and go online to find the specs or just wing it. Usually fuel levels are 3/8 to 1/4 inch below the top level of the fuel bowl.
Apr 20, 2010 | Boating
Need the carburetor assembly manual
It is either a Walbro or a Zama carb. I think both mfrgs have a website w/ parts breakdowns. But both carbs are the same as to the placement of diaphragms + gaskets. On the side with the inlet needle the gasket goes on first and then the metering diaphragm. On the fuel pump side the diaphragm goes against the carb body and then the gasket before the cover.
Aug 10, 2009 | Troy Garden
Honda GCV160 Engine Won't Start
Hello
You should siphon out all the old gas you can. Replace with new gas. Check that the spark plug is good and the air filter is clean. Spray some carb cleaner in the carburetor.. Also, you should check the oil level and change the oil if it is black. If it tries to start after you spray the carb cleaner in but won't keep going then you know the carburetor needs a good cleaning
Aug 08, 2009 | Karcher 2500 PSI Pressure Washer
Honda GCV160 5.5 on a pressure washer runs only intermittently
The problem is the plastic float in the carburetor, it's not adjustable and after sitting up with gas in it it distorts. Save yourself the trouble and buy a new one, you can get them online for $15-$20.
Mar 17, 2009 | Campbell Hausfeld Garden
Garden Logo
130 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
