I have nothing to plug p3 and p4 into when all on no signal
Ok when i turn pc and tower on it only says no signal monitor works thats it nothing eles am i missing what plugs into p3 and p4 i know nothing
    Habit-Forming:
  • 26 Answers
Sometimes if a VGA cable is not screwed into to both your Tower and your Monitor, it can get loose and thus resulting in no signal.
Another cause of a Monitor Displaying the no signal message would be due to the Graphic Card failing, or possibly due to the Graphic Card not correctly being seated.
Other Thoughts
Usually P3 and P4 refers to a cable on your power supply that needs to be attach to your motherboard to supply extra power.
Note:
If your P4 cable is not plugged in before turning on your computer, this will also result in your Monitor displaying the no signal message.
Keep in mind though, if your computer has not been opened or is not a custom built PC, you should not have to worry about such issues as your P4 cable should in theory be connected. However I guess safely checking won't hurt anyone.
Posted on Aug 08, 2015
Muzzi_123
  • 749 Answers
SOURCE: tower won't turn on
hi try to put the monitor lead in the tower, the leads are both the same, the fuse might be out in the tower lead.
Posted on Mar 28, 2009
gpetti2009
  • 92 Answers
SOURCE: No video signal
The video card may have a jumper next to it or it need to be reset in bios If you know how at start up prees F1 or F2 or Del one of these will open Bios in the bios menu you will see setup instructions on the side or the bottom follow them and save if you are trying to add a video card it should say onboard or pci slect pci then press esc on your keyboard then press F10 to save settings then restart pc this should work but check the hp website for downloads get the manuel and find out about the video jumpers.
Posted on Apr 07, 2009
  • 87 Answers
SOURCE: my tower wont turn off and monitor says no input signal and keyboard doesnt work
Do you have two video outputs on your PC ie. one on the motherboard adn a separately installed card maybe? If you do you need to set the BIOS so that it uses the AGP/PCIE video card and not the 'onboard'. Try the onbopard vodeo card first to see if you get a signal there.
If you do NOT have two video outputs, and you can not see a signal then you may have a prblem wiht your monitor itself. Is this a known working monitor to start with?
Posted on Jun 05, 2009
Oz1286
  • 31 Answers
SOURCE: Black Screen Compaq Presario
Do you see the BIOS splash screen or anything?
Try booting into safe mode by pressing F* as soon as you power on the computer. If the monitor works, then it is a bad driver. Roll back to a previous restore point, boot to last known good coonfiguration. Last Known good configuration is available from the same as the safe mode screen.
If this is helpful, please comment and rate. Have any other questions, please let me know.
Oz
Posted on Feb 12, 2010
Jta91
  • 99 Answers
SOURCE: My hp2009m monitor goes into sleep mode
Monitors are programmed to go to sleep when there is no input. If you shut it down on the other "tower" also it will do the same. You need to physically hit the power button on the monitor to actually shut it off.
Posted on Feb 24, 2010
Tower turns on but screen says no signal?
Check to be sure your monitor connection needles are seated properly. Is mouse wireless or connected to back of tower?
Jan 02, 2014 | Acer Aspire X3200 PC Desktop
Tip
How to use a P3 power supply with a P4 or newer motherboard.
Well its fairly simple, You need the following cable to convert your P3 power supply into P4 power supply.
The pictures pretty much explain every thing, this is the only plug that is not present on a P3 power supply. You can make this cable your self by salvaging connectors from non-working power supplies and other computer peripherals. The connections are straight forward just connect both the yellow wires to the single yellow wire and the black wires to the black wires and your done.
on Feb 09, 2010 | Computers & Internet
The tower turns on but does not boot the monitor
There could be a problem with the connection to your monitor.
Dec 21, 2013 | Gateway ATXSTF MNT Pro S P4 1500 Tower...
No Beeps, Post, Nothing.
make sure the p4 power connector is plugged in. (4 wire yellow and black wires) plugs in near cpu. Remove and reinsert memory modules. That is were I would start.
Oct 18, 2013 | Biostar N68S3+ AM3 NVIDIA MCP68S Micro ATX...
I had to take my computer in for repair and turned the acer monitor off while the tower was gone. After plugging everything back in after repair, the monitor will not come on when you hit the power...
The first thing to check is , the Power, are ya sure it's plugged in OK, are ya sure that socket is working, try something else in that outlet to prove, check the power cord is pushed right in, Check ya on the right Video connector on the PC, make sure all conns are correct. Try the monitor on another base unit, try your base unit on another monitor. If all these are OK then ya Monitor has turned it's toes up sorry.
Jan 20, 2010 | Acer AL1914 19" LCD Monitor
I cannot restart my PC AllI get is a note saying NO SIGNAL ANALOG
i had a problem like that ,my tower got bumped and fell over. the heatsink and processor fell off. i had to remove processor (p4) from heatsink and make sure all the pins were straight and aligned properly. i cleaned both parts with alcohol. i then reinstalled processor(unlatched the arm )and it fell into place. then pushed latch down, installed some new thermal grease,installed heatsink ,plugged in and it worked- had a signal/ video again and able to use pc again.
Apr 07, 2009 | Gateway GT5058 Desktop PC
Tower turns on monitor shows no signal
I am guessing what you mean is that the monitor won't turn on. Does it have a green light or a yellow light that turns on?
If it is plugged in, there should be a light. If not, the monitor is bad. If the light is on but there is no video, then your video card has gone bad.
Jan 24, 2009 | MSI KT4A Ultra (MS-6590-050) Motherboard
Monitor comes up shows "acer" then says no signal and goes black
The interface between the monitor and the cable might need replacement. Please check it.
Jan 12, 2009 | Acer AL2016 W 20" TFT LCD Monitor
Color problem
IT is 18 years OLD so has CCFL back lamps that all turn yellow.
is that it? if the OSD is yellow the (white looks yellow) that means the CCFL black lamp tubes are Shot.
i cant see what you see, no photos posted.
ok the monitor has and OSD, on screen display
i see you found that. but then fail to say what you saw there.
"you could see the background on the text as white. "
what does that mean,?
no matter what that is a bad Monitor.
the OSD works with no computer at all, so if the OSD fails
OSD brain, inside, then the monitor is bad.
all monitors worked previously so is not key to why its failing now.
only the tests now, matter. today/
my post above is for any monitor that fails the OSD tests
no PC turned off. or connected to any PC that works
the PC resolution must never exceed
1024 × 768 at 75 Hz Refresh Rate
on this old old dog. or the screen goes back with error
OUT OF RANGE.
Aug 27, 2017 | Compaq TFT5010 (Opal) 15.1" LCD Monitor
Not what i wanted
easy all 4 pin dont matter 4 pin to all hard drives and cd roms ok big 20 pin or 24 to mobo smaller 4 pins floppies ok dont mater that its says p1 p2 3p that dont meen nothing ok 4 pin plugs main ones uuse on cd roms hard drives ok fans sumtimes
Jan 23, 2008 | Computers & Internet
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
