Question about Kitchen Ranges
How do you clean under the coils of the range?
    Top Expert:
  • Kitchen Ranges Master
  • 52,135 Answers
They do lift out if you really must clean that good .
Posted on Mar 30, 2015
How do i open the top to clean under the burners
Normally it's easy. Just lift the range top from the front andtheir should be a lever to pop up and support the range top while you clean. :)
Dec 02, 2015 | Maytag Kitchen Ranges
How do I lift the top of my whirlpool ry160lxtq02 to clean under the coils
IT does but it is not easy to do. YOu have to move it out from the wall, take screws out of the back, open the door and remove and screws that are hidden by the door that hold only the range top down. Then you can lift the range top.
Nov 07, 2014 | Dryers
How do I check the ignition coil
Ignition Coil Primary Circuit Test
Remove the coil. THEN set your ohmmeter scale to RX1 and place ohmmeter leads on the primary coil windings A (front of coil) to B (middle of coil), B to C (front of coil) and check for primary coil winding resistance which normal resistance range is zero point five and zero point seven ohms. If primary resistance is not within this range check out test results below.
Ignition Coil Secondary Circuit Test
With the ignition coil removed from the motorcycle and the ohmmeter set to the RX1K scale place the ohmmeter leads on the secondary coil windings B (middle terminal) to
R (rear secondary terminal/socket), B to F (front secondary terminal/socket) and check for secondary coil winding resistance which normal resistance range will be 5.5-7.5K ohms. If secondary resistance is not within this range check out test results below.
Test Results
A low resistance value indicates a short in the coil winding which requires coil replacement.
A high resistance value might indicate that there is some corrosion/oxidation of the coil terminals requiring the coil terminals to be cleaned and the resistance test then repeated and if after the test is repeated the resistance is still high after the terminals were cleaned the coil must be replaced.
If there is an infinite ohms or no continuity) resistance value the coil is open and must be replaced.
Jul 30, 2014 | 2003 Harley Davidson FLHTC Electra Glide...
How to check for spark, harley springer
Remove the coil. THEN set your ohmmeter scale to RX1 and place ohmmeter leads on the primary coil windings A (front of coil) to B (middle of coil), B to C (front of coil) and check for primary coil winding resistance which normal resistance range is 0.5-0.7 ohms. If primary resistance is not within this range check out test results below.
Test Results
May 03, 2014 | 2003 Harley Davidson FLSTS Heritage...
Throttle cable install
What year????
For some models and years, but do not know if it fits yours as I do not know what year you have:
Test Results
May 03, 2014 | Harley Davidson FXDWG Dyna Wide Glide...
I have an 05 softail duece with manual choke, engine will turn over fine but I have no fire at the plugs, installed new plugs, still no fire
Test Results
Apr 28, 2014 | 2005 Harley Davidson FXSTD - FXSTDI...
The bottom draw on my oven range is not lined up
Has a round track bearing come off? That just happened to me the other day, and I found it under the drawer. Just poped it back in.
Jan 24, 2013 | Whirlpool WFC130M0AW 30" Freestanding...
Between glass dirty on kenmore glass top range
the door must be removed from the oven and taken apart
Oct 23, 2011 | Kitchen Ranges
GE PROFILE JBP79 OVEN RANGE - OVEN DOESN'T BAKE. CLOCK, BROILER, CLEANING WORK, LIGHTS WORK WHEN CLEANING OVEN. COIL ON BOTTOM DOESN'T GET HOT BUT BROILER COIL DOES.. WHEN CLEANING OVEN LIGHT WORKS WHEN...
Could be the sensor inside the oven.Mine burnt out when using the self clean feature. Two screws un-plug replace with new. Part less than 15 dollars
Jan 08, 2010 | GE Kitchen Ranges
Range is not working
i know it sounds obvious but have you checked you oven fuse or circuit breaker - ie in your fuse box?
Apr 17, 2007 | Whirlpool RBD245PD Electric Double Oven
Kitchen Ranges Logo
53 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
