Question about Amana Washing Machines
How to replace the coupler on an Amana DLW 330 raw video please
  • Amana Master
  • 5,323 Answers
TRY YOU TUBE PUT IN BRAND NAME AND WHAT U WANT TO DO
Posted on Apr 16, 2015
Amana washer making a grinding noise when draining and getting ready to spin Model # NAH6800AWW
hi,
sounds like the couplers going, if its a traditional top loader, the coupler is in between the motor and the transmission and are meant to shear off to protect the machine from damage, overloading. they dont last forever. once you get the motor off the part is right there..
if its a front loader check the belt teeth.
jm
Jul 20, 2017 | Amana Washing Machines
Belt off how do you put it on?
This washer does not run by belt drive, it has a direct inverted drive motor with a motor coupler between the motor and the transmission, if you need assistance on how to replace the motor coupler please comment back. If you can see a belt under the washer than you have listed the wrong model as your washer.
Mar 10, 2013 | Amana 3.2 cu. ft. Top-Load Washer
Washer fills with water then hums
On an older washer that is a broken belt. On a newer model the drive coupler has failed:
Video:
More videos, how it works
Jun 26, 2011 | Amana 3.2 cu. ft. Top-Load Washer
I HAVE A PORTER CABLE 330 SANDER, IT VIBRATES SO MUCH IT IS UNCOMFOORTABLE TO HOLD. IF I REPLACE THE RUBBER POSTS WILL THIS SOLVE THE PROBLEM? IS IT SOMETHING ELSE?
Not sure if this will work for you, but I had the same problem with my 330, it vibrated so much it felt like I was being electrocuted. I took the four screws holding the pad off and blew compressed air inside the sander to remove all the sawdust. Screwed the pad back on and now it works fine. Mine was only 5 years old with very little use.
Apr 20, 2009 | Air Tools & Compressors
Amana dryer dle330raw tenson on belt
Usually very simple. You need to get the diagram for our model. Most dryer belts go around the drum, around the tensioner pulley and around the motor pulley. You need to take off the front, top and rear panel depending on model. I can change mine in about 15 minutes complete job.
Jan 08, 2009 | Kenmore 82822 Electric Dryer
I have an Amana Elec. Dryer. Model # DLE 330 RAW that all of sudden quit heating. This dryer is about five years old. It has 7 cycles and 3 temp controls. Could this be a bad heat control switch or a...
It could be a circuit breaker, fuse, or electrical problem. Just because the motor runs doesnt mean it will heat.
You should check for power first.
Then unplug the dryer remove the lower front panel, two screws.
Mark and label any wire you remove so you know where they go!
in the back on the left is the heating element, check for burnt wires, take the element out and check for a broken wire on the back side also check all the thermostats, and electrical components to make sure they are good.
ask more questions if needed
Jul 15, 2008 | Amana Dryers
Washing Machines Logo
47 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
