Question about Imperial EFS-40 - Gas Elite Deep Fryer - 40 Lb - Tube Type - 15-1/2" Wide
Burner tube believed to have small fracture. Causes small grease fires periodically. Believe warranty has expired.2yrs old. Can you replace just the basket and tubes? Tubes welded in. Will I be forced to replace entire unit?
2 Suggested Answers
  • 77 Answers
SOURCE: flame not going into heat tubes
Make sure the regulator assembly on the gas valve is for propane. Sounds like the gas pressure is too low and the flames aren't going into the burner tubes. Make sure they didn't install an appliance regulator on the back of the fryer. This is not needed as the fryer has a regulator on the gas valve. You can unscrew the cap on the regulator assembly and turn the plastic screw inside all the way in. DO not turn with alot of force. Easy does it.
Tom
Posted on Aug 16, 2010
Have a overhead natural gas Hot Dawg heater, came with garage no previous owner help, no book it is a 48000 btu I believe. Prevoius owner had done some painting and heater had paint residue on it. I tried...
Remove all the burner tubes. Get a soft bristle brush and clean the orifices real good for each burner. Then remove the rust from all the burners with a wire brush and blow them out. That is what I would try first.
Nov 06, 2011 | Marvin Overhead Workshop Heat And Light...
Distorted sound on my LG 42LG50 HD LCD TV. Has been repaired 3+ times under warranty, with no success. LG refuses to replace, since it is now out of warranty, though problem persists beyond the warranty...
Ur last chance,might be the power supply board,could have very small amount dip current going through ur tv main Tuner board causes this problem.We might be fishing here,but this is the only logical answer left.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power suppply for the replacement.
Dec 09, 2010 | LG 42LG50 42 in. LCD HDTV
Viking grill burner is clogged and fire is shooting out of knob. How do I clean my grill from excessive grease.
Is it still under warranty? I'd call Viking or a qualified repairman to fix it. If your burners are clogged, the flames should be coming out the venturi tube and flaming towards the gas valve knob. If the flames are coming out of the gas valve itself, then it will need to be regreased. If the burners can be removed without too much trouble, soak them in the sink with hot water and dishwashing detergent. Be sure to remove the knobs, so no one turns the gas on without the burners connected. If it's difficult, call a repairman.
May 12, 2010 | Grilling
I lost the foam from the back of my bindings
I would contact Drake/Northwave (i believe northwave owns drake now) and ask if they have replacements. If it is under warranty (usually 1-2yrs) they may be able to ship out a replacement highback as the padding is not usually designed to be removed
Feb 14, 2010 | Winter Sports
20f514td rca has no focus.
Either the flyback or the picture tube is bad. It's usually the tube that causes this problem, but sometimes the resistors in the flyback fail. Since it's such a small set, you probably would be better off replacing it than putting money into repairs.
Mar 04, 2009 | RCA 20F514TD 20" TV
Burner not working
try to clean the injector if no gas came out.or try to use matches to have a flame, i think there a problem in ur spark igniter if the gas is going out.tnx
Nov 22, 2008 | GE 30 in. Profile JP350 Electric Cooktop
Error code f13
There is a small thermostat button ontop of the Heater mechanism which has tripped . It has either a red dot or blue dot ontop. Use a pin or opened up paper clip and push through the red wax. It will go click and it is reset. .
It sometimes trips out with a F code which normally trips the machine off because it thinks the Heater unit is on fire.
There is a small disk which costs about £15 to buy which you can change. You will need HEX screwdriver set to change and open up the Heater matrisx to clean the fluff off the element.
Sep 10, 2008 | Hotpoint Aquarius WD640 Front Load...
1/2 of burner works
The burner is bad and needs replaced. Broken coil in the burner causes this. Check your owners manual because most come with a 5 year warranty on the burners.
Nov 02, 2007 | Maytag MES5870A Electric Kitchen Range
CD Drive not Ejecting properly
Hi, Since the warranty period has expired I will assume that the CD/RW has been in use for some time. Normally a small belt powered by a motor drives a gear that slides the tray out. Sometimes this belt is loose, warped or plain cut. Replacing the belt should solve the problem. You have to open the CD and it is near the front just below the tray. In other instances, the grease on the toothed railing at the sides and/or underneath the tray gets gummed up, cleaning and repacking with new light grease should take care of that. Rarely (but still does happen), the motor itself burns up and replacement (if you can get the part) is in order. An interim fix is to push a small straightened metal paperclip at a small hole below the tray cover/lip and slightly push till the tray partially opens. You can then manually pull it out. Hope this be of some help/idea to you. Good luck and kind regards.
Aug 27, 2007 | Samsung (SH-W08AENB) DVD±RW Burner
Imperial EFS-40 - Gas Elite Deep Fryer - 40 Lb - Tube Type - 15-1/2" Wide Logo
71 people viewed this question
Top Imperial Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Paul Carew
Are you an Imperial Kitchen Appliances - Other Expert? Answer questions, earn points and help others
