Question about Kitchen Ranges
Plug ins are not working on one whole wall
I have one whole wall that all the plug ins are not working. I went to breaker box nothing was flipped. I did just try all the one's related to anything in the kitchen or near kitchen just to see, but nothing is working.
    New Friend:
  • 62 Answers
If its not a ground fault outlet. Have one of the non-working outlets been broken ? Maybe cracked ?
most outlets are wired in series and a bad outlet may break the rest of the out lets in the series.
If you know which one it is you can change that outlet and it should bring the rest back up too.
Posted on Apr 01, 2015
    Habit-Forming:
  • 158 Answers
Is there one of them (maybe even in another room close by) that has two small buttons on the plate that say "test" and "reset"? If so, press the test, then press the reset button. That might set the ground fault interrupter circuit back on. The button should pop out when you press test, then go back in when you press reset.
Posted on Mar 30, 2015
Testimonial: "He fixed my problem and didn't have to hire an electrician."
  • Jerry Z Apr 01, 2015
    Thanks! I'm glad that was it...
My 36” Electrolux glass cooktop just stopped working. Was boiling eggs & noticed it wasn’t working so checked breaker box. I flipped breaker off for 30 sec & turned on to no avail.
The breaker can still be the problem. The way to prove it is to measure the voltage at the wall plug where the cook top is plugged into the wall. Unplug the cook top and look at the pattern the plug contacts make. Should look something like a Y. Using a volt meter set on AC and 240 volts put one lead in the bottom leg of the Y and the other lead on one of the other leg contact. You should read 120 volts on each leg. If one leg has no voltage, replace the breaker in the panel. If the voltage is present on both legs of the plug then the breaker is good and the problem lies in the electronics of the cook top or perhaps a burned out heating element.
May 27, 2018 | Electrolux Cooktops
You need an electrician it can be the breaker or the power feed to or out of the breaker or ground
Mar 30, 2015 | Kitchen Ranges
My dryer came on then within five minutes went off and won't come back on.
If it was on and then cut off I would first check the breaker in the electric panel (breaker box) in the home. Even if it looks on alot of times it's not so flip it to the off position then back on. If you still have the problem then check 1. "The receptacle" that is plugs into (the wall) and 2. Check the panel where the power cord/cable wires up to the dryer. For #2 check Google and YouTube make sure to type the right model number with the "How To"
Jun 10, 2014 | Dryers
I need a owners manual for a Sunquest Pro 24 RS, Wolff Systems tanning bed
Have a trained technician to look at it. You probably have a loose wire nut in the wall box if it is hardwired or a loose connection on the wall receptical. The screws on the recepticals can come loose when pushing the receptical into the wall box. Most new construction uses plastic wall boxes so shorting out the receptical screws to the box should not be a problem. It is possible that the bare ground wire inside the box is hitting one of the receptical screws. If so, then push the bare wire away from the screws with an insulated screwdriver.
Jul 22, 2012 | Wolff Sunquest Pro 24RS 220 Volts
Power went out. Is there a way to reset it?
If all the power went out in your whole house, then you need to flip the main breaker switch off then back on again. This should restore power.
If only frig went out, then which secondary breaker switch is "triggered" and flip off then back on.
Dec 31, 2011 | Refrigerators
The ovan can not start
If your oven operates on electricity then carefully pull it out from the wall and make sure it is plugged in. If it is plugged in then locate your main electrical breaker box and find the breaker that says OVEN and flip it to the off position and wait 30 seconds, then flip it to the on postion. Go back to the oven and try it. If that doesn't work then I would need more info to help you resolve this issue.
Sep 14, 2011 | Ovens
Frigidaire fghd2433kf dishwasher. less than a year old. flashed PF. the power hasnt been off. now whole unit is dead. no lights or movement.
Hello bidness_67 please check inside of the sink cabinet look for a switch on the back wall. If there is one flip it. Many new building electrical codes require a switchto turn off power to the dishwasher. Sometimes when putting items in the cabinet the switch is hit unknowingly. If there is no switch check outlets (the GFCI ones)and press the reset then check the dishwasher.if not those two items check breaker box for a tripped breaker.
Aug 15, 2011 | Frigidaire FGHD2433KF Builtin Dishwasher
It hasn't been used much and a couple of months ago it ran just fine. I went to do a load of dishes and it is just dead. Nothing is working. I flipped all the breakers to see if that was the problem and it...
flip every wall switch in your kitchen,while having door latched and turned to a run mode of some sort.be sure to check under kitchen sink for any hidden power switches as well.8 out of 10 ge d/w with this issue usually revert back to a wall switch
Nov 13, 2009 | GE Nautilus 24" Built-in Dishwasher
My gargabe disposol won't turn off.
sounds like the wall switch needs to be replaced.
Apr 05, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Can't get my Asko D3232 to start
Try flipping the breaker off and on. If that does work it maybe the control panel.
Sep 25, 2017 | Asko TouchProof D3232XL Stainless Steel...
Kitchen Ranges Logo
70 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
