Question about Amana Washing Machines
If you try to spin the drum by hand it will not turn but if you spend the belt the drum turns what is the problem Amana washer
  • Amana Master
  • 5,323 Answers
Try reversing the belt inside ut
Posted on May 08, 2015
Jimster
  • 240 Answers
SOURCE: kenmore washer
It could possibly be a motor coupler that has broke. Its a small rubber disk mounted on plastic drive joints. Its located between the motor and the transmission. This coupler is made to rip or break in case of something more serious, sort of like protection for the motor or transmission. Jim
Posted on Sep 07, 2007
srsrs_1999
  • 9 Answers
SOURCE: AMANA WASHER WON'T SPIN. HOW DO I REPLACE THE BELT?
is this a whirlpool built amana? if so, its most likely a direct drive model, and when it doesn`t spin its likely a coupling between the gearcase and motor assembly...youtube has videos on how its replaced, which isn`t too complicated to do...good luck
Posted on Apr 30, 2009
  • 64 Answers
SOURCE: maytag washer will not spin. motor overheats and drum won't turn
If it has a belt try loosening the belt and see if the transmission and pump will turn and are not stuck.
If they are they will have to be replaced. Try the motor and see if it turns freely with the belt loose or off. If they all turn freely check motor.
Posted on Jun 10, 2009
  • 574 Answers
SOURCE: Replaced broken washer belt, but drum still won't spin.
you may have a bad bearing in a pulley,could be motor coupling. Take belt off and spin motor shaft and pulley both ways if it's free, then its more than likely not the motor. Now spin the drum with belt off and see if it does the same as with the belt on if it does it has to be a bad bearing or coupling to the drum. hope this helps
Posted on Aug 24, 2009
Testimonial: "Thanks for your input. I'll look into it. If the problem is a bearing, is it an easy fix or should I start saving for a new washer?"
  • 410 Answers
SOURCE: washer will not spin out. Drum will not turn by
I am not a repair professional. I am a 78 year old man who has been making his own repairs for about 50 years. So the washer or dryer ID doesn't mean much to me. I came to fixya looking for a schematic for an really old AM/FM radio and found that more than 4,700 people were asking for help with a washer repair. I recently had a washer repair of my own and at that time I found an excellent video which showed me how to take my machine apart. This video made it possible for me to do my own repair. If you are repairing a dryer or a front load washer I suggest you
go to www.applianceaid.com where they have very good step by step trouble shooting and repair information on both washers and dryers as well as other appliances. If you have a direct drive top load washer and need help taking it apart this video is an early christmas present. I was so impressed with it that when I saw all these people needing help, I wanted to tell them about it. If you look at the back of your washer and the panel is solid (no small inspection plate to remove which would indicate you have a v-belt drive) chances are you have a direct drive and this video is just what you need. You can see it at www.acmehowto.com You will probably still need help in determining what the trouble is and how to fix it. After viewing the video or if you have a v-belt drive rather than a direct drive, I suggest you go to www.applianceaid.com where they have very good
trouble shooting and repair nformation on most
washers and dryers. I think you'll find what you need
there. Don't worry about the timer, they hardly ever
go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
Posted on Dec 05, 2009
What could possibly the reason my amana dryer wont tumble and just buzzes when you push the start button
Could be a broken belt spin the tumbler by hand it if it spins real easy the belt is off or broke another thing to try if you have resistance when turning the drum have a helper for this one open the door and hold the door switch in set timer to a cycle and press start while holding switch and buzzing spin drum and see if it will continue to rotate while holding switch if so motor going bad
Feb 17, 2015 | Amana Dryers
I have a frigidaire front load washer that I have spent over $375 to have repaired and it is still not working. It is not washing or spinning. It has water in it now. It comes on and just hum.
i just fixed the same problem on my machine. turns out my drum was jammed by a pair of underwear that made its way between the drum and housing. try turning the drum by hand. if it does not spin freely, take off the back panel and remove the belt. check the motor to see if that turns freely. if not,replace motor. if the motor turns, try turning the drum by hand (very sharp edges, wear gloves) using the pulley. if something is in there impeding the spin, get ready to pull the whole thing apart. cuss a lot and have a great time
Mar 29, 2011 | Frigidaire ATF6000ES Front Load Washer
Front loader washer machine not rotating.
Fisrt, see if you can rotate it by hand, BOTH directions. It should have some resistance. If you can spin it and when you stop pushing it will turn a full turn, your drum belt is too loose. If the belt is good and tight, it will spin less than one half rotation, there is probably something blocking one of the wheels that the drum rides on.
Nov 16, 2009 | Frigidaire GLTF2940ES Front Load Washer
Aug 24, 2009 | Amana ALW480DA Top Load Washer
Washer won't spin, motor sounds like its working, belt is fine...what do I check or do?
The belt may look fine, but if the motor is spinning, then the belt isn't transferring the motion to the drum.
First, make sure you can turn the drum by hand. Turn off the power. Reach inside the drum, grab the opposite sides and turn. If it moves more than a few inches, then it isn't the drum that's stuck. Possibly the belt tensioner has slackened and needs to be adjusted.
Jun 25, 2009 | GE WBSR3140DW Top Load Washer
Maytag washer will not spin. motor overheats and drum won't turn
Jun 09, 2009 | Maytag Atlantis MAV6000 Top Load Washer
DRUM WILL TURN TO EITHER WASH OR SPIN CLOTHES
your belt has probably fell off the back of the drum try turning the tub by hand see if you can hear the motor turning with it
Mar 31, 2009 | GE WSXH208A Front Load Washer
Washing Machines Logo
49 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
