Question about Radio Shack Pro-2018 Scanner
Clunking noise when going over bump - Radio Shack Pro-2018 Scanner
Clunking noise going over bumps
Could be a ball joint or the strut.
Mar 04, 2014 | 1998 Buick LeSabre
Front end clunking sound
check the drop links they don't like bumps. fitted to the anti roll bar and the strut ( suspension strut ) change both side at same time. to check it is these grab it and pull about if it feels like its moving easy then replace. should be stiff and no movement when pulling. these make a clunking sound when they go.
Feb 05, 2018 | Honda CR-V Cars & Trucks
2005 equinox devolped a clunking noise in front end when driving along and turning corners. Could it be strutts or shocks. Has 44,000 miles on it.
Not likely more common for sway bar links. The upper and lower portion of the links become loose and cause a clunking noise turning or over bumps. They are also known for the lower intermediate steering shaft. This is more common and noticeable just turning especially in parking lot maneuvers (not going over bumps).
Feb 26, 2011 | 2005 Chevrolet Equinox
I have a dodge magnun and have replaced the front linkage to sway
check the frunt break pads if the pads were ever replaced by aftermarket pads they will make a clunk sound going over bumps
Jul 10, 2010 | 2005 Dodge Magnum
Clunking going over bumps
shocks my be going bad push up and down hard on top of the car over each front wheel and let go..it should not bounce up and down more than once. if it does shocks are bad.
Apr 08, 2010 | 2000 Chevrolet Prizm
Clunking noise front passenger when i hit a bump
It's unlikely to be a ball joint on an '05. Make sure the mechanic jacks the car up under the lower control arm then checks radial and axiel (up and down). The sway bar links are bad about making noise.
May 19, 2009 | 1992 Honda Accord
Clunking noise when i go over bumps
have it put on a lift and the shocks and struts checked, they may be loose or defective.
Apr 22, 2009 | 2005 Chrysler Town & Country
I have a2001 cherokee sport changed upper &lower ball joints,shocks sway bar end links and bushings. rear shocks,sway bar end links & bushings also,but i still get a clunking noise in the rear of...
Clunking noise in the rear of the vehicle is a broad statement. When is the vehicle doing it? Is it all the time or just over bumps? Is it happening only going around curves? Is it a constant bump that speeds up and slows down with the vehicle speed. You would be supprised how many clunking noises can come from the driveline not the suspension. It could be anything from a bushing to your rear differential getting ready to grenade.
Nov 14, 2008 | 1996 Jeep Cherokee Country
Clunk noise from front left suspension
My guess is a strut bushing/bearing, but have your front end checked out by good shop to make sure it isn't something else more dangerous.
Sep 09, 2008 | 2005 Pontiac Grand Am
Radio Shack Pro-2018 Scanner Logo
141 people viewed this question
Top Radio Shack Radio Communications Experts
Jason
john milligan
Steve
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
