Question about Kitchen Ranges
I have one whole wall that all the plug ins are not working.
My gas stovetop is included on the wall. I went to breaker box nothing was flipped. I did just try all the one's related to anything in the kitchen or near kitchen just to see, but nothing is working.
  • Steve Butterworth Mar 30, 2015
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Sergeant:
  • 244 Answers
You need an electrician it can be the breaker or the power feed to or out of the breaker or ground
Posted on Mar 30, 2015
Miele 212 oven does not work. We have a Miele oven that does not work anymore. 220V gets to the oven and then nothing happens, no lights, no display, nothing... Advise anyone?
Nothing Works, or the Oven / Range / Stovetop Works Only At Certain Times:
1.Home breaker flipped or the fuse blown?Possibly an electrical surge has flipped the breaker. Check your breaker or fuse box and replace or reset as necessary.
2.Power cord plugged in?Grab the plug and wiggle to determine a good connection.
3.Power cord damage?Damaged rubber with wires showing through or the wire is being pinched can cause issues. Electrical tape is acceptable for covering damaged wires.
4.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
5.
6.Even a bad relay door switch will hinder your oven from operating.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
May 18, 2015 | Miele Ovens
Plug ins are not working on one whole wall
Is there one of them (maybe even in another room close by) that has two small buttons on the plate that say "test" and "reset"? If so, press the test, then press the reset button. That might set the ground fault interrupter circuit back on. The button should pop out when you press test, then go back in when you press reset.
Mar 30, 2015 | Kitchen Ranges
Troubleshooting power issues for whirlpool accubake double oven
5.Even a bad relay door switch will hinder your oven from operating.
Mar 02, 2015 | Whirlpool Ovens
Oven does not heat
Apr 18, 2014 | Frigidaire Ovens
No power after self cleaning
5.
Dec 14, 2013 | LG LWD3081ST Electric Double Oven
I need a owners manual for a Sunquest Pro 24 RS, Wolff Systems tanning bed
Have a trained technician to look at it. You probably have a loose wire nut in the wall box if it is hardwired or a loose connection on the wall receptical. The screws on the recepticals can come loose when pushing the receptical into the wall box. Most new construction uses plastic wall boxes so shorting out the receptical screws to the box should not be a problem. It is possible that the bare ground wire inside the box is hitting one of the receptical screws. If so, then push the bare wire away from the screws with an insulated screwdriver.
Jul 22, 2012 | Wolff Sunquest Pro 24RS 220 Volts
The ovan can not start
If your oven operates on electricity then carefully pull it out from the wall and make sure it is plugged in. If it is plugged in then locate your main electrical breaker box and find the breaker that says OVEN and flip it to the off position and wait 30 seconds, then flip it to the on postion. Go back to the oven and try it. If that doesn't work then I would need more info to help you resolve this issue.
Sep 14, 2011 | Ovens
When i plug in my kenmore stovetop the other electrical outlets trip, i unplug it and reset the outlets and the outlet works but i can't use the stovetop unless i light the gas with a match now. what is my...
you, or your electrician has pulled power from one of the gfi outlets to power the electric sparker on the stovetop. If you can figure out which gfi that the power was pulled from, open up the box and find the wire that runs to the stove and remove it from the gfi outlet and connect it to the power before it goes to the gfi.
Dec 26, 2009 | Gb Electrical 1 30 Amp Ground Fault...
Electric oven and stovetop do not work, clock and oven light do.
Sounds like you are only getting 120 volts instead of 240 volts. Either a house electical problem or wiring in range. First go to your breaker and turn it off and on three times and give it a little extra push each time you flip it. ( You can actually flip a breaker off and on without resetting a blown breaker if you doni't push it all the way off and all the way on. If the breaker throws itself off do not reset it. You have an elecrical short in your house or range. If resetting the breaker does not work then you need to test for 240 volts coming into the range. We don't recommend you do any electical testing unless you know what you are doing with electicity. If you have 240 volts going to the range then unplug your range and remove the backing panel off the back of the range. Look for burned wiring or terminal blocks. If there is nothing obvious then you need to know how to read a wiring schematic and use a electical tester to go any farther. Let me know if this helps. Good Luck, Appliance Specialists
Dec 15, 2009 | Amana AER5715QAS Electric Kitchen Range
Kitchen Ranges Logo
65 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
