Question about Whirlpool Refrigerators
Refrigerater light not working on whirlpool gold
  • 937 Answers
Turn power off, remove bulb and use a battery and piece of wire to check if it works OR use a circuit tester to check if there's any electrical resistance (if yes, bulb is shot and needs replacing) otherwise replace bulb and turn power back on.
Does the light normally come on when the door's opened? If it does then there's a switch that opening the door MUST operate. Find it, and with the door open, operate the switch. The light should turn on &off. Clean the switch - often fail with time and a buildup of gunge.
Posted on Mar 30, 2015
HOW TO CLEAN COILS BETTER UNDER MY WHIRLPOOL REFRIGERATER ?
It's messy (REALLY MESSY), but I just use my shop vac and put the hose on the blow side. With the crevice tool it creates a lot of velocity and the coils clean up really well.
Dec 20, 2014 | Whirlpool Refrigerators
Dish washer lights dont work and will not run
Prabably no current running throught the dishwasher or a breaker or
somethings disconnected also the button or turn on or off switch mmay be bad
Aug 23, 2012 | Whirlpool Gold Series 24" Tall Tub...
My refrigerater is still iceing up ,in the freezer part,causeing the refrigerater too be warm ,and i have already changed the heater and the thermostat.
if you have a full freezer and a not so full fridge a brand new one will do that but check your door seals as well
Apr 23, 2012 | Refrigerators
My whirlpool refrigerater is not cooling properly, the freezer is working but the fan in back turns freely by hand but I haven't seen it actually start by itself
replace fan motor. same thing happened to me but I can't see other end of fan wires.I will have to cut and solder wires for new fan...I have question on how to get that darn relay box off compressor to see where condenser fan wires go!!!
Jan 28, 2012 | Amana ATB1832AR Top Freezer Refrigerator
Refrigerater is not cooling
The refrigerator gets air from the freezer. Look in the freezer for frost. If you have frost in the back or bottom the you have a defrost problem. Could be a timer or heater that is bad. If no frost do you hear a fan? You should have a evaporator fan running. Maybe thats out and it not circulating air for the refrigerator. You can check this out.
Hope it helps
Aug 17, 2009 | Whirlpool Refrigerators
Whirlpool gold
First press your "Sani-rinse" button and the your "Heat Dry" button and toggle between them a couple times. This will reset your control module. If the clean light continues to blink then it means that your heating element needs replacing.  This is not a big job, either. You will need to order a new element and come back for instructions if you can't figure it out quickly....
Dec 16, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool gold self cleaning oven
is it screwed all the way in??Using a meter test the bulb socket for power.If its showing no power check the light switch
May 20, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
60 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
