Question about Home
Looking for a toilet tank by Orion nivel stamped on the inside circa july 1987
I need this tank or a replacment tank that will fit
  • 10865 Answers
SOURCE: toilet tank replacement
I believe you will find it cheaper to replace the whole toilet. good luck
Posted on Jan 24, 2009
  • 10865 Answers
SOURCE: elongated toilet doesn't fit where a round toilet was installed
Hi. There are toilets designed to accept a round seat and there are other toilets designed to accept an elongated seat. The primary difference is that the round seat fits a round bowl and the elongated seat fits an elongated bowl.
I recommend that you return the elongated seat and exchange it for a round toilet seat. good luck
Posted on Jan 31, 2009
whytfang
  • 170 Answers
SOURCE: correct tank to bowl gasket for Orion toilet
I would change out the flush valve itself...it will come with the right gasket....it won't cost anywhere near the price of a new toilet...and it will save you time in the long run..good luck and.thanks for rating my effort....the fang.
Posted on May 01, 2009
bearsfan7538
  • 119 Answers
SOURCE: need diagram of toto toilet tank inside have
You need to replace the fill valve
Posted on Nov 15, 2009
jyackle5
  • 8197 Answers
SOURCE: My Pegusa toilet tank is
You can get the tank from the link below.
http://www.google.com/products?hl=en&q=pegasus+toilet+tank&wrapid=tljp128543491589019&um=1&ie=UTF-8&ei=MS6eTMLvMoH6sAPN65TWAQ&sa=X&oi=product_result_group&ct=title&resnum=3&sqi=2&ved=0CEcQrQQwAg
Good Luck and please accept my answer
Posted on Sep 25, 2010
Where can I find replacement parts?
home depot etc, most hardware stores.
Mar 30, 2012 | Home
Orion toilet, the tank to bowl gasket leaks
turn off the water,, flush the toilet ,, using a rag or paper towels sop up the remaining water in the tank, ( if you hold the flush valve down more will exit the tank) remove the water inlet tube, remove the 2 or 3 hold down bolts that have a slotted screw head inside the tank, and a nut on the underside of the bowl, use care in lifting the tank off the bowl section, as they are normally a matched pair and most aren't interchangeable, on the underside of the tank you will see the bottom of where the flapper attaches,, at that point will be the gasket that needs replacing, remove it, and install the new one, reverse this order to re assemble,, NOTE, you don't have to tighten the tank bolt very much,, snug is better than over tightening, the tank will crack if you over tighten the tank back on the bowl, so use care in this step, I always replace the tank bolts at the same time,
Sep 10, 2011 | Home
When I flush, I believe the flapper is not seating correctly inside the toliet because the pump runs ocassionally!?!? Any suggestions?
Those flappers need to be replaced regularly. They are available at many store like Home Depot or Lowes Make sure to get the make of your toilet and maybe even the number of the tank. It is stamped on the inside of the tank.
Then buy a new flapper and replace it, it is easy!
heatman101
Apr 20, 2011 | Saniflo Home
I am looking for a gasket between the tank and bowl which is leaking. I only have the number stamped on the inside of the tank which is BN30 BN31. Can you tell from this lid number which model toilet...
It looks like you have a Jacuzzi Perfecta.
This model came in two flavors:
  • the 300 MaP flush performance (with an elongated bowl, #BN30959), and
  • the 350 MaP (with a rounded bowl, #BN31959).
Both use the BN30 BN31 tank.
If you have trouble finding a gasket, you might consider using plumbers' putty.
(Sometimes, the old ways are the best...)
Mar 03, 2011 | Jacuzzi Bath Era BK37 959 White toilet...
The black bend and arm that goes inside the tank does not fit in my TOTO Carlyle toilet. Can I get a smaller bend, or different piece to go inside the tank? The lever installs on the end of the tank, not...
the reason it doesn' t fit is cause for a toto side mount you need a specific handle for that type of toilet. the universals don't fit that. you can go to a plumbing supply house to get the right handle or you'll have to go on line or contact toto directly.
Nov 16, 2010 | Moen Accessories Decorative Tank Lever -...
I have Kohler toilet ...I believe it was a Rialto model....the numbers inside the tank are T33 K2402P3 ...
picture is of a kohler rialto
looks like you can get the parts or retro fit newer kohler flush parts
ring around for a plumber or kohler toilets seller that can supply kohler cystern parts
Apr 28, 2017 | Home
CAN'T IDENTIFY THE MODEL OF MY TOILET AND SEAT
Look inside of the tank the number will be stampes into the porcelin of the inside of the tank...
heatman101
May 26, 2010 | Kohler - Toilet - One-piece - Santa Rosa -...
LOOKING FOR GASKETS & BOLTS BETWEEN TOILET & FLUSH BOX
go to any howm center, plumbing section. The replacement gasket is not the same as the original, however, they do fit. The other choice is go to Kohler resaller.
May 20, 2009 | Kohler Home
Correct tank to bowl gasket for Orion toilet
Apr 20, 2009 | Home
Square toilet seat made by American Standard Model TL 235.
This guy Allen in NY has lots of odd seats. Try him 914-963-6895
Jan 06, 2009 | Home
Home Logo
69 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
