Have you used the HDMI cable with the PS3 before? it may be configured to use the AV connection. If so plug in an AV lead, then you would need to find in the settings to change the output to HDMI.
The HDMI cable may not work
Press windows key and P to switch between monitor modes
This works: Turn ps3 on. Plug the controller into the usb cable and into ps3. Then plug the dongle into other usb port. After a short time the dongle will flash quickly (this means it's in pairing mode - when the dongle flashes slowly it's too late). Press the PS/Home button as soon as you see the dongle fast flashing. All the LED's on the controller will begin to flash and after a short time one (or two) will remain solid. Immediately disconnect the charging usb lead from the controller and again the LED's will flash, push the PS/Home button again and after a short time one or two will remain solid. The controller should now be working. If the controller fails to respond repeat this process but make sure that you disconnect the dongle and reinsert (so you can see the fast flashing lights and try again).
Did you try holding down the Power button until you heard 3 beeps? It is not uncommon for the video output to exceed the resolution of different television. This hard reset feature was added to troubleshoot such a problem, factory resetting the video settings.
