Question about Kenmore Washing Machines
Kenmore elite he topload washerIts weird..sometimes it will power on.sometimes it won't.sometimes when it does power on it won't let me choose type of load but sometimes it does n then sometimed it powers on n lets me select load but then when I hit start it won't start.but sometimes it works like nothins wrong at all.freakin has power cause in time display I very faintly see lines lit up
the dr
  • 447 Answers
SOURCE: Kenmore Elite Calypso Wash Motion
Basically its saying that the motor is pulling very high amperes. This could signify a faulty motor, motor controller, or thermal protector, or there could be a mechanical bind in the transmission. i would use a amprobe and check to see how much power is being pulled when the machine starts, and as it is operating if it is 5.55 amps or greater and higher than 20 amps on motor start surge, than the motor controller is correct in saying there is a problem. ------Dont forget to rate my help!!!!!! thanks
Posted on Sep 30, 2007
SOURCE: kenmore elite front load washer
Posted on Sep 26, 2008
  • 36 Answers
SOURCE: kenmore elite washer won't start
Dear Customer
Please perform the following
unplug the washer for 5 minutes and then plug it back in,This can resets the system
Please rate this,Thank u
Posted on Dec 17, 2008
  • 5911 Answers
SOURCE: My kenmore Elite HE3t Giving a code F 06
"F06" is a Motor Speed error code. This is an indication that there is a problem with the Drive Motor, Tachometer, Motor Control Unit (MCU), Central Control Unit (CCU) and/or interconnecting wiring between the all these components. The following link explains:
I would begin by checking all the connector plugs between the CCU, MCU and Drive Motor to ensure none of them are loose or have corroded contacts.
Read through the link and follow the steps provided. If you have questions, please let me know. I hope this helps.
NOTE: The majority of the time this failure is attributed to a bad tachometer which is located on the MCU. If defective, the MCU must be replaced. There is a technical data sheet that comes with the washer. It is located inside the washer behind the lower toe panel directly below the door. The panel comes off by removing the screws located under bottom front edge of the panel. With the screws removed, the panel will drop down, then come off. If the tech sheet is not located directly behind the panel, it will be affixed to one of the interior cabinet walls. Included are all the diagnostics and troubleshooting advice for your washer, including diagrams to show test points. HINT: For better access to the screws you can prop the two front feet of the washer up using a 2 x 4.
Posted on Sep 14, 2009
SOURCE: kenmore elite he3 - door lock
fdl error code on kenmore elite he4 washer. wont start after selecting wash cycle
Posted on May 02, 2010
Toploader kenmore elite oasis is showing F1 code for error. I do not have an owners manual. What does F1 mean?
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
Aug 21, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
My Kenmore TopLoading Oasis shreds my towels. What can I do to prevent this from happening?
Tighten the agitator. It has loosened up - allowing material to fit underneath.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 07, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Error F51 for Kenmore Elite Oasis Toploading washer??
bad main board or motor possitioner sensor.. most likely motor sensor.
China made junk parts with a million problems
Nov 21, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Just dead. Doesn't light up or start or respond.
You will need to replace the power supply most likely. If you can find a fuse or relay, check with an ohmmeter to determine that they are good. You can use a voltmeter to determine that there is power going to the control panel.
Jul 13, 2009 | Washing Machines
Kenmore top load washer won't drain
Could be the pump itself or the belt driving it... many of the older type washers run the pump off of a drive belt and many of these pumps get clogged with material so that they do not pump... usually, you can unbolt the pump and seperate the pump casing to access the impellor and clean out the insides.. As always.. be certain to unplug the washer first..
Hope this helps
Sep 21, 2008 | Kenmore Elite HE4 Electric Dryer
Microwave cycles off
Does this happen just at the full power microwave cook setting?
Have you tried defrosting and doe sit do it on this setting? Does it run any longer in defrost mode?
Dec 02, 2007 | Microwave Ovens
Open Questions:
Washing Machines Logo
42 people viewed this question
Sal De
 Brian Main
Brian Main
