LCD screen is cracked and computer has only 2.0 usb ports no HDMI or Bluetooth how can I connect to another moniter or LCD TV
Is it possible to install Bluetooth and connect that way to an LCD TV
  • Allan Clark
    Allan Clark Mar 30, 2015
    its a gateway all in one zx4250 ub380 and has no vga either
  • Allan Clark
    it is a Gateway One ZX 4250 UB 380 and only has USB ports no VGA, no HDMI, and is not Bluetooth equiped
    Master:
  • 496 Answers
No it is not possible this way. Look for a VGA port.
LCD screen is cracked and computer has only 2.0 us - 25618467-cbt13vi4zbmnff1d5zdl02jb-2-0.jpg Not always blue, but it has 15 pins. Your monitor or TV will need to have the same connection.
Posted on Mar 30, 2015
Testimonial: "this is an all in one computer and has no VGA port either is it possible to install Bluetooth and connect that way"
  • TechGirl
    TechGirl Mar 30, 2015
    As I said it is not possible. What is the exact model number of the all in one computer? Normally on the back somewhere. There will be some sort of VGA port...
Bought a new computer and it just has a usb type port how do I connect the moniter
Depends on the monitor does the monitor have a hdmi input port ?
The usb type port you describe - I suspect is a HDMI port.
The monitor I am guessing has a vga only input
as you did not provide us with the make and model numbers of any of your devices involved I can only guess on the situation ?
You might be able to go to a computer retailer and ask them about a HDMI to VGA adapter for your monitor if this is the situation you have
Jan 14, 2017 | Computers & Internet
Screen is cracked can it hdmi out to another moniter or lcd tv to be able to use
It it has an hdmi port on the computer, then it will work with a compatible monitor or lcd tv with HDMI. If it does not have an HDMI Port, then you will have to use some type of signal converter to get it to work with the other units.
Mar 30, 2015 | Gateway One ZX4250-UB308 ZX 1.6GHz 4GB...
I have a lead from my tv usb, to the samsung tablet, but i dont know how to get it to connect
Step 1 Connect one end of an HDMI cable to the Samsung Galaxy Tab HDTV adapter.
Step 2 Connect the other end of the HDMI cable to a free HDMI port on your television.
Step 3 Connect your Galaxy Tab's travel charger to the other end of the HDTV adapter. Plug the travel charger into a power source, such as an electrical outlet or a computer's USB port.
Step 4 Plug the HDTV adapter connector into the Galaxy Tab's "Power/Accessory Interface" port. The port is on the bottom of the device.
Step 5 Turn on the TV. If your TV has multiple HDMI ports, use the remote control to switch to the correct one. Press the "Source" or "Input" button on the remote to switch ports. When you're using the correct port, the TV will instantly display whatever is on the Tab's screen.
Feb 05, 2015 | Samsung Galaxy Tab 2 7in. WiFi Tablet, 8GB
Hooked hdmi dongle to projector. Used kindle fire hdx. Picture works fine but no sound from projector speakers. No sound from kindle speakers. Need to use kindle headphone jack for sound.
follow this steps and fix it. God bless you
Check the system requirements on the Bluetooth dongle. If your system does not fit all the requirements, the device is not going to work. The requirements for the Bluetooth dongle are printed in the user manual and packaging. You may compare this to what is running on the computer by clicking "Start," "Control Panel" and "System." This displays the hardware running on the computer.
    • 2
Disconnect the Bluetooth dongle, restart the computer, then plug it back into a USB port. If you power on the computer with the dongle already instead, the system may not detect the equipment. Restarting the computer and performing this action helps correct the problem.
    • 3
Remove the Bluetooth dongle from the USB port and plug it into a different connection. Some USB ports fail to detect certain computer hardware. Changing the connection port fixes this.
    • 4
Install the driver on the provided driver installation CD. Without the driver, the computer is unable to detect and use the dongle. Insert the driver installation CD into the disc drive of the computer, then follow the on-screen steps to install the driver onto the system.
Oct 29, 2013 | Brookstone HDMI Pocket Projector
Trying to connect hdmi cable to laptop to watch movies
Are you sure you have four hdmi ports? I have only one hdmi port and three usb ports. Be sure you are connected to the hdmi port and for some reason not a usb port.
Aug 17, 2012 | Sanyo DP46849 46 in. HDTV
How do i connect my acer z5600 to my hd tv
Inorder to connect computer to an LCD TV, you need a HDMI or DVI port on both TV and computer. You will also need a cable for them. You can check on the back of the computer and
TV for HDMI port, it looks similar to USB port. If it is there, then you may need a HDMI cable and you can connect TV and computer through it.
Thanks and regards,
Jitha
Dec 18, 2010 | Acer Aspire Z5600 PC Desktop
Where does the hdmi cable go on my tv
If you have an HDMI tv, and just because it is a wide screen does not me it is High Definition or HDMI compatible, you will normally find the connector on the back marked HDMI.
Not knowing what TV you have, I can't really tell if it is HDMI compatible or not, but you will know by the shape of the connector if it is.
Aug 27, 2009 | Televison & Video
Connecting PS3 console to a moniter
The manual should contain that, but yes if you have a HDMI port on your PS3 you can conect a HDMI monitor to it
Jul 16, 2009 | Sony Playstation 3 (PS3) Console
NO sound on HDMI3 port and when playing Blu-Ray DVD's the screen is pink
Go to the samsung website, and find out how to upgrade the firmware for your TV. You will probably need a portable usb memory stick to do so (if your TV is equipped with one). HDMI is an evolving technology, and firmware upgrades can resolve many of these quirky issues.
Here's a possibility from http://www.samsung.com/us/support/faqs/supportFaqList.do?group=&type=&subtype=&model_nm=LN-S4696D&dType=D&mType=UM&vType=R&prd_ia_cd=02010100&acc_ia_fl=&disp_nm=LN-S4696D
Which Samsung LCD TVs Have The HDMI 1.3 Interface? spacer.gif Of the LN-T series Samsung LCD TVs, those models whose last two digits are 61, 65, 66, 69, 71, or 81 (for example, LN-T4071F or LN-T466F) have the HDMI 1.3 interface.
Samsung LCD TVs with HDMI 1.3 interfaces also have HDMI-CEC (HDMI - Consumer Electronics Control). For information about CEC, click HERE.
For information about individual Samsung LCD TVs with HDMI 1.3 interfaces and HDMI-CEC, click HERE. When the Samsung LCD TV web page appears, select the TV model you want information about by clicking the drop down list under Product Finder on the left side of the page.
Though other series of Samsung LCD TVs (LN-R, LN-S, etc.) have HDMI connections, none have models with the HDMI 1.3 interface.
Feb 18, 2008 | Televison & Video
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
