Question about Kenmore Washing Machines
Kenmore Elite HE washer!!!!Its weird..sometimes it will power on.sometimes it won't.sometimes when it does power on it won't let me choose type of load but sometimes it does n then sometimes it powers on n lets me select load but then when I hit start it won't start.but sometimes it works like nothins wrong at all.freakin weird.please please please help.there is power getting to machine cause in the time display I can see lines very dimly lit up
  • Kenmore Master
  • 5,323 Answers
Lol sounds like a female to me.. Seriously think u may have a control board issue
Posted on Apr 20, 2015
SOURCE: kenmore elite front load washer
I HAVE A KENMORE ELITE WASHER AND IT STOPS IN THEN MIDDLE OF THE CYCLE AND DOESN'T RISNSE. THE DISPLAYS SHOWS F21. CAN YOU LET ME KNOW WHAT THIS MEANS?
Posted on Sep 26, 2008
duby1990
  • 370 Answers
SOURCE: Front Loading washer Kenmore Ht3
Here are the steps to unlocking the door manually if clothes are still in the machine.
1.Unplug machine
2.remove bottom panel
3.Reach up along the inside of the front panel and locate the botttom of the door latch assembly
4.Located on the bottom of the door latch assembly is a tear dropped shaped tab
5. Gently pull down on the tab about a 1/4 inch or until a click is heard.
6. You may now open the door.
This code means the door lock mechanism has failed or the central control unit has failed. Replace the door lock mech. first. This should fix the problem. (before replacing anything make sure there is no obstruction around the switch or in the switch.) After the machine has been unplugged it may fix itself. if not replace door lock mech.
Posted on Nov 21, 2008
  • 36 Answers
SOURCE: kenmore elite washer won't start
Dear Customer
Please perform the following
unplug the washer for 5 minutes and then plug it back in,This can resets the system
Please rate this,Thank u
Posted on Dec 17, 2008
jsrock516
  • 5911 Answers
SOURCE: My kenmore Elite HE3t Giving a code F 06
"F06" is a Motor Speed error code. This is an indication that there is a problem with the Drive Motor, Tachometer, Motor Control Unit (MCU), Central Control Unit (CCU) and/or interconnecting wiring between the all these components. The following link explains:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
I would begin by checking all the connector plugs between the CCU, MCU and Drive Motor to ensure none of them are loose or have corroded contacts.
Read through the link and follow the steps provided. If you have questions, please let me know. I hope this helps.
NOTE: The majority of the time this failure is attributed to a bad tachometer which is located on the MCU. If defective, the MCU must be replaced. There is a technical data sheet that comes with the washer. It is located inside the washer behind the lower toe panel directly below the door. The panel comes off by removing the screws located under bottom front edge of the panel. With the screws removed, the panel will drop down, then come off. If the tech sheet is not located directly behind the panel, it will be affixed to one of the interior cabinet walls. Included are all the diagnostics and troubleshooting advice for your washer, including diagrams to show test points. HINT: For better access to the screws you can prop the two front feet of the washer up using a 2 x 4.
Posted on Sep 14, 2009
  • 1937 Answers
SOURCE: I need a manual for Kenmore Elite HE4t front load
If you go to the following Sears site, click on "Manuals" and enter your model number, you should be able to get a PDF version of the manual.
http://www.managemyhome.com/
Posted on Apr 24, 2010
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
see this causes and fix it. God bless you
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Oct 05, 2012 | Kenmore Elite 45986 Front Load Washer
Kenmore won't fill with water
Make sure your water valves are turned on. Check for blockages in the rubber hose and especially where the water enters the washer. Sometimes the chack valve of a washer can collase and restrict the flow of water entering the washer. It is usually located just beyond where the hose connects to the washer. Metal screens can clog and stop water flow. Check and replace as necessary.
The electronics of the washer may also not be advancing to the point where it allows water to enter, The main dial may be faulty. Check and verify all washer settings also
Aug 04, 2012 | Kenmore 4.5 cu. ft. High-Efficiency...
How much does it cost to replace the rubberseal
Hello, Welcome to FixYa.
Hopefully the info below will supply you with the assistance to get the door seal your enquiring about. They should have anything you need. (provided the numbers in your post are accurate "45986"...though the complete number should be on the tag inside the door opening of the washer.
http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-elite-Parts/Washer-Parts/8182119/0026/110/Model-11045986400/0583/0153200?keySuffixId=NA&pathTaken=partSearch&pathRender=modelComponent&documentCompId=K0503012&diagramPageId=00002&productTypeId=x&searchModelNumber=11045986400&subCompDesc=Door%20and%20latch%20parts&brandDesc=KENMORE ELITE&modelDesc=RESIDENTIAL-WASHER&blt=11
The gasket/bellows is part number 8182119 and sells for around $100-$110US. The cost to install will vary on how it's done and by whom of course.
Thank you for choosing FixYa. Please take a moment to rate the assistance you received here today and good luck.
Regards,
Macmarkus :)
Aug 14, 2011 | Kenmore Elite 45986 Front Load Washer
I plug it in and it won`t turn on
A faulty door switch can cause this, You can test it with an ohmmeter. A faulty control panel can also cause this. Also a faulty fuse or power supply which can be tested with a voltmeter to make sure it is getting power.
May 03, 2010 | Kenmore Elite HE5t Washer
Kenmore elite calypso wash motion top loader won t come on at all after power outage. checked breaker and outlet.
Unplug the unit and let it sit unplugged for 30 minutes. There is a power filter on the AC input line and sometimes power surges can cause it to need to bleed off the voltage from capacitors. There is a test procedure to see if the filter needs to be replaced but so far every time this has happened to our Calpyso, we pull the plug for a bit and the washer recovers.
There isn't enough space on this text box to post the removal & replacement procedure for the line filter, but you can find it at www.pcappliancerepair.com and look up the part # on the Sears Parts Direct site for your model # specifically.
Sep 20, 2009 | Kenmore Elite 21086
Kenmore Elite Catalyst Washer Keeps beeping and displays 10
I'm not sure if you've solved this already but our Kenmore Elite washer had a similar problem that got worse. It ended up being the whole touch panel had to be replaced. I was able to diagnose and replaced it myself with help from the Tech sheet that is underneath the touch panel. Our Kenmore Elite dryer also had to have this paenl replaced several years ago when it was fairly new. Hope this helps.
Sep 08, 2009 | Kenmore 3.2 cu. ft. Top Load Washer
How do i turn on the kenmore elite He4T washer, it does not turn on
shut door,choose setting then hold start button for a few seconds.if it doesnt start check and make sure water is turned on.
Mar 10, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Catalyst Mod. 22052
Oil is no problem. The door switch/interlock is faulty. Replace door interlock. Try closing the door firmly with an extra little shove on the door handle. Sometimes this works.
Oct 30, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washer 26922
I would take body of washer find out where noise coeing from.. got 2 screws in each side of head, flip head up and take clamps off .. pull whole body off washer run thu cycle and see if ya can locate the noise.. sometimes water pumps get something in them that well make weird noises.. but are in all cycles.
Sep 07, 2007 | Washing Machines
Washing Machines Logo
47 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
