Question about GE Microwave Ovens
How do I replace the keypad on GE Spacemaker microwave model #JVM1650CH01?
  • GE Master
  • 473 Answers
The keypad is usually glued to a metal plate to give it support. You have to remove the complete control panel to replace the keypad. Remove the top grill across the top pf the micro. Make sure the micro is unplugged. Next, there should be 1 screw going through the top plastic of the control panel. Remove screw and then lift gently up on the complete control. It is tabbed into the micro body. Once lifted it should pull forward and hinge downward. You will now see the back of the main control board with wires and plugs. The best way is to make notes or take a picture of all the plugs before you remove them. Unplug all the wires and you should be able to lift the control panel off the micro completely and lay it face down on a table or workbench. You will see several small screws holding the main board in place and a flat ribbon connector about 1.5 inches wide going to a connector on the board. To remove that ribbon, lift gently up on the ends of the connector. It should lift about a 1/4 inch but will not come off. Once it is up the ribbon will pull out. That ribbon is the touch pad connections to the main board. Play with the old ribbon a few times getting it in and out. Now remove the main board and lay it aside. You can now see the metal box like bracket the touchpad is attached to. It is just held in place with plastic tabs on the control trim. Gently pry the tabs back while you lift out the metal box. If your new touch pads have the metal box just reverse the procedure to reassemble. If your touchpads are not on the metal box frame, you need to pull off the old one and carefully align the new pads to the metal frame. They will be self stick. Sorry this is so long but it needed explained. Most people can't handle this type repair and need service. You will need to decide.
Posted on Mar 30, 2015
I have a 2003 GE Spacemaker model 2.0 (JVM2070WH001): the touch pad has stopped responding to any input. Can it be fixed?
Yes! but the whole keypad control or smart board will need to be replaced. I highly recommend a professional for this job and do a spot check on the rest of the unit.
Apr 01, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
I have GE microwave oven model JVM1740DM1WW-1000W. the key pad 1 to 6 on express is not working. all other key pad works. how to troubleshoot this problem?
you can try removing the outer cover and being careful,check all ribbon cables to the keypad by removing if they are plugged in and not soldered to the keypad circuit board and re plugging them back in,if this doesnt solve the problem you will need to replace the keypad board
Aug 07, 2011 | GE Spacemaker JVM1740 Microwave Oven
What is the wattage of my GE Spacemaker Microwave JVM1650CH01?
The owner's manual (online here) doesn't list that, but the specs found here say it's 1000 watts.
May 24, 2011 | GE JVM1650 1000 Watts Microwave Oven
I have a GE Spacemaker microwave, Model #JVM140H 002, manufactured March, 1990. Sometimes when it is cooking, it switches to a "timer" mode. Other times, I cannot get it to cook - it just goes to...
The problem is in the keypad controller, the microprocessor is mounted on a circuit board along with other parts behind the keypad. Now if this can be repaired it will come down to the availability of a replacement keypad module, you would need to check with the manufacture to see if they carry any stock and price. There might be a possibility that a appliance repairman or tv technician may be able to repair the module if replacement is not available.
Jan 26, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Microwave Model JEM31SA, intermittent problem with keypad going dead after cooking. Have to go out and flip breaker to reset. It prompts for clock set info and functions normally again after...
You're going to have to replace the keypad module and possible the control module (do the keypad first). You can try contacting these folks: http://www.appliancepartspros.com/search.aspx?model=jem31sa%20001%20ge%20spacemaker%20microwave
And see if they have a keypad for your unit. Depending on the age of your microwave, you may be best off replacing the whole microwave.
Aug 29, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL Microwave Oven Model
Your membrane keypad is wearing out.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
The keypad is part number WB27X10171 and you can get it here for $91.68 plus shipping.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs nationwide.
Jan 30, 2010 | General Electric Microwave Oven
I have a GE Spacemaker model #JVM1650CH01 that keeps on shutting off everything after a few seconds. I have to rest the clock and month -year - date to try again.
my spacemaker xl jvm 1650 microwave shuts down after just a few minutes of operation and after a few minutes needs to have a clock/time/day etc reset. is this reparable by a homeowner?
Oct 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1540 keypad only works for some buttons
Membrane keypads are not very durable, and do fail after a relatively short time.
The only method is to replace them as a spare part.
Aug 20, 2009 | GE Spacemaker JVM1540 Microwave Oven
Microwave Ovens Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
