Question about Toro Garden
I have a toro zero turn z4200 starts and runs fine but when I put arms in gear, it will not move forward or backward.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    New Friend:
  • 91 Answers
Make sure the drives are engaged. Under the seat and towards the rear are two thin metal levers with finger loops. These are used to disengage the drives in order to push the mower when the engine is off. Levers towards the back to engage.
Good luck
Posted on Apr 09, 2015
  • 85 Answers
SOURCE: The motion control levers became tight to move and
You may have some bent or out of adjustment linkages, causing the brakes to stay on.
Or the friction nut (one on each transmission) is too tight. These are located just in front of the axel, they go through a slot, the washer behind the nut should turn freely
Posted on Aug 17, 2009
SOURCE: will not move
The transmission is shot. A common problem. Mine died after 3 years and 200 hours of use. Estimate to fix was almost $2000. I scapped it and bought a better mower. There was a rtransmission design defect in the RZT series.
Posted on Jun 21, 2010
  • 8 Answers
SOURCE: My zero turn Toro dont want to start, the battery is good and starter
On mine the arms have to be out the blades have to be off and the parking brake has to be on for it to start hope this helps.
Posted on Jun 06, 2012
SOURCE: My toro zero turn seems to overheat and stops moving from left side about half hour it runs fine.?
First check to see if you have any leaks especially on the problem let side. This includes the wheel motor. where hydro oil comes out, air can go in. either way it sounds like you need to take your pump out and open it up and check for metal inside. If you do not have any metal inside check the 5 pistons to see if they are stuck. What series hydro pump do you have?
10L 10A etc.
Posted on Aug 06, 2012
Testimonial: "Thank You very much for your support on this matter. "
mirab327
SOURCE: My 42" toro zero turn
the drive belt pulley probably needs replacing or the belt popped off the pully
Posted on Aug 08, 2012
Timecutter z4200
If you were able to jump start mower then the problem lies with the battery connections or battery itself
Jul 11, 2014 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Toro Z4200 hdro won't stay in neutral
Your throttle csble is stretched it needs a new one
Dec 15, 2013 | Toro Garden
Toro Z5000 won't move
did the belt break or fall off? are the trans release levers pulled out ?the ones you release to push it around
Apr 14, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
My Toro Z4200 will not turn when i engage gear on my right hand, machine sat all winter in my garage, replaced battery, which i can understand, but why did the hydro-gear on right side quit working just...
Make sure the hydraulic transport bypass is not open. It may be that your belt idler is sticking for the drive system. Check under the machine and see if all the belts are tight. You might need to grease the idler arms.
See a local dealer like www.arcolawn.com for diagrams and parts.
Good luck
Mar 13, 2011 | Toro Lawn Mower With Toro Power Tools
Won,t move
Check the pump.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 20, 2010 | Husqvarna Zero Turn Mower Z5426
Garden Logo
890 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
