Question about Hannspree HF199H 19 Flat Screen LCD Computer Monitor
My monitor was working perfectly fine until I unplugged it to play on ps3 so when i did the ps3 wouldnt connect i tried holding down the ps3 button nothing so i plugged back into laptop no connection.
So far i tried to restart my pc with the cord plugged in also i tried to hold down ps3 power button.
    Master:
  • Hannspree Master
  • 496 Answers
Have you used the HDMI cable with the PS3 before? it may be configured to use the AV connection. If so plug in an AV lead, then you would need to find in the settings to change the output to HDMI.
The HDMI cable may not work
Press windows key and P to switch between monitor modes
Try those and post back if you need more help.
Posted on Mar 30, 2015
Testimonial: "Tryed still wont work, my power to my monitor is yellow and nothing is working i tryed everything is there any other solution?"
  • 3 more comments
  • christan
    christan Mar 30, 2015
    also i went to my laptop and tryed to detect a projector and says no detectable projectors
  • TechGirl
    TechGirl Mar 30, 2015
    Could just be coincidence that it died at that time. Take to a repair shop is the next step unfortunately. If the monitor is a few years old it may not be worth fixing because of the costs of labour to fix. A new monitor is the next thing.. you can pick up monitors cheaply anywhere
  • christan
    christan Mar 31, 2015
    Just plugged in with avg works
  • christan
    Just plugged in with VGA
  • TechGirl
    TechGirl Mar 31, 2015
    PS3 doesn't have VGA but ok good
I have a goodmans TV is having issues, sky box works fine through the hdmi but, ps3 no display or sound through the same port, my ps4 gets pic but no sound, both consoles have been tested on other tvs
1.Put your PS3 on standby.
2. Unplug the power lead.
3. Connect HDMI cable to HDMI out on PS3 and HDMI in on TV
4. Connect PS3 so that the red standby light is showing
5. Hold down the On/Off button until you hear a second beep. The PS3 will try and detect the display output settings on your monitor.
Dec 02, 2015 | PS4 Video Game Consoles & Games
My son recently took his playstation to a friends to play. Friends TV did not have HDMI connection so used the scart lead. In order to get it to work we had to hold the power switch down to "OFF"...
well this a common problem and the solution to the problem is as follows:
Turn off the power to your PS3 and then turn it back on again. But when you turn it on, hold down the power button until you see something on the screen. When you hold down the power button of the PS3 when you are turning it on, it completely resets the video settings to the most basic settings (480p I think) so that it'll work on any TV or monitor. Once you can then get something on the screen, you can configure the video settings to match the TV you are hooking up to.
hope its helps, thanks
Jan 11, 2011 | Sony Playstation 3 (PS3) Console
I unplugged my ps3 to put it into a different room and it worked fine, then i put it back in my room and now it comes up with a blank screen?
Connect your controller into the USB port and press the `P` button.
If still no joy, then hold the power button down at the front of the console until your hear one beep then eventually another. When the PS3 shuts down, let go of the button.
Then press and hold it again until you hear the first beep, 2nd beep then a double-beep.
This will bring up a 6 option menu, select `Restart System`.
This should sort the problem!
Good Luck!
Jul 04, 2010 | Sony Playstation 3 (PS3) Console
PS3 HDMI No picture nor audio
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jun 26, 2010 | Sony Playstation 3 (PS3) Console
My PS3 freezes while playing both discs and demos. Occasionally it won't even recognize that there is a disc in the drive until I eject and put it back. When I click on the disc icon (tried with both...
You need to RESTORE FILE SYSTEM on your ps3.
Here is how you can do it.
HOW TO GO TO THE RECOVERY MENU OF PS3 SYSTEM
1. Make sure the ps3 is plugged in (stand by mode).
2. Put out your usb cable for the controller and the controller itself (do not connect yet).
3. Hold down power firmly, ps3 will turn on and then turn off, release power button when it turns off.
4. Hold down power again, you will hear a beep and then a double beep, when you hear that double beep release the power button.
5. Now you should be seeing something in your monitor that say "Connect usb controller", do just that.
6. After connecting the controller press PS button.
7. You are now in the recovery menu.
8. To fix the problem of corrupt data you can choose #3.
9. If you want to format your hard drive choose #5. Be aware that this option will delete everything that is in your hard drive.
10. Remember that doing #3 and #5 is not 100% to fix the problem of corrupt data, I say about 70%.
Jan 19, 2010 | Sony Playstation 3 (PS3) Console
Ps3 wont read games
update the system by hooking it up the the Computer useing a eathernet cabe.
Jan 18, 2010 | Sony Playstation 3 (PS3) Console
Will not play without using HDMI cable
  1. Make sure the AV Cable is connected to the [AV MULTI-OUT] port on the back of the PLAYSTATION 3 system.
  2. Connect the other end of the AV Cable into the yellow Composite port for video, and into the white and red audio ports (if your TV does not have the red port, simply ignore it) on the back of your TV.
  3. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  4. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically be reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jun 16, 2009 | Sony Playstation 3 (PS3) Console
PS3 Controller will only work when plugged into the USB
i had same problem turn off your system with controller plugged in to usb unplug controller remove the power cable for a couple of mins reconnect and use controller PS button to turn system on and it should be back to normal. it worked for me
May 31, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3
try using the composite cables as well.....with your tv set to the composite input go back into the settings and select the HDMI output switch your tv's input back to your HDMI input and remove the composite cables....it should work fine...
Jan 11, 2008 | Sony Playstation 3 (PS3) Console
My ps3 display
to all those who cannot see any display..hold down the on/off button until it beeps once, then wait a few seconds until it beeps again, the ps3 will have reset itself and will adjust the visual settings to fit your tv
Mar 08, 2007 | Sony Playstation 3 (PS3) Console
Hannspree HF199H 19 Flat Screen LCD Computer Monitor Logo
112 people viewed this question
Top Hannspree Computers & Internet Experts
 Chuck N
Chuck N
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
