Question about Life Fitness 9500RHRT Recumbent Bike
Treadmill belt not moving and speed sensor error comes up on the screen
  • Life Fitness Master
  • 918 Answers
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH Please have your model and serial number available.
Posted on Sep 28, 2015
Merit 725 T plus reading E1
If you wish to get some details about treadmill error codes and repair; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Nov 28, 2016 | Exercise & Fitness
How long does it take for someone to help me, on this site.
How fast you get answers depends on many factors. I just picked up your question but have spent time finding and reading the manual. I am by no means a treadmill expert, but my first thought was treadmill belt tension was too loose to keep the movement sensor happy.
Moving the belt manually would be irrelevant as the electronics would not be monitoring to throw up the E1 Error..
The manual tells you to check all these things.
E1
Loss of Feedback Speed Sensor disconnected Check Speed Sensor
Connection
Speed Sensor Misaligned Check Sensor position
Faulty Speed Sensor Replace Speed Sensor
Loose Display Connection Check Display Cable
Connection
Faulty MCB (D2 LED on) Replace MCB
Faulty Drive Motor Replace Drive Motor
If BH Fitness are being no help, I would be asking them to take the machine away or get it fixed on-site.
So does the belt turn when you switch it on? Is the belt centrally aligned when it spins?
Page 35 shows belt adjustment and I would guess tension although not specifically mentioned.
http://www.bhfitnessusa.com/manuals/final/ts2.pdf
Jan 05, 2016 | Bh Fitness TS2 Folding Treadmill
What is E-1 error in Sportsart Tradmills
ERR1 Definition: The display board CPU didn't receive the optic sensor signal. • Explanation: After processing by the drive board, the optic sensor signal travels the 16-pin cable to the display board CPU, which determines motor speed. Components involved include the optic sensor, optic sensor wheel, 16-pin cable, drive board, display board, and connections. http://www.sportsmith.net/images/product_support/sportsart/Repair%20Manuals/General%20Treadmill%20Svc%20Manual.pdf
Jun 23, 2014 | Sportsart Treadmill Doctor Walking Belt...
Speed Stall error
Have to check the speed sensor. Either the speed sensor is faulty or the can be dust or speed sensor alignment.
If you wish to get some details; check the site linked here. Pull up older posts.
Dec 12, 2013 | Life Fitness F1 Smart Treadmill
Life fitness 9500hr treadmill belt not moving and speed sensor error comes up on the screen
see the video and lube to the rollers bearing front+back .
and Run the calibration software for easy diagnostic for s. sensor
God bless you
Oct 17, 2013 | Life Fitness 9500hr Next Generation next...
Client run on treadmill then suddenly its stop and display an error speed, then 5 seconds treadmill belt moves again and moves faster whats the problem of that?
hi,
There are two possibilities for this problem
1. Check the speed sensor on near the motor pulley. Remove the sensor and clean it and re-fix it. then make a try. if problem remains then
2. The motor speed controller is faulty. There is an IGBT for controlling the motor speed. If it get shorted the motor will run it its high speed.
Be sure before opening the treadmill remove the power.
ok
Feb 25, 2011 | Life Fitness 9100 Next Generation...
Error 1 message on older life fitness t3 treadmill
Error 1 - Start up error. This is caused because the belt was commanded to move and the opto (speed sensor on the motor) has not seen any movement or the belts movement was interrupted prior to it reaching its commanded speed. To fix Verify opto operation in Diagnostics, Motor Test
Mode, Section 2. Verify DC voltage at connector P6 pins 1 and 2. Verify that LED 4 on the Motor Controller flashes as the motor moves. Let me know if you need any more help. Fitness Fix-It
Feb 17, 2010 | Life Fitness T3 Treadmill with Advanced...
Tredmill error code e1
Trimline treadmill starts up then code E2 comes up, and the display shuts down.
Any ideas???
Apr 02, 2009 | Nautilus Tr300 Treadmill
Bowflex treadmill code 05
tHIS MAY BE A SPEED LOSS ERROR. Is the belt moving when this happens? Decribe what lead to this problem in the first place that will help me to better assist you.
Mar 30, 2009 | Bowflex Treadmill Series 7
Life Fitness 9500RHRT Recumbent Bike Logo
442 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Howard
Howard
Glenn Mayer
Glenn Mayer
Craig Butler
Craig Butler
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
