Question about Kubota Garden
We changed water pump in Kubota l3010 tractor. It won't crank and water is coming out of exhaust pipe. Any suggestions?
  • Kubota Master
  • 2,478 Answers
Jonsas, right. Don't try to crank with water on pistons. If it crank, it would bent the rods. Pull spark plugs or injector precups first.
Posted on Apr 03, 2015
    Habit-Forming:
  • 138 Answers
Head gasket water in cylinder so it wont crank ??
2 Suggested Answers
  • 62 Answers
SOURCE: Headlamps quit on L4200 kubota tractor, Wireing
CHECK THE FUSES
Posted on Sep 25, 2009
I just replace hydr. pump on a bx2200 Kubota tractor but it keeps blowing the filters apart . can you help me ?
connected the pipes to the pump incorrectly
filters go on the return lines or suction lines not the high pressure side of the pump
they are only good for a pressure of 30psi not 2000psi
Sep 02, 2017 | Kubota Garden
Starter problems with Kubota l3010 tractor
Could be the solenoid need more information does it click make any noise .Year make an model
Jul 20, 2016 | Kubota Garden
Where is the drain plug for the block drain on a Kubota engine V1902-B?
[PDF]KUBOTA DIESEL ENGINE - Waterax
waterax.com/app/uploads/2015/09/ENGINE-MANUAL-D902.pdf
engine maintenance. it is KUBOTA's policy to utilize as quickly as possible .... Be sure to close the coolant drain valve, secure the pressure cap. and fasten the .... Oil drain plug. (18) Oil ... around the machine. it may catch on moving (B) "OFF".
Kubota V2203 Block Water Drain? - Diesel Bombers
www.dieselbombers.com > ... > Diesel Engine Conversions
Nov 21, 2013 - On my Kubota V2203 DI above the Oil filter is a long bolt of which the only thing ... I did not even know that Block Water Drain was there till last night I ...Also, the pipe plugs in the engine are a Japanese style, but we've ... Kubota v2203 vsv1902, ziegler, Diesel Engine Conversions, 4, 01-10-2015 06:27 PM.
Kubota Engine Service Tips
johnsoncitykubota.com/Kubota%20Engine%20Service%20Tips.htm
If the reading is 11 volts or more while you are trying to crank the engine see the ...Other causes include defective glow plugs or low cranking speeds from a weak battery.... We have not seen it "ruin" anyone's tractor yet, so drain the tank, refill with ....passages between the cylinder head and the block became 90% blocked.
Kubota L2550 needs block heater! - Yesterday's Tractors
www.yesterdaystractors.com > Discussion Forums > Tractors
Jan 25, 2011 - 25 posts - ‎14 authors
Oldmax, I could swear I was looking at a closeup of my engine, except for the colour.... V1702, V1703, V1902, V1903, V2003, V2003T, V2203 (4 cylinder) Part No. ... BSeries (Except 2 cylinder) Part No. Watt Volt Diameter Type .... Paul, does the tractor have a block drain plug, and a thermostat bypass ...
Jan 06, 2016 | Cars & Trucks
L2050 kubota tractor after engine gets hot if i shutdown it will not crank over after cool down starts back up.
Nest time it is hot and does not start, check for spark. U could have a thermal issue where the ignition coil gets hot and stops working till it cools down.
U mentioned glow plugs - is this a diesel powered unit? Check for proper oil level in unit? Oil pump? Poor lubrication will cause an engine to expand when hot and not restart till it cools down.
Oct 13, 2015 | Kubota Garden
Can I adjust or take out thermostat in my Kubota D902-E diesel motor it overheats
u need to find the cause, here is a easy rundown. 1/ make sure water levels are full,remove radiator cap start up and let run about 1/2 throttle if starting to get hot and no water shouting out of rad. its not a head gasket2/whiledoing step 1 can you see thr water moving thru the system . if so.not water pump.3/ replace thermostat make sure fans come on good luck
Oct 22, 2012 | Kubota Garden
I have a kubota bx25 that won't start. it has power to the starter on battery side
you need to have power to the small wire on the starter for it to crank over
Sep 03, 2012 | Woods Kubota Bx 24 Bx 23 Bt610 Bh75 And...
Kubota G4200H Diesel won't smoke or fire up. New gas pump,fuel filter,battery,glow plugs,new gas. Bleed lines many times. Voltage at glow plugs ( approx. 10 volts), glow lamp works. Checked 10amp fuse....
There is air in the high-pressure line from pump to injector. Ensure that there is diesel up to the pump inlet, Back off the injectors connector(s) one turn (so it's loose but not falling off). Connect a FULLY CHARGED battery and crank until diesel comes out of the loose injector connector. Whilst still cranking, tighten the injector nut. With any luck, the engine will start. You may have to repeat this several times.
The 'cheat' is to spray WD40 into the air intake after removing the filter, and crank. The engine will fire on the WD40 and run fast enough to purge the fuel line. Even when doing this, you may still need to back off the injector connector(s).
Mar 09, 2010 | Garden
Garden Logo
143 people viewed this question
Top Kubota Garden Experts
Vernon Taylor
Mike Henne
Level 1 Expert
Are you a Kubota Garden Expert? Answer questions, earn points and help others
