Question about Miscellaneous
What to do if one of the two Blue LED lights inside the reciever does not come on?
Led lite blue solid and led lite red solid when i turn on my pdp-5070pu
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Apr 03, 2014 | Pioneer Televison & Video
My shure mic receiver SLX4 is showing Ready indication but not recieving the Audio from SM58 mic...whether it is reciever problem or transmitter.. what is the solution
If you shout into mic and the audio signal LED on receiver lights everything is ok.First check your receiver to amplifier jacks and cables,If ok check muting transistor inside the receiver next to the audio output terminal.As an expert on cordless microphones I'll be glad to answer your questions. Send me an e.mail if you wish at moska.1982@yahoo.com
Feb 15, 2012 | Shure SM58 Professional Microphone
I am trying to hook up my Pioneer vsx-455 to a LG LED LCD TV. I am not sure on how to do this and I can not find a manual anywhere. Can you help me?
your reciever does not have hdmi, so the audio is not going to be true DD+ or DTS for broadcast tv.
if your dvd/blue ray player has digital optical spdif, this can be used to transfer the encoded DD+/DTS digital audio.
the besat way to run your tv audio through the reciever is to hook up the dvd/blue ray player up with (perferrably) digital optical spdif, composite spdif or (least favorably) through the stereo stereo analog inputs on the reciever for "dvd" audio in and hook the video from the dvd/blue ray up to the corresponding "dvd" video component input on the reciever.
this way is only going to get your dvd/blue ray sound, next you need to hook up your cable box to the reciever so that you can get broadcast tv sound. hook up the cable box audio to the "tv" stereo analog audio ins, and hook the video to the corresponding "tv" video component inputs.
the component video inputs have separate jacks for red, green and blue ( labeled "Y" "Pb" and "Pr") and are capable of carrying a 1080p full hd signal. use the component video outputs on the reciever to output the video signal to a component video input on the tv, using the receiver's input selector to change the video source.
Nov 25, 2010 | Pioneer VSX-455 Receiver
Even though the camera works, the blue light no
Perhaps the LED burnt out or is defective, or a wired came loose inside the webcam. It might not matter as long as your webcam works. Test it on the free webcam test tool just to be sure.
May 11, 2010 | HP KQ246AA Deluxe Webcam
Does the pioneer sx315 receiver work with the samsung led?
From memory, this amp does not have HDMI.
If this is the case, use an optical fibre cable for your connections.(Audio)
And if you want every thing to run through your amp you will also need to use component video cables (red/green/blue)
I would suggest the following.
Blue Ray to TV with HDMI.
HD Reciever to TV with HDMI.
TV AUDIO OUT to AMP with Optical Fibre.
This way, whatever is displayed on the tv, the sound will come throught the amp.
Hope this helps.
Sep 05, 2009 | Pioneer Audio Players & Recorders
Receiver not recognized by computer
The green LED on this reciever is also a button. Press the LED on the reciever with a small blunt object (pencil will work) and then press the "connect" button on the bottom of the mouse. The green LED should come on, and restore the connection between the reciever and the mouse.
Apr 14, 2009 | Microsoft Wireless Notebook Optical Mouse...
I have a wireless headphones the only number i can see is model f0461b on the trasmitter. The transmitter and headphone are not comunicating the lights are red not blue.How do i recalibrate them so they...
In rare cases, the FreePulse Headphones may loose synchronization with the receiver. If this occurs the following steps will re-establish the connection by putting both the headphones and the receiver in discoverable mode (actively searching for another bluetooth device it can connect to).
Putting the headphones in discoverable mode:
Press and hold the power button (located next to the charging port on the right earpiece) on the headphones. The LED on the button will go through three states in this order:
  • Blinking Red
  • Off (continue to hold. the LED will be off for several seconds)
  • Alternately blinking red and blue. (The headphones are now in discoverable mode and you can release the button at this point. The headphones will remain in this state for 30 seconds).
Putting the receiver in discoverable mode:
Press and hold the power button (located on the side of the receiver opposite the headphone jack).The LED on the button will go through three states in this order:
  • Blinking Red
  • Alternately blinking red and blue. (The reciever is now in discoverable mode and you can release the button at this point. The reciever will remain in this state for 30 seconds).
Re-establishing the connection:
To re-establish the connection between the headphones and the reciever, put the headphones and the receiver in discoverable mode at the same time. It will take a few seconds for the two devices to establish the connection. Once the connection has been established the LEDs on both the headphones and receiver will glow solid blue.
Nov 19, 2008 | Audio Players & Recorders
My logitech headphones dont turn on anymore.
Quote from LOGITECH official site:
  • Blinking Red
  • Blinking Red
Do this and Freepulse will be pleased.
Aug 15, 2008 | Logitech FreePulse Wireless Consumer...
Blue light
If it is a Laptop, sorry but no.
If it is a PC, restart it and hit F10 (Setup)[i think] and go to LED options, then check to see if you can, or cannot turn them on/off.
Dec 13, 2007 | Veo Connect Webcam
Wireless LED blinking, normal?
Same problem here - wireless light starts blinking and I get a network interruption. At that point, I have to walk across the house and downstairs to cycle the power on the router to get it working again. What a pain - and the manual doesn't even mention a blinking status for that light. I'm thinking about hooking the router up to a automated power switch (X12) so I can remotely cycle the power.
Dec 17, 2006 | NetGear RangeMax WPN824 Router
Miscellaneous Logo
22 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
