Question about AUVIO SOUNDBAR 32&
What happens (with a coaxial cord, new)) is that it emits a really loud, quick palpatation-like sounds, as if it were cord problem. The Coaxial is from the tv to speaker.
I can use the bluetooth, so thats not a problem, but otherwise I cannot use any cord I plug into it.
  • 352 Answers
It sound like the connector needs to be replaced.
Posted on Mar 30, 2015
Testimonial: "I will check it out and get back to you. Thank you!"
Where is the coaxial output on the LT-2722 twenty-seven inch LCD TV from Norcent
Many new TV's do not have a standard coaxial input anymore. The industry has moved on from that and you might have to get an external tuner to get an input like that. I found an old review from 2006 and it shows the antenna input on the bottom side where the power cord plugs in. http://www.geek.com/xyzcomputing/norcent-lt-2722-27-inch-lcd-tv-571351/
Jul 07, 2016 | Televison & Video
How to get sound from digital coaxial output? Trying to hookup to surround sound system but getting no sound
Digital out put needs a digital input to go into. You also need to set up your television to use the digital sound. That is in the audio menu.
Mar 08, 2016 | Vizio Vbr122 Blu-ray Player With Wireless...
Lightning run through coaxial cable
have you tried replacing the coaxial cable? could have burnt out the internal wiring in the cable
May 24, 2012 | Sanyo Dp32640
I Just recently bought this have it hooked up to my Computer through a Digital audio Coaxial cord . The problem is this 600 - Watt system is emitting less power than the 300 watt one it replaced that was...
Audio power is relevant only between the amp and the speakers. Check the volume setting of the source and any audio settings in the PC.
SPDIF is not Red and White. If anything it is a single coaxial RCA connector.
Wattage specs for comparison are pure fiction at this level. 10% distortion fudges the number upward.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/RCA-RT2910-Home-Theater-Systems-manual/id/23699ag100/t/2/
Defeat any bass enhancement in the source until you figure out the level issue.
Mar 23, 2011 | RCA RT2910 Theater System
I hava a insignia dvd receiver is-htib102731 and want to know what optical digital audio cord to buy for sound on my tv
gailsplaytim,
That really depends on what audio inputs you have on your tv. Your Insignia has composite audio outputs (Red and White) and digital coaxial and your tv most likely will have at least composite inputs.
The easiest way to connect your dvd to your tv is just to use the composite as you will not hear the difference in sound quality between the two through the speakers built into your tv.
If you want to run digital audio into your tv for a reason such as the tv's audio output is running to another device like a receiver and you want the digital audio to transfer, you need to look at what digital audio inputs you have on your tv. The only digital audio output on your dvd is a digital coaxial. You can buy digital coaxial converters online. If your tv for example has a toslink input, there are digital coaxial to toslink converters relativity cheap online
-Chris.
Feb 28, 2010 | Electronics - Others
On the digital input 1 have the coaxial cable hooked up to blu-ray player but i have no sound, but if i hook up optical i do have sound.. wrong coaxial cable
Possibly a bad cable, but not likely its a 'wrong' one. Any RCA-style cable will do for SPDIF coaxial digital signals. Try another one. Are there other Digital Coaxial inputs you could try to prove the function?
You may have to configure your Digital Inputs so the receiver knows Digital Input 1 is Coaxial.
Nov 19, 2009 | Technics SA-DX950 Receiver
CANNOT FIND CABLE CONNECTION FOR AKAI TV LCT42V6TN
They don't make a coaxial to RGB or Component adapter. I know they make a coaxial to RCA. If you go that route you would just connect the coaxial to the video. Now if you do this not sure as to what would happen with sound, if you would have it or not. It is possible but not sure. The adapter I am talking about is called a
UHF Female to RCA Male Coaxial Adapter. Which can be found at most Radio Shacks. If this doesn't work I would contact the cable company about a cable box that they could then run the coaxial to and then the RGB or Component cables to the TV.
Hope this helps.
Mar 01, 2009 | PC Connection RG6 Bulk Coax Cable, Plenum...
The coaxial opening on back of dvd recorder
Go to an electronics store and pick up some quick release coax adaptors. They screw into the cable and the other end just plugs in without screwing it in.
Here is an example of what one looks like on amazon.com
Jul 19, 2008 | Televison & Video
Connecting Dell speaker system to TV or console
If you have a coaxial out on your TV and a coaxial in on your Speaker system that is the way to go to experience digital surround sound. Radio Shack, etc. has coaxial cables in the appropriate size. If you go to Radio Shack, etc. bring along your speaker system's model number as well as your TV's model number.
Hope this gets you going.
Worldvet
May 18, 2008 | Audio Players & Recorders
Video input not recognized for LD and DVD
By coaxial, do you mean the composite (yellow)? Either way you have to use the same style no matter what the cable. I mean, if you have s-video's IN to the reciever then you need S-videos OUT to the TV. ....Component IN to the reciever? then Component OUT to the TV. And so on. You cant have composite cords going into the reciever and use a component cord out to the TV (with the exception of a few models).
Sep 10, 2007 | Pioneer VSX-D912 Receiver
AUVIO SOUNDBAR 32& Logo
103 people viewed this question
Top AUVIO Audio Players & Recorders Experts
 Mikey
Mikey
L Pfaff
L Pfaff
Vladimir Frolov
Are you an AUVIO Audio Player and Recorder Expert? Answer questions, earn points and help others
