Question about Harmon Kardon Harman Kardon - Avr 1700 500w 5.1-ch. A/v Home Theater Receiver
Bco update shows up on the display and it won't let me adjust the volume level on my avr 1700 harmon karmon receiver
Harmon karmon
Try pulling the batteries out for 5 minutes or so, and see if that resets it to factory defaults.
Dec 18, 2014 | Harman Multimedia AVR 245 7.1 Channels...
Why does update say the usb folder is empty?
formatting wipes everything off the device usually, you may have deleted what was on there, hope this helps.
Jun 23, 2014 | Harmon Kardon Harman Kardon - Avr 1700...
Bco update
you need to connect the receiver to the internet make sure you have a direct connection with a cat 5 cable.
Apr 15, 2014 | Harman/Kardon AVR 1700
How to troubleshooting
prob with the audio amph on the motherboard
Dec 04, 2013 | Harmon Kardon Harman Kardon Harman/kardon...
Avr-1700 airplay
I have the same problem. Please let me know if you were able to find a solution. Carzev@yahoo.com
Dec 21, 2012 | Harmon Kardon Harman Kardon - Avr 1700...
Audio problems
Click the link below for manual pages I mention to make changes:
http://www.harmankardon.com/resources/Brands/harmankardon/Products/ProductRelatedDocuments/en-US/OwnersManual/AVR1700_OM_EN.pdf
Most dialog sound comes from the center channel / speaker. If not working correctly, it make become difficult to hear people talking especially if there is a lot of other sound going on in movies and some music, too.
Check and adjust the volume level for the center channel or speaker. Check page 8 of the manual to learn how to use the remote to change the volume level of individual channels or speakers.
If you want, you may find it is a good idea to check page 17 to esablish correct volume levels for each channel by runnijng the set up with the microphone. This will allow the system to be "calibrated" for the room. This is a very important step in "getting the sound right".
If none of these suggestions work, you may have a problem with the center speaker itself - or with the amplifier for the center channel.
I hope this helps & good luck!
Check the speaker connections for the center channel. Page 6 shows the location on the rear of the amplifier - but check the speaker itself first as it is easier to get to and the rear of the amp is less likely to be distrubed and have a poor connection.
Dec 13, 2012 | Harmon Kardon Harman Kardon - Avr 1700...
Harmon kardon 745 displays "unlock" no sound for tv or movies
I also had this UNLOCK message on my Harman Cardon AVR 130.
The reason for this error was - in a hurry I've plugged the optical input into optical OUT! Double check that your connections in the back are correct and hopefully it fixes your problem.
Cheers,
Sergey
Jan 11, 2009 | Harman Kardon AVR 130 Receiver
Multi-zone volume levels --not adjustable (too high!)
Press the reciever button on tyhe remote until it say Multi in the display. You can now adjust the multi zone volume level.
Jul 18, 2008 | Denon AVR-3802 Receiver
Was using the harmon kardon avr 225 receiver and the front panel went out. .... screen display of the channel number, volume, or menu item does not work. ...
Try hooking up a yellow video wire from the back of the AVR 225 Monitor out. Should be at the end of the 7 or 8 yellow video ports on the back of the stereo. Next plug the other end into a yellow video in on a t.v. Get your remote, (Harmon/Kardon) and make sure the t.v. is on the correct video input and hit the OSD(on screen display) button on your harmon remote. There should be a setting in there that says VFD under ADVANCED menu option that allows for turning the front of your stereo lights on and off and dimming them half way also. OFF/HALF/FULL are the 3 options I believe.
If this doesnt solve it your display may have crapped out on you.
Jan 22, 2008 | Harman Kardon AVR 225 Receiver
Harmon Kardon Harman Kardon - Avr 1700 500w 5.1-ch. A/v Home Theater Receiver Logo
87 people viewed this question
Top Harmon Kardon Audio Players & Recorders Experts
Steve
 Grubhead
Grubhead
Ngoro
Ngoro
Are you a Harmon Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
