Question about Nakamichi Car Audio & Video
Nakamichi NA1550 phone does works when radio is on, but not if disc or USB playing.
Device is paired with Samsung Galaxy phone.
SOURCE: samsung bluetooth device pass key ?
Try 0000
Posted on Jul 27, 2008
Dissolu
  • 221 Answers
SOURCE: bluetooth/radio stopped working
In first instance try to disconnect the unit from the mains and reconnect 15-20secs later 8 times out of 10 it helps. otherwise you might need to reprogram the unit processor which is more complicated and requires knowledge and understanding of electronic principles, assembler, also some devices to perform the task.
Otherwise I'm not sure about exact model of your ECU (computer) but in some cases it also gives the access to reprogrammable radio unit, so in this case laptop, one simple program (u can find it as free downloadable .exe file) and special diagnostics cable wuold sort everything out. But as I said not all ECUs offers such an option. And if you'll go for this step you need some knowledge about electronics and soldering as you'll have to build the cable I mentioned, as tu purchase one would be quite painfull for your vallet.
Hope it helped although if you need any further information just drop a line here.
Posted on Mar 27, 2009
Z1G ZA9
  • 122 Answers
SOURCE: disc and usb cable that came with samsung sgh-e900 mobile phone does not work with windows vista desktop
Hi
the version software that came with your phone, PC studio is not compatible with Vista. However here is a link that you can download the version that is. It will be same cable.
http://www.samsung.com/uk/support/download/supportDown.do?group=mobilephones&type=mobilephones&subtype=slide&model_nm=SGH-E900&disp_nm=SGH-E900&language=&cate_type=all&dType=D&mType=SW&vType=&prd_ia_cd=01011800&model_cd=&menu=download
Hope that solves your problem?
Posted on Apr 26, 2009
  • 6 Answers
SOURCE: Jawbone bluetooth won't pair with phone.
sometimes the phone will not pick up on certain bluetooth headsets so i recommend a Motorola.
Posted on Jun 04, 2009
  • 928 Answers
SOURCE: I have the Samsung Galaxy I7500 but cannot get its
Most samsungs comes with only A2DP BT profile, this means that it can only pair up with BT headset device. If you know how to navigate your phone, go to the BT settings and check the profiles.
Posted on Sep 29, 2009
Why does my samsung galaxy rush think there are earphones plugged in when there are none?
1) Check to be sure that "Hands Free" mode is off. This may be overriding the settings to believe you have bluetooth connected. and/or
2) check to be sure a bluetooth device the phone is paired with is not on and active.
Aug 11, 2014 | Samsung Galaxy Rush Boost Mobile
How can I connect my galaxy s3 cell phone to my tv?
How to connect Samsung Galaxy S3 to TV..
There are 3 ways to do this..
1. You can use a compatible MHL adapter that connects to the micro USB charging port of your phone and then a regular HDMI cable from your TV connects to the MHL adapter that's connected to your phone. You will have to connect the Samsung micro USB charging cable to the MHL adapter in order for this to work.
You will be able to see everything that you do on your device, however you will be limited to how you hold your phone if you are trying to play a game and direct what you see on the screen to the TV.
Note: the MHL adapter may overheat your device if you have it on and working for long periods of time.
Youtube example of MHL to TV:
How to Mirror or connect Samsung Galaxy s3 to TV
2. You can use a remote access app on the phone to view on a PC/TV monitor. Depending on the remote access app, there maybe a lag seeing the image on your screen. Most apps like this are paid apps.
3. The Samsung Galaxy S3 phone has a natively installed software tool on the phone or can be downloaded from the Samsung Galaxy App Store (Available after you set up your Samsung account on your phone) that can link to a compatible DLNA device (most TV's that are 2005 or older). The app is called Samsung AllShare Play, or it may also be called Samsung Link
Youtube video:
How To Use Samsung Link previously AllShare Play
Jan 15, 2013 | Samsung Galaxy Cell Phones
How do I pair a Samsung bluetooth headset model HM1000 to my Nokia C7-00 phone?
1.first on samsung bluetooth device
2.press& hold call answer button in bluetooth device now light is on ,not blinking
3.and then search your bluetooth device by your phone and pair.
Apr 11, 2012 | Samsung HM1000 Bluetooth Headset
How to pair Samsung Galaxy 551 cel phone to vehicle radio
search on radio for settings find phone if it asks for a code normally 0000
Feb 15, 2012 | Samsung Galaxy 551 Cell Phone
Didnt get a disc with my samsung galaxy cant connect it to the laptop dosent reckonise the device
You don't need a disc, you need Samsung Kies (so just google for it and download it to your computer). After installing you will have a working driver for your device. Under connection settings and I mean USB connection settings (you can find it in under Settings -> Wireless and network, change it to connect to samsung kies. Connect the phone and open Kies and everything should work.
Jul 29, 2011 | Samsung Galaxy S GTI9000 Smartphone
I cannot pair a Nokia 6700 with Samsung Galaxy s11 via Bluetooth. The Galaxy recognises the Nokia, but says problem with PIN nunber or Password. I don't know of any such PIN or Password. Cannot connect...
If you need the pairing code for Bluetooth to connect just pairing with the same code in each device
for example if your device asking for code just enter 1 in your device ( Samsung galaxy) and enter the same code (it means 1 for Nokia), the code will depend on you but the important the code must be same each other.
Jun 05, 2011 | Samsung Cell Phones
I want to view pics on my pc from my samsung galaxy s phne with the usb but i dnt have the disc
In Mass Storage mode, once the device is recognized on your PC, extend the notification area on your phone (press top of the screen on your GS and slide it down), then select "Mount USB" (can't remember exactly the text, but it is USB related), then you will be able to access the phone internal memory and the SD card from your PC.
Jun 03, 2011 | Samsung Galaxy S GTI9000 Smartphone
Cant setup audio from samsung galaxy to toyota camry xle 2010 via bluetooth tohear music.Bluetooh works for phonecalls though.
Most likely due to the pairing problem. The technology which allows streaming is called A2DP and some times during the pairing the other device (your car or other) might not be able to respond or configure itself. I can suggest few steps,
1. Make sure both devices support a2dp (Samsung Galaxy S does support and your camry XLE too supports)
2. Restart the phone/Car bluetooth
3. Unpair and try to do pairing one more time. If it asks for any password then provide the default password as per your car manual
4. Try to make the phone visible (Applications>Settings>Wireless and Network>Bluetooth Settings>Visible.
If all options fail, perhaps you may check with the toyoto service center. Sometimes the other device may need specific security parameters or requirements.
Hope it helps.
Mar 11, 2011 | Samsung Galaxy S GTI9000 Smartphone
Pair Bluetooth Stereo
put the music player on and press down on the jogwheel, select 'Play Via' and change it to Bluetooth stereo headset. It'll prompt you to open the swivel and take you to the bluetooth devices screen where you select the correct device, it'll then prompt you to close the swivel and will start playing through your headphones :-) Is that what you mean?... It's a bit of a pain really :-(
Aug 04, 2007 | Samsung SGH-X830 Cellular Phone
Car Audio & Video Logo
48 people viewed this question
Top Nakamichi Car Audio & Video Experts
Aaron Hackbarth
Level 1 Expert
Jaime Hernandez
Mohamed Ismail
Mohamed Ismail
Are you a Nakamichi Car Audio and Video Expert? Answer questions, earn points and help others
