Question about Hotpoint -Ariston Aquarius WD645 Front Load All-in-One Washer / Dryer
My aquarius washer/dryer wd645 is flashing f-07
Its flasing f-07
  • andrea ludlow
    andrea ludlow Apr 01, 2015
    the machine sound like its goin to run a cycle and takes the liquid from the drawer but then stops dead and starts flashing code f-07
    Filmmaker:
    Uploaded 5 video answers.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 24 Answers
Dont warry it will be for few time then it will be ok
Posted on Apr 01, 2015
  • andrea ludlow
    thank you aman ansari for your help,i have taken your advice but it has not helped,any other ideas please
  • Aman Ansari
    Aman Ansari Apr 02, 2015
    i will advise u to plz call service center and it will solve it for free if your waranty is valid
    Top Expert:
  • Hotpoint Master
  • 10,875 Answers
Replacing Oven Electronic Control
Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
I NEED A MANUAL FOR HOTPOINT AQUARIUS WDL520G
You should be able to download the user manual from the following site: hotpointservice.co.uk/pages/manual
Or directly download from this link: Hotpoint/Laundry/WDL520 (pdf)
Hope helps.
Sep 25, 2011 | Hotpoint -Ariston Aquarius WD645 Front...
No manual
Go to the following site.
WWW.HOTPOINTSERVICE.CO.UK
In the menu on the left, click on USER MANUALS.
Then enter your model number in the search box.
Then download the instructions.
Nov 19, 2010 | Hotpoint -Ariston Aquarius WD645 Front...
Manuals
http://dl.owneriq.net/3/38ecd169-5275-4ae3-a0b1-cabeff66dafe.pdf
May 22, 2010 | Hotpoint -Ariston Aquarius WD645 Front...
Clean Filter?
There is a filter at the rear of the washer.
Remove lower rear panel.
Remove large black hose from bottom of drum.
Remove and clean filter in inside hose.
Remove hose onto pump and check for blockage oe obstruction here as well.
Please rate my solution.
Thankyou.
Jan 27, 2010 | Hotpoint -Ariston Aquarius WD645 Front...
Hi ,, my machine has no power ,, when i push the start button there is nothing at all ,, no lights nothing ,, i have tried the plug and fuse ,,the machine is the hotpoint wd645 ,,, many thanks
Try the plug in another socket that you know is o/k, if still no go ,then you need to remove top cover and rear panel, and check all connectins to control module/s.
Make sure the door is fully catch is fully engaged, as sometimes the spring can give out in the door handle.
Jan 16, 2010 | Hotpoint -Ariston Aquarius WD645 Front...
Wd645 has no power to on/off switch. changed plug
Could be mains choke. Mains power comes into mahine via wall socket /worth checking this then onto mains filter/Choke..then to switch..So if no power here check this..wish you well
Oct 07, 2009 | Hotpoint Aquarius WD640 Front Load...
Tumble dryer isn't woking
You may need to replace the thermostat or the heating element.
Apr 13, 2009 | Hotpoint -Ariston Aquarius WD645 Front...
Hotpoint wd645 flashing f-08
The manual says F08 - Heater relay cannot be activated.The dryer might be having difficulty with this.It is not something that can be fixed.Heater Relay equipment might be damaged.Might have to call a repairman to set this right.Good luck.Do post comments for more help.
Jan 10, 2009 | LG WD-14124RD Front Load Washer / Dryer
HOTPOINT KEEPS FLASING F-03
The error code F03 indicates that the wash thermistor is open or short circuit.
Check heater element and thermistor,if ok, then you need to call an engineer.
Sep 22, 2008 | Hotpoint Aquarius WD63 Front Load...
F-05 flashes up and water not draining out
An F-05 error message means that the pressure switch is jammed on empty or a problem with pump.
The fault is associated with drain out (pump blocked or restricted in some way).
Small panel at rear of machine reveals the pump, pull of the two pipes (Plastic clips hard to get off, slide them sideways), remove wire and unclip pump from base of machine by lifting locking tab and sliding to the left, pump can then easily be cleaned.
Jun 30, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint -Ariston Aquarius WD645 Front Load All-in-One Washer / Dryer Logo
66 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
