Question about Samsung Refrigerators
How do I remove the inside back panel of a Samsung refrigerator model #RB195ACWP
  • Samsung Master
  • 5,323 Answers
USUALLY HAVE TO REMOVE THE BOTTOM PLATE FIRST 4 SCREWS i THINK
Posted on Apr 07, 2015
  • 93 Answers
SOURCE: Chemical odor in refrigerator/freezer
put coffeee grains or orange peeles this will take the smell away thanks from gilles
Posted on Mar 15, 2009
  • 351 Answers
SOURCE: water leaking into refrigerator
yes you have to take off the ice maker then remove the scews, sometimes there is a air channel that has to be removed which are held in by plastic tabs
Posted on May 06, 2009
  • 291 Answers
SOURCE: Ice keeps forming inside on the back panel of mysubzero model 550
If the ice is on the back panel especially a block of ice in the middle left part of your panel, then you have a sealed system problem. Check to make sure that your condensor coils above the refer are clean, and if it continues to have an ice block then you have to have a technician come out an do a major repair. This is not something you can do yourself, most subzeros have a 6 to 12 year sealed system warrantee that covers either all of the repair or just parts. This is an expensive repair if it is not warranteed, but when the refers cost 8000 to 10000 new it is usually well worth it. Most often it is the result of a slowly leaking evaporator, though most inexperienced technicians replace the compressor first, so make sure you use an experienced Sub-Zero technician. Good Luck, Appliance Specialits
Posted on Dec 14, 2009
guru_fixya
  • 944 Answers
SOURCE: samsung model rs2577sl side
This seems problem is with the main control board,Because you say the lights works and display panel works.It seems this is an short circuit on the board or the main control board.Use multi
meter to test on the board.Check for the change in reading.
The main control board controls the power supply to the
compressor.
Note:It needs testing on the board and the wiring connection.
Need to do continuity testing to find the exact cause.
Mainly the control board is good.I feel the problem is with
wiring connection
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 22, 2010
  • 351 Answers
SOURCE: I have 501R model Sub-Zero
it is low on gas or coolant need a appliance tec to fix it
Posted on Oct 03, 2010
Refrigerator barely cooling and freezer part isn't cooling at all
Can you feel the compressor top to see if too hot to keep your hand there? Tell me if the fan is running next to the compressor and if the evaporator fan is running. If the compressor and fan are running normally I need you to remove the cover over the evaporator inside the back of the freezer and see what the frost pattern looks like. (provide photo of evaporator frost pattern)? I can help you find the problem if you respond to my questions. Hopefully this is only a start relay overload and run capacitor. Here is a list of parts=> http://www.repairclinic.com/vwo7/Shop-For-Parts/a4b160d1067876/Model-RB195ACWP-Samsung-Refrigerator-Parts?sml=true?RCAID=35836
Try to upload photo here but if unable I will provide my contact info. Below is a photo of a refrigerator evaporator that shows that the refrigerator is leaking Freon. APPLIANCE 911 74bbe3be-3b56-4111-ae2b-7d0d2139a639.jpg
Nov 29, 2015 | Samsung RB195ACWP Bottom Freezer...
How do I remove the back wall of freezer on samsung rb195acwp
Annonymous, what problem are you trying to solve? Is the water at the bottom of the refrigerator because the fridge is not cooling? If that then unplug the fridge, Keep the fridge and the freezer doors open after salvaging food items. Keep it unplugged for about 12 hrs and any ice buildup in the back wall will melt. You will see a pool of water on the floor. Clean that and the inside of fridge and freezer. Re-connect. You might get lucky!
Jul 29, 2014 | Samsung RB195ACWP Bottom Freezer...
Ice build up under the produce drawers of a Samsung refrigerator model RB195ACWP.
You need to contact Samsung about that. there is a fix kit out for that issue. I've put several of them in myself but cant find online how to order it. basically the water is leaking from the evap in the fridge to your fridge bottom and then it freezes because it sits there in the cold for so long. Hope this helped!
Aug 09, 2013 | Samsung Refrigerators
Samsung RF26XAEBP frig a little over 2 years old sounds like fan motor is rubbing behind icemaker area when i open the door it stops close the door it starts again how to resolve?
You need to unplug and then remove the rear panel inside the back of the freezer and look over the fan assemblies to insure they are not hitting accumulated ice. Ice buildup around fans can be caused by leaving refrigerator or freezer door open over extended times or defrost component failure. Either way it's a good idea to have a look at the inside of the evaporator compartment to prevent damage to fan blades and food loss. Click HERE FOR=>> Samsung Refrigerator Model RF26XAEBP Parts I will be here if you have questions, Thanks Sea Breeze
Jul 03, 2012 | Samsung RF26XAEBP
How to install water line to a samung refrigerator
One line hooks to the water supply, the other line hooks to the ice maker. How old is refig?
May 08, 2012 | Samsung RB195ACWP Bottom Freezer...
Samsung double door refrigerator/freezer is not holding the tempature in the refrigerator. When you attempt to reset the temperature and press "power cool" nothing... temp remains around 56 The freezer...
I just had (have?) this same problem. I called out the repair man and in the end he suggested that I buy a new fridge because of all the problems reported with my model (RS2555SL) on the internet. Anyway, after a while I heard what sounded like a fan trying to spin on the fridge side. I unplugged the unit, removed the inside back panel on the fridge side. The entire coils and the fan had iced over. I removed all the ice, plugged the unit back in and it is now working. I will still replace this unit because I probably only corrected the symptom but the problem remains.
Jun 15, 2009 | Samsung RS2556 Side by Side Refrigerator
Refrigerators Logo
123 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
