Question about Plantronics Radio Communications
I can't get my Plantronics Marque 2 M165 to work anymore. The indicator light is solid white when charging. It won't connect to anything or do anything at all. Is there a reset or something I can do to fix it?
SOURCE: can't get charged
same problem
Posted on Jul 31, 2008
SOURCE: Solid Purple Light on Plantronics 220
Explorer 230 went into solid blue light the second time I used it. Fixed mine by letting the headset go completely dead and re-charged and it appears to work fine now.
Posted on Jun 07, 2010
wb91
  • 126 Answers
SOURCE: My plantronics discovery 975 will
It sounds like you're still in pairing mode (and not paired) if the light is flashing white/red. Take a look at the following link on pairing instructions:
Plantronics Discovery 975 Pairing
If it continued to flash white/red and not pair, you may have a defective unit. Contact where you purchased the unit for a replacement or call Plantronics at 1-800-544-4660 x 5538.
Good Luck from Headsets Direct!
Posted on Apr 18, 2011
HDI Headsets
  • 537 Answers
SOURCE: I have an LG phone
You want to make sure that there is no other bluetooth interference on your phone and follow the instructions on the link for the Plantronics Discovery 925 (see page 4).
Good luck from Headsets Direct!
Posted on Aug 31, 2011
HDI Headsets
  • 537 Answers
SOURCE: When I try to charge
If this is not charging correctly it may be that the battery is no longer functioning properly. The batteries are non replaceable on this headset. If this is still under warranty (1year) you should be able to get a replacement
Here is a link to the User's Guide.
Posted on Oct 10, 2011
Why My Marque 2 M165 Bluetooth Blinking repeated in Red?
Might be a clue if you looked up your user manual if it says anything about your Marque 2 M165 Bluetooth Blinking repeated in Red.
May 06, 2015 | Radio Communications
Plantronics M165 why is the red light flashing when plugged into charger
Flashing means it is charging. When fully charged, it will be a steady light.
Jul 25, 2014 | Radio Communications
How can I get my bluetooth connected to my phone
The problem I had connecting mine was operator error. First, make sure bluetooth is enabled on your phone. Then, turn on the headset using the sliding switch on one side. After that, the circle looking button on the front side needs to be held down (it takes a pretty firm touch) for a couple of seconds to initiate the bluetooth connection. Hope this helps.
Jun 08, 2014 | Marque 2 Headset Plantronics Marque 2 M165...
How can i change the ringtone for plantronics M165?
Why would you want to change the ringtone on a headset. I think they are preset from the factory
May 03, 2014 | Marque 2 Headset Plantronics Marque 2 M165...
Bluetooth will not stay connected to cell phone when wi-fi is in use
If this only happens at home, you can probably enter the wifi settings and change the channel it uses to connect. If it happens any time you're near a wifi connection, you'd have to change the channel setting within the Bluetooth device if that's even possible.
Mar 08, 2014 | BluetoothTronics.com Plantronics Marque 2...
Indicator light not on and won't charge
My plantronics M50 won't charge anymore it was working fine. Is there anything I can do to repair it or reset?
Jan 02, 2014 | Plantronics M50 Bluetoothe Headset
I am having problems getting my Voyager Pro bluetooth to recharge. I am not getting the solid red light to indicate the unit is charging.
So if it won't charge, it may be that the charger is bad, and you may not have a way of charging it to find out if it is the charger or the battery. If it is the charger you can get a new one, there is a link below to the right part. If it is the headset and it is still under warranty return it to the vendor.
Plantronics 79414-01 AC Adapter
Oct 21, 2010 | Plantronics Voyager PRO Bluetooth Headset
My lg vx1100 can not find my plantronics 232 explorer and I do not have the instructions anymore.....can anyone help?
The following are for TB-20EL model. But it works in general for plantronics as well. For step 3 make sure your headset is in pairing mode. When you hold the button 6-8 sec, it should turn either solid blue or blink.
for tb-20el:
1. ensure that your phone's bluetooth feature is on
2.Ensure that the headset is off(press and hold button on your headset (called multifuntcion button) for 2-4 sec, teh indicator light will flash red)
3. press and hold the multifunction button for 6-8 seconds until the indicator light alternately flashes blue and red
4. set your phone to find new device
5. Ente rpin '0000' (four zero) then press OK or yes
6. this should complete the pairing.
Mar 31, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Oct 09, 2008 | Plantronics Explorer 220 Bluetooth Headset...
Radio Communications Logo
64 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
Ed Nelson
Ed Nelson
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
